Uptime Robot
Uptime Robot is an uptime monitoring platform, providing a free tier to create up to 50 free monitors for Website, SSL, Port and Ping, as well as heartbeats to monitor reoccurring jobs. This dashboard gives an overview of monitoring configured using Uptime Robot’s website monitoring features.
- Create a Web API provider to connect with your Uptime Robot environment.
Use the following settings:In SquaredUp browse to System > Administration > Integrations.
- Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using. Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
 - Complete the provider fields, using your API provider's online documentation as a guide.
 - You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
 - In DS for SCOM go System > Administration > Content > Community Packs and drag the zip file into the Manual Import box.
 - The dashboard pack is imported and if the pack contains top-level dashboards, these will automatically appear in the navigation bar, usually in a folder called 'Community Dashboards' for dashboard packs from the SquaredUp Community. If the dashboard pack also contains perspectives (see Working with perspectives), then you'll see these when you drilldown to the relevant object.
 - Carry out any additional steps required to make the dashboard work in your environment. These steps will be described on the download page for each dashboard. For example, you may need to create the correctly named Web API provider, create a PowerShell profile, or edit tile collections.
 - Add your Uptime Robot API key to the tiles.
For the tiles to work with your Uptime Robot environment, you need to add your API key to each tile.- Edit the tiles by clicking the Edit button.
 - Open the headers & data panel.
 - Enter your Uptime Robot API key in the data field in the following format:
 Publish the dashboard.
