LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packssql page timeframe
SQL Page Timeframe
Sometimes, the hardest thing to deal with when designing a dashboard are date and time fields. When writing a SQL query, getting the date and time to format correctly can be a real pain. What is the current date and time, and how is it formatted? What happens if I want the date and time from 30 days ago? This SQL Page Timeframe dashboard demonstrates how the current date and time are displayed. Each tile on the dashboard does something different with the Date and Time, including an example how the page timeframe in SquaredUp DS impacts the date and time in a SQL query.
The page timeframe is the timeframe setting a dashboard or perspective is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have use page timeframe set will adapt to the new timeframe. (Tiles that do not have use page timeframe set (i.e. are set to specific timeframe or custom timeframe) are not affected and won't change.)
The custom option can be used to set timeframes using ISO 8601 format
    Try it for free
  2. Download and import this dashboard pack.
  3. Replace the connection string in each of the seven SQL tiles with the connection string to your own OperationsManagerDW database.
    Note: This dashboard requires a connection to SQL Server, but any database can be used. To make things simpler, the Master database was chosen, but the target database can be changed as needed.
    1. Edit the tiles by clicking the Edit button.
    2. Open the connection panel.
    3. Enter the connection string global:dw.
  4. Publish the dashboard.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
