LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packssalesforce
Salesforce
This is a really simple dashboard showing how to use the Salesforce API to query for data using SOQL (Salesforce Object Query Language). It displays summed up accounts, contacts and opportunities using the SOQL count function.
    Try it for free
  2. A Salesforce Admin needs to create a new Connected App in Salesforce with the following settings:
    • "Enable OAuth Settings" - activated
    • A callback URL in the format
      https://your-squaredup-server-url/SquaredUp/ext-core-webapi/callback/SalesforceNote: The last part of the URL has to be Salesforce, because it needs to be identical with the name of the provider you're going to create for the tiles in this dashboard.
    • Granted OAuth scopes:
      • Manage user data via APIs (api)
      • Perform requests at any time (refresh_token, offline_access)
    • IP restrictions:
      Change the IP Relaxation setting to Relax IP restrictions in the Edit Policies area.
      Alternatively, you can whitelist the IP address for your SquaredUp server in the Profiles admin area.
  3. Create a Web API provider to connect to your Salesforce environment with the following settings:
    Type
    OAuth
    Name
    Salesforce
    Grant type
    Authorization code
    Base URL
    The base URL to your Salesforce environment in the format
    https://your-salesforce-org.my.salesforce.com/services/data/v52.0/
    Ignore invalid SSL
    Off
    Send authorization with query
    Off
    Authorization URL
    https://login.salesforce.com/services/oauth2/authorize
    Token URL
    https://login.salesforce.com/services/oauth2/token
    Client ID and secret
    The Consumer Key of the Connected App you're using for SquaredUp DS. You can find it in Salesforce, in the App Manager area of the Connected App.
    Note: When creating a new Connected App in Salesforce, it can take 20-30 minutes before the Consumer Key becomes active for API usage. This may cause the provider to fail to authorize. If this happens, wait 10 minutes and then click Perform Authorization again.
    Client secret
    The Consumer Secret of your Connected App you're using for SquaredUp DS. You can find it in Salesforce, in the App Manager area of the Connected App.
    Authorization scope
    api offline_access
    1. In SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
    2. Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using.
      Simple
      No authentication, basic authentication (username and password in a header) or Windows authentication (configured automatically to use the application pool identity account).
      Basic auth
      Basic authentication. Your specified username and password will be Base64 encoded automatically.
      OAuth
      Token-based authentication according to the OAuth 2.0 standard. Many APIs use OAuth 2.0 for authorization, and will require an OAuth provider to include the additional information about how to authorize against the service.
      Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
    3. Complete the provider fields, using your API provider's online documentation as a guide.
    4. You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
  4. Download and import this dashboard pack.
  5. Each tile has a Salesforce SOQL query in the Headers & Data panel. Change the query to a query that works for your Salesforce environment:
    1. Edit the tiles by clicking the Edit button.
    2. Open the Headers & Data panel.
    3. Paste your query in the Data section.
      Examples for generic queries you can use:
      SELECT Name FROM Account
      SELECT Name, Owner.Name FROM Account
      SELECT Count(Name) FROM Contacts
  6. Publish the dashboard.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
