LogoDark mode logo
LogoDark mode logo
    • Management Packs (MPs)
    • Exploring the sample Enterprise Applications
    • How to create an Enterprise Application
    • Enterprise Applications - How to configure an availability test
    • How to edit Enterprise Application rollups
    • How to manually set the health state of an application
    • Enterprise Applications - How to map an Enterprise Application using VADA
    • Enterprise Applications - Dependencies
    • How to create Availability Test Groups for use with Enterprise Applications
    • How to delete an Enterprise Application
  • Auditing
customizingenterprise applicationshow to delete an enterprise application
When an Enterprise Application is saved in SquaredUp DS, a new Management Pack is created and saved into SCOM.
To delete the Enterprise Application, you will need to delete the Management Pack from SCOM:
  1. Navigate to the SCOM console and click on Administration.
  2. Navigate to Installed Management Packs.
  3. From the list of Management Packs, select the one you wish to delete and click Delete from the list Actions on the right-hand panel.
Submit a ticket
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
