Jira Health dashboard
This dashboard shows a quick view of the state of your next release and overall Jira project.
One of the main issues to overcome when returning a large number of items from Jira is that the API has a 100 issue limit. This is resolved here by using a PowerShell tile and making multiple API calls.
Release completion is calculated by total issues Closed or Merged, divided by the total issues in the release. This could be further fine tuned to only look at specific issue types that you care about by changing the API call in the script. Similarly on the Project side the Top 10 list (Web API) could be set to be any issue type by adjusting the API call. The trend line is calculated by creating an array.
- Create a Web API provider to connect with your Jira environment.
Use the following settings:In SquaredUp browse to System > Administration > Integrations.
- Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using. Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
- Complete the provider fields, using your API provider's online documentation as a guide.
- You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
- Create a PowerShell profile in SquaredUp DS with the following settings:
$user = "username" $pass = "password" $org = "https://<JIRA domain>.atlassian.net/rest/api/3/" $pair = "$($user):$($pass)" $encodedCreds = [System.Convert]::ToBase64String([System.Text.Encoding]::ASCII.GetBytes($pair)) $basicAuthValue = "Basic $encodedCreds" $Headers = @{ Authorization = $basicAuthValue }- Browse to System > Administration > PowerShell.
- Click add new profile.
- Enter the profile script.
- Click add profile.
- In DS for SCOM go System > Administration > Content > Community Packs and drag the zip file into the Manual Import box.
- The dashboard pack is imported and if the pack contains top-level dashboards, these will automatically appear in the navigation bar, usually in a folder called 'Community Dashboards' for dashboard packs from the SquaredUp Community. If the dashboard pack also contains perspectives (see Working with perspectives), then you'll see these when you drilldown to the relevant object.
- Carry out any additional steps required to make the dashboard work in your environment. These steps will be described on the download page for each dashboard. For example, you may need to create the correctly named Web API provider, create a PowerShell profile, or edit tile collections.
