Kubernetes Monitoring dashboard (with Prometheus)
This dashboard visualizes the performance of a Kubernetes cluster by getting metrics from Prometheus using PromQL in the Web API and PowerShell tiles.
- Basic cluster information displayed in a grid
- Network traffic sent and received for the cluster
- CPU, memory and disk utilization for the cluster
- CPU, memory and disk used by each node in the cluster
The tiles on this dashboard automatically adjust the queries to Prometheus based of the page time frame being selected. The Rate and Step variables are handled in the PowerShell profile and can be amended as required.
- Create a Web API provider to connect with Prometheus.
Use the following settings:In SquaredUp browse to System > Administration > Integrations.
- Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using. Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
- Complete the provider fields, using your API provider's online documentation as a guide.
- You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
- Create a PowerShell profile in SquaredUp DS with the following settings:
# Set the end point of the Prometheus API endpoint $uri = "https://<your-prometheus-url>/api/v1/query_range" # Changes step and rate values based on the timeframe of the page. switch ($timeFrame) { "last1Hour" { $step = '60'; $timeago = -1; $rate = '2m' } "last12Hours" { $step = '600'; $timeago = -12; $rate = '30m' } "last24Hours" { $step = '900'; $timeago = -24; $rate = '1h' } "last7Days" { $step = '1200'; $timeago = -168; $rate = '6h' } "last30Days" { $step = '1800'; $timeago = -720; $rate = '1d' } "last3Months" { $step = '7200'; $timeago = -2160; $rate = '1d' } "last6Months" { $step = '10800'; $timeago = -4320; $rate = '7d' } "last12Months" { $step = '21600'; $timeago = -8640; $rate = '7d' } } # Get the page timeframe start and end $end = Get-Date -Date (Get-Date) -UFormat %s $start = Get-Date -Date ((Get-Date).AddHours($timeago)) -UFormat %s- Browse to System > Administration > PowerShell.
- Click add new profile.
- Enter the profile script.
- Click add profile.
- In DS for SCOM go System > Administration > Content > Community Packs and drag the zip file into the Manual Import box.
- The dashboard pack is imported and if the pack contains top-level dashboards, these will automatically appear in the navigation bar, usually in a folder called 'Community Dashboards' for dashboard packs from the SquaredUp Community. If the dashboard pack also contains perspectives (see Working with perspectives), then you'll see these when you drilldown to the relevant object.
- Carry out any additional steps required to make the dashboard work in your environment. These steps will be described on the download page for each dashboard. For example, you may need to create the correctly named Web API provider, create a PowerShell profile, or edit tile collections.
