Surface tile
The Surface tile shows health state, performance metrics and other information on top of an image, such as a map.
How does the Surface tile work?
The Surface tile works by using a row perspective to show a row of data for each of the objects returned by the scope. (The Matrix tile also uses a row perspective to show data, but in a single table, see Matrix tile).
A row perspective can display health state, performance metrics, properties, and SLA information for each object.
They work in a similar way to dashboard perspectives in that they are stored in dashboard packs, they use a match criteria that defines which class, group or particular object they apply to, and they have a rank that specifies which row perspective should be displayed when multiple row perspectives match.
A row perspective is made up of 'cell tiles' of various types, such as Status, Sparkline, Bar, Health State History etc.
Objects shown on the Surface tile can use different row perspectives. (The Matrix tile uses the same row perspective for all the objects returned by the scope).
The Surface tile supports a maximum of 25 objects per tile, so only the first 25 objects of a scope are shown. Use the list or advanced scoping options to configure the scope to show the 25 objects you need.
Can I change what information is shown?
You can change the row perspective used by each individual object, and you can untick any cell tiles you don't want to show.
Can I create new row perspectives?
When cell tiles are unticked, the data is still returned, but it is hidden from view. To make the tile more efficient or for more customization you can create a new row perspective: How to create and modify row perspectives.
How to configure a Surface tile
  1. Add a new tile to a dashboard or perspective and choose the Surface tile.
  2. Image
    Tip: If you want a different selection of maps, you can download more at https://freevectormaps.com/
    Supported image formats: png, jpg, jpeg, gif, tif, tiff. svg, bmp
    Tip: SVG images resize best since they are vector images.
    File size limit: 10MB
  3. Scope:
    Configure the scope to define the objects you want to show, Scoped objects will appear straight away and can be dragged into position.
    The Surface tile supports multiple objects types. The Surface tile can show a different row perspective for each objects (whereas the Matrix tile can only display rows of data for objects of the same type with a common row perspective). The row perspective used by each object can be changed, see Display information below.
    Tip: If you experience any problems with scoping tiles, you'll find FAQs and help in the article How to scope tiles.
    List
    List allows you to select one or more objects or groups.
    Tip: Start typing and after two characters you'll see suggestions that match the name appear.
    Group
    Group allows you to select members of a specific group. Only one group can be selected.
    Advanced
    Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
    Group:
    Class:
    Criteria:
    Objects you would like to see
    Criteria
    Objects with particular text in their name
    DisplayName like '%Server1%'
    Objects starting with a particular string
    DisplayName like 'test%'
    All objects in maintenance mode
    InMaintenanceMode = 'TRUE'
    Only healthy objects
    HealthState = 1
    Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark.
    HealthState = 0
    Objects that are not healthy
    HealthState != 1
    Objects in critical state
    HealthState = 3
    Objects in critical or warning state
    HealthState = 2 or HealthState = 3
    To show all gray uninitialised objects
    HealthState = 0 OR HealthState IS NULL
    All objects not in maintenance mode
    InMaintenanceMode != 'TRUE'
    Objects where the parent agent is offline
    IsAvailable='false'
    Objects that are offline, in maintenance or state unknown
    IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0
    Computers with a particular OS
    OSVersion = '6.3.9600'
    List objects by name and filter by HealthState
    List objects by SCOM Id and filter by HealthState
    Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3
    Exclude object from the Group specified
    DisplayName not like '%server3%'
    Exclude objects from the Group specified
    (DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')
    For more information see:
    • the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
    • the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
    Suggestions
    A sibling of an object is any object of the same class that is hosted by the same parent.
    This object
    This / *
    Example:
    This / IIS Web Server / * selects all objects of any class in the level below This / IIS Web Server.
    Example:
    Parent class of object
    Sibling class of object
    1. For an EA you want to scope to the servers that are specified on the EA map by selecting something from the suggestions (SquaredUp DS 4.2 and above) that shows something similar to the following:
      The screenshot below shows some scope suggestions for an application called FinanceXS. The bold text shows the currently selected scope is This object. The cursor shows the option This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
    2. In the scope section click custom.
    3. Click on the text <YourApplicationName> Map (children) which is your first scope step. This will expand the scope step so you can edit it.
    4. Remove the auto-populated class <YourApplicationName> Map by clicking the cross x next to it.
    5. Start typing Enterprise Application - Map and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
    6. The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
    Custom
    1. At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
    2. Class:
    3. Criteria:
    2. Class:
    3. Criteria:
    Other specific objects
  4. Display
    Once the objects appear on the image you can drag them into location, and customize the way the panels look.
    Hide metrics - tick boxes allow you to hide/show individual metrics.
    Change row perspective - the drop down arrow at the bottom of the panel allows you to change the row perspective being used. The drop down list shows all the row perspectives that match the individual object, and you can choose a different row perspective to see different metrics. For more information about creating new row perspectives see How to create and modify row perspectives.
    Show preview - allows you to view the tile without the editing controls, so you can see what it will look like in normal use.
    Settings in the tile display panel:
    Object size
    Change size of the panels. From the initial size set, the panels will scale with the image, as the tile or dashboard size changes.
    Object opacity
    Change how transparent the panels are.
    Label
    Change how the metric labels are shown in relation to the metric graph.
    Hide object name
    Tick this option if you wish to remove the object name, if for example it's already shown on the image.
    Collapse mode
    The metrics from the row perspective are hidden by default. Clicking on the object name (if shown) reveals the metrics, therefore clicking on the object name to drilldown is disabled.
  5. Click done to save the tile.
