LogoDark mode logo
LogoDark mode logo
    • AdventureWorks
    • Au2mator
    • Azure DevOps Analytics
    • Jira Health dashboard
    • M365
    • Microsoft Teams
    • Octopus Deploy
    • PagerDuty
    • Pingdom dashboard
    • Salesforce
    • ServiceNow
    • SQLFacts
    • SQL Page Timeframe
    • SQL Samples
    • Team Presence
    • Teqwave
    • Uptime Robot
    • VM Insights Metrics
    • VM Updates
    • VMware: Status of VMs
    • Zendesk Support
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingdashboard packsadventureworks
AdventureWorks
Microsoft provides a sample database for various workload types like OLTP, Data Warehouse, and Lightweight workloads for each release of SQL Server. This sample database is called AdventureWorks. This dashboard shows data from the AdventureWorks database. There are ten tiles, and each tile pulls and formats data differently for each visualization.
Since each release of SQL Server results in a new version of AdventureWorks, you may need to make a few alterations to the data for visualization purposes. For example, the database doesn’t have any current data in some cases. The initial target for this dashboard was the AdventureWorks 2017 dataset. In several instances, the data for the tile was duplicated so that the graph appears continuous for visualization purposes.
    Try it for free
  2. Import the Microsoft AdventureWorks datasets from: https://docs.microsoft.com/en-us/sql/samples/adventureworks-install-configure?view=sql-server-ver15&tabs=ssms
  3. Download and import this dashboard pack.
  4. Replace the connection string in each of the ten SQL tiles with the connection string to your own OperationsManagerDW database.
    1. Edit the tiles by clicking the Edit button.
    2. Open the connection panel.
    3. Enter the connection string global:dw.
  5. Publish the dashboard.
Submit a ticket
On this page
  • Description
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
