How to add links to an external ticketing system from Alerts
Using this setting allows you to turn the ticket field on a SquaredUp DS Alert drilldown into a link to a ticket in your external service desk or ticketing system. This is useful if you have a separate ticketing/service desk system that has a web interface.
Procedure
The ticket hyperlink is configured through a setting stored in scom.json.
On the Windows Server where SquaredUp DS is installed:
- Run notepad as administrator (File, Run, type
notepad, and then right-click and select Run as administrator) and then open the following file:C:\inetpub\wwwroot\SquaredUpv[version number]\User\Configuration\scom.json - Add the following line and replace with the desired template. You may not need the id= depending on your particular service desk URLs.
{{ticketId}}is automatically replaced with the value of the ticket ID field in the Alert."ticket-template": "http://my-ticketing-system/id={{ticketId}}" - You may also need to add a comma at the end of the previous line, if there are multiple settings in the file.
Linking to an alert
Once the template URL is set up, any alerts with a ticket ID will display a link, and will be automatically hyperlinked in the Alert tile's TicketId column and the alert donut / heatmap drilldowns.
To manually update an alert's ticket ID:
- Drill down into any alert within SquaredUp DS.
- Select the ticket button near the top right of the page.
- Enter the desired ticket ID.
- Click update.
You'll now see the ticket ID displayed alongside the alert name. Clicking this tag will open a new window to your external ticketing system / service desk.
Variables
Using the curly brace syntax, e.g. {{variable}} you can include different variables in the URL template. In the example above we used {{ticketId}}.
- classId
- customField1
- customField2
- customField3
- customField4
- customField5
- customField6
- customField7
- customField8
- customField9
- customField10
- description
- id
- isMonitorAlert
- lastModified
- lastModifiedBy
- monitoringObjectDisplayName
- monitoringObjectId
- monitoringObjectPath
- name
- owner
- priority
- problemId
- repeatCount
- resolutionState
- resolutionStateName
- resolvedBy
- ruleId
- severity
- ticketId
- timeRaised
- timeResolved
- type
