LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packsm365
M365
This dashboard visualizes data produced by your organization’s M365 tenant so you can manage licenses, usage, capacity, and more. This dashboard will allow you to monitor key metrics for Microsoft 365 SharePoint, Exchange Online, and Teams so you can be proactive in assigning storage.
The dashboard connects to the Microsoft Graph API, which offers a broad set of functionalities for working with Azure. Microsoft 365 sits on top of Azure and can be managed via Graph API, too. The reports section of Graph API exposes usage insights of your M365 tenant and can be easily consumed and nicely presented.
SharePoint Site Number Growth
Monitors SharePoint Online and displays the site number growth as a line graph to manage storage.
SharePoint Site Top Storage Usage
A bar graph displaying top five sites by storage usage to see exactly which sites are using the most storage.
Top Visited Pages
Displays the top five most visited pages in SharePoint Online.
Exchange Online Mailbox Count
Monitors M365 Exchange Online and displays the mailbox count as a line graph showing both the total count and the number of active mailboxes.
Exchange Online Mail Traffic
Displays how much mail is sent and how much is received in a line graph.
Outlook Platforms
Monitors which platforms are used to access Outlook – Mac, Windows, mobile, and web. The Donut shows percentages of all the traffic.
Teams Top Members
Top 5 of Teams with most members.
Teams Top External Members
Top 5 of Teams with most external members.
Teams Activity by Type
Displays when and how often the Teams activities Calls, Meetings and Messages have been used.
    Try it for free
  2. Create an Microsoft Entra ID provider with settings as described in this blog article. Name this provider "AzureTest".
  3. Download and import this dashboard pack.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
