LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packssqlfacts
SQLFacts
This dashboard shows data from custom tables there were created using the SQLFacts utility. The SQLFacts utility must be configured and running before importing the SQLFacts dashboard for data to appear.
    Try it for free
  2. Download and import this dashboard pack.
  3. Within SquaredUp DS create a new SQL provider called SQLFacts that points to the database where you installed SQLFacts.
    1. Make sure you have access to the database you want to use.
      Access to the SCOM Data Warehouse
      Access to the SCOM Data Warehouse is configured during the SquaredUp DS setup process. If you are able to see graphs in SquaredUp DS, SQL queries have access to the SCOM Data Warehouse (see How to check and reconfigure the Data Warehouse connection).
      Access to other databases
      To be able to query other databases, such as the Operations Manager database, the SquaredUp DS application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
    2. Provider name:
    3. Driver and Connection String:
      If you want to connect to the SCOM Data Warehouse:
      Tip: SquaredUp DS already comes with a default SQL provider that connects to your Data Warehouse, so you don't need to create a provider for this connection. In case you deleted this provider, you can always recreate it with the following connection string:
      global:dw
      If you want to connect to the Operations Manager database:
      Server=<SQLservername>;Database=<OperationsManagerDatabaseName>;Integrated Security=True;
      Tip: If the Operations Manager database is on the same server as the Data Warehouse you can use the Data Warehouse provider in your tiles, but you need to remember in the Query panel that you have to put the following in front of the query:
      USE <OperationsManagerDatabaseName>;
      If you want to connect to any other data base:
      With integrated security:
      Server=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;
      With username and password:
      Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
      Server=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;
      Example:
      Server=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;
      If you want to specify a port
      Server=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;
      Example:
      Server=SQLServer1,51433;Database=CRMDB;Integrated Security=True;
      Note: You need to use 64-bit ODBC drivers.
      If you are using an ODBC driver
      After you've set up your ODBC driver in Windows on the SquaredUp server, add the following at to your connection string:
      Driver=<Name of your ODBC driver>;
      Example:
      Driver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
      If you are using a System DSN
      DSN=<DSNname>
    4. Click save to save your new provider.
  4. Publish the dashboard.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
