LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packspagerduty
PagerDuty
This dashboard gives an overview of incidents and alerting from PagerDuty.
Resolved (Summary Donut)
Resolved incidents
Triggered, Acknowledged, Resolved (Scalar)
Insight into the current incidents of each priority
Incidents Over Time (Line Graph and Sparklines)
Time series showcasing incidents over a time span (customizable and can use page timeframe)
Recent Alerts (Grid)
List of recent alerts (customizable and can use page timeframe). Also displays which integration alert has been triggered from
The page timeframe is the timeframe setting a dashboard or perspective is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have use page timeframe set will adapt to the new timeframe. (Tiles that do not have use page timeframe set (i.e. are set to specific timeframe or custom timeframe) are not affected and won't change.)
The custom option can be used to set timeframes using ISO 8601 format
    Try it for free
  2. Create a Web API provider to connect with your PagerDuty environment.
    Use the following settings:
    Type
    Simple auth
    Name
    PagerDuty
    URL
    Enter the base url for the PagerDuty API, i.e. https://api.pagerduty.com/
    default headers
    Enter your PagerDuty API token in the following format:
    First box (name): authorization
    Second box (value): Token token=API token from PagerDuty
    1. In SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
    2. Under Integrations click Web API.
    3. Click the authentication type Simple
    4. In the service name box type in a suitable name, e.g. PagerDuty
    5. The base URL should be the current PagerDuty API URL, for example:
      https://api.PagerDuty.com/
    6. Under default headers click add
    7. Add the following information to the boxes as shown below:
      First box (name): authorization Second box (value): Token token=API token from PagerDuty
      Paste into the authorization value box in SquaredUp DS, prepended by Token token= as shown above.
    8. Click Save.
  3. Download and import this dashboard pack.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
