LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packsvm insights metrics
VM Insights Metrics
This dashboard uses Log Analytics tiles to display key metric data for Virtual Machines, regardless of where the servers are hosted. This dashboard focuses on insights about virtual machines, such as free disk space, CPU performance and security issues.
    Try it for free
  2. Create an Azure Log Analytics provider to connect to your Azure instance. Use the following settings:
    Name
    LogAnalytics
    For help creating an Azure Log Analytics provider see How to add an Azure Log Analytics provider
  3. Download and import this dashboard pack.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
