LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packspingdom dashboard
Pingdom dashboard
This dashboard gives an overview of Pingdom checks using PowerShell scripts against the Pingdom API
  • Monitor Health - Status block tile showcasing health and last response time
  • Monitor Status - Donut tile summarizing checks by status
  • Monitor by Type - Donut tile summarizing checks by check type
  • Monitor Last Response Time - Scalar tile values for single checks. Your chosen Pingdom check name should be added into the quotes in the tile script section: $checkName = '' for example $checkName = 'website'.
  • Last Response Time - Bar of all checks' last response time
  • Multiple Response Times - Line graph of two checks (easily adapted to include more than two checks) - Your chosen Pingdom check ID should be added into the quotes in the tile script section: $checkId1 = '' and $checkId2 = '' for example, $checkId1 = '1234567'.
  • Single Response Time - Line graph for single check -Your chosen Pingdom check ID should be added to the tile script section in the quotes: $checkId1 = ''for example, $checkId1 = '1234567'.
  • Monitors Detail - Full check output (some returned data hidden - use grid columns > show hidden columns in the tile to view all)
Pingdom check ID's and names are shown in the PowerShell grid tile titled Monitors Details at the bottom of the dashboard.
  1. Create a PowerShell profile in SquaredUp DS with the following settings:
    Name
    Pingdom
    Sets the Pingdom API endpoint, changes step and rate values based on the timeframe of the page, and gets the page timeframe start and end.
    Script
    Copy and paste the script below. Modify the PowerShell profile to replace ***TOKEN GOES HERE*** with your Pingdom API token without the asterix.
    $url = "https://api.pingdom.com/api/3.1/"
    $headers = @{
                authorization = "Bearer ***TOKEN GOES HERE***"
    1. From the top right hand menu ☰ click system.
    2. Go to the PowerShell tab.
    3. Click add new profile.
    4. Enter a name and a description for the new profile.
    5. Enter the profile script.
    6. Click add profile.
  1. Download and import this dashboard pack.
  2. Finally you need to edit the dashboard to enter the Pingdom check IDs and names for the checks you wish to display.
    Each tile that needs editing has a subheading showing what is needed.
    Copy the checks ID or name you want from the PowerShell grid tile titled Monitors Details at the bottom of the dashboard. If you prefer, then you can find the check IDs and names in Pingdom as described below.
    Browse to your Pingdom instance, and the check you are interested in.
    The <check id> is the number shown in the URL:
  3. Edit each tile and enter the required checks ID or name into the script section of the tile configuration.
    So it looks like this, but with your own check IDs:
  4. Click Apply Changes > Done.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
