SQL Samples
This dashboard demonstrates how the same base SQL query could be used with each of SquaredUp DS's visualizations. Each SQL visualization slightly modifies how the data from the OperationsManagerDW database is presented to target user requirements. For example, a Status Block to quickly show health or a spark line to show how something has changed over time. The same data source, seven different SQL visualizations!
- In DS for SCOM go System > Administration > Content > Community Packs and drag the zip file into the Manual Import box.
- The dashboard pack is imported and if the pack contains top-level dashboards, these will automatically appear in the navigation bar, usually in a folder called 'Community Dashboards' for dashboard packs from the SquaredUp Community. If the dashboard pack also contains perspectives (see Working with perspectives), then you'll see these when you drilldown to the relevant object.
- Carry out any additional steps required to make the dashboard work in your environment. These steps will be described on the download page for each dashboard. For example, you may need to create the correctly named Web API provider, create a PowerShell profile, or edit tile collections.
- Replace the connection string in each of the seven SQL tiles with the connection string to your own OperationsManagerDW database.
- Open the connection panel.
- Enter the connection string
global:dw.
Publish the dashboard.
