How to create an Enterprise Application
With SquaredUp DS for SCOM we have defined a new type of SCOM object called an Enterprise Application (EA). Enterprise Applications are like regular SCOM Distributed Applications (DAs), but improved, to give you an easy way to model and monitor all of your applications from the point of view of your users.
To create an Enterprise Application (EA) click the + button on the Getting Started dashboard, or from Applications > Enterprise Applications, or click the Create new application button from system > EAM.
First, give your application a name. You can then configure availability tests, map the components or monitor external dependencies. Even if you just use availability tests you can still build accurate application availability dashboards and SLAs. You can even create an EA that simply displays the manually set health status/availability of the application (see How to manually set the health state of an application).
This training video below (30 mins) takes you through configuring Enterprise Application availability monitoring:
1. Availability test
You can create a very basic EA with no availability test, just simply use Report Availability option to manually set the health state of the application.
Adding an availability test to the EA means that the health state will be automatically updated based on the availability test.
See Enterprise Applications - How to configure an availability test and Report availability (see How to manually set the health state of an application).
Note: If you save an empty EA (meaning you saved the EA before configuring any availability monitors under Availability), the overall health of the EA will be displayed as green (and not - as you might have expected - as gray, since the availability is unknown). The green (healthy) state of the EA is due to SCOM considering uninitialized objects as healthy.
2. Map
See Enterprise Applications - How to map an Enterprise Application using VADA
3. Dependencies
See Enterprise Applications - Dependencies.
Saving and viewing the EA
  1. Click save and check the Management Pack ID.
  2. Click save. This may take a few minutes as the Enterprise Application (EA) is saved into SCOM.
  3. Click the view dashboard button at the top right of the page. After first saving an EA you will need to wait a few minutes for SCOM to update before the dashboards show anything meaningful.
    From here you can:
  4. To return to editing the Enterprise Application click the edit app button.
For more information about creating your own dashboards to show Enterprise Applications see this training video (24 mins) Building Enterprise Application Dashboards.
FAQs
How do I delete an EA?
In SCOM go to the Administration workspace, then Management Packs > Installed Management Packs and locate or search for your EA, and then right click on it and select Delete.
Who can create, edit and delete EAs?
Only SCOM admins can manage Enterprise Applications.
Can I edit Enterprise Applications in SCOM?
You can update your EAs in SquaredUp DS at any time, or by editing the management pack XML and importing/re-importing. EAs are not editable in the SCOM Distributed Application (DA) Designer.
Why can't I save my EA?
The EAM library management pack must be installed in order to save EAs. See Management Packs (MPs).
Troubleshooting Enterprise Applications
Availability for an EA is not correct after the SCOM availability test group is changed
See Availability for an Enterprise Application is shown incorrectly after the 'test from' group is changed.
See A group renamed to EAM_ is not appearing in the test from drop down list.
Application mapping or VADA issues
