SLA tile
Overview
The SLA tile displays gauges showing the availability of SCOM objects, such as servers or applications, based on your SCOM Monitor Service Level Objectives (SLOs).
How to configure an SLA tile
  1. Before the SLA tile can be used, you must have one or more Monitor SLOs created in your SCOM management group.
    1. Open the SCOM Operations Console.
    2. Go to Authoring workspace (Authoring tab on bottom left).
    3. Select Authoring > Management Pack Objects > Service Level Tracking in the left-hand tree view.
    4. Click Create in the right-hand task pane.
    5. On the General page, enter the following details and click Next:
      Name:Service AvailabilityDescription:<leave blank>
    6. On the Objects to Track page click Select... next to Targeted class
    7. Set the Search result filter dropdown to Distributed Application
    8. In the list, select Service (from System Library). Click OK
    9. Ensure the Scope is set to All objects of the targeted class
    10. Click the New button to create a new management pack, for example SlaTest
    11. On the Service Level Objectives page click Add > Monitor state SLO.
      SquaredUp DS does not support Collection Rule service level objectives.
    12. Enter the following details and click OKService level objective name:AvailabilityTargeted class:ServiceMonitor:AvailabilityService level objective goal:99.000Specify states:Critical is checked
      SquaredUp DS does not support unmonitored, and it should not be ticked.
    13. Click Next. On the Summary page, click Finish
  2. Add a new tile to a dashboard or perspective and choose the SLA tile.
  3. Scope:
    Tip: If you experience any problems with scoping tiles, you'll find FAQs and help in the article How to scope tiles.
    List
    List allows you to select one or more objects or groups.
    Tip: Start typing and after two characters you'll see suggestions that match the name appear.
    Group
    Group allows you to select members of a specific group. Only one group can be selected.
    Advanced
    Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
    Group:
    Class:
    Criteria:
    Objects you would like to see
    Criteria
    Objects with particular text in their name
    DisplayName like '%Server1%'
    Objects starting with a particular string
    DisplayName like 'test%'
    All objects in maintenance mode
    InMaintenanceMode = 'TRUE'
    Only healthy objects
    HealthState = 1
    Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark.
    HealthState = 0
    Objects that are not healthy
    HealthState != 1
    Objects in critical state
    HealthState = 3
    Objects in critical or warning state
    HealthState = 2 or HealthState = 3
    To show all gray uninitialised objects
    HealthState = 0 OR HealthState IS NULL
    All objects not in maintenance mode
    InMaintenanceMode != 'TRUE'
    Objects where the parent agent is offline
    IsAvailable='false'
    Objects that are offline, in maintenance or state unknown
    IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0
    Computers with a particular OS
    OSVersion = '6.3.9600'
    List objects by name and filter by HealthState
    List objects by SCOM Id and filter by HealthState
    Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3
    Exclude object from the Group specified
    DisplayName not like '%server3%'
    Exclude objects from the Group specified
    (DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')
    For more information see:
    SLA-specific examples:
    • To show the SLA of a group itself, use the list option and type in the name of your group.
    • To show the SLA of members of a group use the group option with your group name.
    General examples:
    What you want to select
    What to use as a scope
    All your Distributed Applications (DAs)
    In the advanced section, use a class of either service (system.service) or user created distributed application
    Only your Enterprise Applications (EAs)
    In the advanced section, use a class of Enterprise Application (Base)
    • the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
    • the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
    Suggestions
    A sibling of an object is any object of the same class that is hosted by the same parent.
    This object
    This / *
    Example:
    This / IIS Web Server / * selects all objects of any class in the level below This / IIS Web Server.
    Example:
    Parent class of object
    Sibling class of object
    1. For an EA you want to scope to the servers that are specified on the EA map by selecting something from the suggestions (SquaredUp DS 4.2 and above) that shows something similar to the following:
      The screenshot below shows some scope suggestions for an application called FinanceXS. The bold text shows the currently selected scope is This object. The cursor shows the option This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
    2. In the scope section click custom.
    3. Click on the text <YourApplicationName> Map (children) which is your first scope step. This will expand the scope step so you can edit it.
    4. Remove the auto-populated class <YourApplicationName> Map by clicking the cross x next to it.
    5. Start typing Enterprise Application - Map and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
    6. The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
    Custom
    1. At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
    2. Class:
    3. Criteria:
    2. Class:
    3. Criteria:
    Other specific objects
  4. SLO selection:
    Click on the drop down list and select the Monitor SLO from SCOM that you wish to use.
    The slo selection drop down only lists the Monitor SLOs from SCOM.
    SquaredUp DS does not support Collection Rule SLOs, or the unmonitored state which should not be ticked in the Monitor SLO configuration.
  5. Timeframe:
    This is the timeframe over which the SLA will be calculated. Hourly aggregated data will be used if it exists for the whole of the interval, if not then daily aggregated data is used.
    You can either choose a specific timeframe or allow the tile to adapt to the page timeframe.
    The page timeframe is the timeframe setting a dashboard or perspective is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have use page timeframe set will adapt to the new timeframe. (Tiles that do not have use page timeframe set (i.e. are set to specific timeframe or custom timeframe) are not affected and won't change.)
    The custom option can be used to set timeframes using ISO 8601 format
  6. Style:
    Here you can define how the SLA gauges are displayed.
    tile (large SLA gauge, more details, useful for a large impact wallboard):
    inline (smaller SLA gauge, list format to display more objects):
  7. Visualization:
    Allows you to remove the status icon, label or SLA gauge.
  8. Label:
    Allows you to change the label next to the status icon. You can also create a custom label (see How to use Custom Labels).
  9. Click done to save the tile.
Troubleshooting
If when displaying the status and SLA of groups themselves (adding groups to scope > list for example) one or more groups have missing SLA gauges and the health status is shown as gray with a question mark, this means that the group does not have a Dependency Roll Up Monitor.
See Groups show no health information.
SquaredUp DS pulls service level data from the Operations Manager Data Warehouse. To verify that the data shown in SquaredUp DS matches that shown in SCOM, you can run a Service Level Tracking Summary Report (see How to run a Service Level Tracking Summary Report in SCOM).
Both SquaredUp and SCOM Reporting pull data from the Data Warehouse, so any inconsistencies in figures are usually due to configuration differences.
  1. Check that both SquaredUp and the Service Level Tracking Summary Report are using the same SLO.
    In SquaredUp DS check the SLO selection section of the SLA tile configuration:
    The SLO is specified in the Service Level Tracking Summary Report:
  2. Check the configuration of the SLO (see How to check the configuration of a Service Level Objective in SCOM). Specifically, that Unmonitored is not ticked.
  3. Check that your SCOM report is using the same timeframe as SquaredUp DS.
    In SquaredUp DS if the tile timeframe is set to use page timeframe then the user can change the timeframe from the default of 12 hours using the buttons at the top of the page:
    If the tile timeframe is set to specific timeframe then if a user clicks the page level times at the top of the page, the timeframe will not change:
    Check that the timeframe in the SCOM report matches that being used in SquaredUp DS:
  4. Check that your SCOM report is using the same Data Aggregation as SquaredUp DS for the timeframe.
    Data Aggregation setting in the SCOM report:
    SquaredUp DS uses hourly data by default as long as it is available for the whole reporting timeframe, otherwise it uses daily data. Whether hourly data is available for the whole timeframe will depend on your Data Warehouse data retention settings (see How to optimise the Data Warehouse - 5 Point Plan). For a timeframe of 12 or 24 hours it will probably be using hourly data aggregation, for timeframes over 2 days (i.e. 7 days, 30 days, 3 months, 6 months, 12 months) SquaredUp will be probably be using daily data.
  5. If you are using an Availability report (see How to create an Availability Report in SCOM) check that the downtime state options match those specified in the SLO. See How to check the configuration of a Service Level Objective in SCOM. Run a Service Level Tracking Summary Report on the SLO (see How to run a Service Level Tracking Summary Report in SCOM).
  6. Change to an SLO that is working on another dashboard
  7. On the SCOM server restart the System Center Data Access Service.
