SolarWinds Orion: Nodes and their health status
This dashboard shows data from SolarWinds Orion about nodes and their health status.
    Try it for free
  2. Create a Web API provider to connect with your SolarWinds environment.
    Use the following settings:
    Type
    Basic auth
    Name
    Solarwinds
    URL
    Enter the URL to the Solarwinds API in the following format:
    1. If your Solarwinds environment is installed on the same server as SquaredUp DS: https://localhost:17778/SolarWinds/InformationService/v3/Json/
    2. If your Solarwinds environment is installed on a different server:
      https://server.domain.name:17778/SolarWinds/InformationService/v3/Json/
    Username and password
    Enter the credentials for your SolarWinds environment.
    1. In SquaredUp browse to System > Administration > Integrations.
    2. Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using.
      Simple
      No authentication, basic authentication (username and password in a header) or Windows authentication (configured automatically to use the application pool identity account).
      Basic auth
      Basic authentication. Your specified username and password will be Base64 encoded automatically.
      OAuth
      Token-based authentication according to the OAuth 2.0 standard. Many APIs use OAuth 2.0 for authorization, and will require an OAuth provider to include the additional information about how to authorize against the service.
      Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
    3. Complete the provider fields, using your API provider's online documentation as a guide.
    4. You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
  3. Download and import this dashboard pack.
    2. In DS for SCOM go System > Administration > Content > Community Packs and drag the zip file into the Manual Import box.
  4. Change the row links to point to your SolarWinds environment.
    The Unhealthy Nodes and All Nodes tiles contain dynamic row links. To make the links work in your SolarWinds environment, you need to edit the link template in both tiles:
    1. Edit the tiles by clicking the Edit button.
    2. Open the grid options panel.
    3. Exchange the your-server part of the URL with the server name of your SolarWinds console.
      Dynamic links make use of dynamic properties which are inserted as part of the URL. This creates a template URL that will be resolved to an actual URL based on the item's properties.
      For example, to link to tickets in your ticketing system you can use the dynamic property that contains the ticket ID to create this template URL: https://www.my-system/ticket-{{ticketID}}
      Where the URL for tickets in your system is https://www.my-system/ticket-123 and 123 is the ticket ID.
      Dynamic links are also used with Dashboard Variables.
      Dashboard variables allow you to pass variables to another dashboard, so you can create your own drilldown dashboard to show further data detail. Dashboard variables are available for SolarWinds, Prometheus and VMware integrations (DS v7.1 and above).
  5. Publish the dashboard.
