LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packsau2mator
Au2mator
This dashboard uses SQL and PowerShell tiles to present performance and health counters for the au2mator- Self Service Portal and a Web API tile to directly open the Self Service Portal in a new tab.
It also contains a quick overview of automation engines, System Center Orchestrator and Azure Automation Runbook Health.
Total Requests (SQL tile - Donut)
Displays the actual state of all requests and their state.
Note: This tile uses the page timeframe in its SQL query.
Heavy Users (PowerShell tile - Donut)
Shows heavy users.
Since the au2mator DB only contains the SamAccountName, PowerShell is used to provide the DisplayName from Microsoft Entra ID.
Total Services (Scalar)
The number of au2mator Services.
Top 8 Service Usage (SQL tile - Donut)
The top 8 services by usage.
Start au2mator (Web API tile)
To start the au2mator – Self Service Portal in a new tab.
Runbooks Job Status (SQL tile - Donut)
Displays all Runbook Jobs which have the state of failed, warning, or success.
Note: This tile doesn't use the page timeframe in its SQL query.
Running Runbooks (SQL tile - Grid)
A list of all Running and Queued Runbook jobs.
Azure Automation (Azure Log Analytics tile - Donut)
Displays the Azure Automation Runbook Jobs state.
    Try it for free
  2. Create an Azure Log Analytics provider with the following settings:
    Name
    squaredup
    For detailed information see How to add an Azure Log Analytics provider
  3. Download and import this dashboard pack.
  4. Replace the connection string in the SQL tiles (Total Requests, Total Services, Top 8 Service Usage, Runbook Job Status, Running Runbooks) with the connection string to your own au2mator database.
    1. Edit the tiles by clicking the Edit button.
    2. Open the connection panel.
    3. Enter the connection string to your own au2mator database.
  5. Edit the script in the Heavy Users PowerShell tile to query data from your au2mator database.
    1. Edit the tile by clicking the Edit button.
    2. Open the script panel.
    3. Insert your au2mator database.
  6. Edit the Start au2mator Web API tile to connect to your au2mator Self Service Portal.
    2. Open the content panel.
    3. Insert the URL to your au2mator Self Service Portal.
  7. Publish the dashboard.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
