LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packsoctopus deploy
Octopus Deploy
This dashboard gives an overview of deployments and tasks from Octopus Deploy
Deployments (Donut)
High level view of all deployments
Tasks (Grid)
High level view of all tasks
    Try it for free
  2. Create a Web API provider to connect with your Octopus Deploy environment.
    Use the following settings:
    Type
    Simple auth
    Name
    OctopusDeploy
    URL
    Enter the base url for the Octopus API, i.e. https://octopus.company.com/api
    default headers
    Enter your Octopus Deploy API key in the following format:
    First box (name): x-Octopus-ApiKey
    Second box (value): Token ( i.e. API-LKASJDLKAJDLKASLDKJ)
    1. In SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
    2. Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using.
      Simple
      No authentication, basic authentication (username and password in a header) or Windows authentication (configured automatically to use the application pool identity account).
      Basic auth
      Basic authentication. Your specified username and password will be Base64 encoded automatically.
      OAuth
      Token-based authentication according to the OAuth 2.0 standard. Many APIs use OAuth 2.0 for authorization, and will require an OAuth provider to include the additional information about how to authorize against the service.
      Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
    3. Complete the provider fields, using your API provider's online documentation as a guide.
    4. You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
  3. Download and import this dashboard pack.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
