ServiceNow provider
An EAM-X edition license is required for this feature. To upgrade please contact [email protected]
About ServiceNow providers
A ServiceNow provider is a dedicated provider that contains the connection details to your ServiceNow instance. You need to create a ServiceNow provider before you can use ServiceNow tiles.
What are Integrations and Providers
Requirements for ServiceNow providers
  • SquaredUp DS 4.4 or above.
  • The SquaredUp server must have access to your ServiceNow instance on port 443 (HTTPS), since it is the server that connects to ServiceNow, and not your users' browser.
  • If you use a proxy server you may need to configure the proxy. See How to configure SquaredUp DS to use a proxy.
  • A ServiceNow account. It depends on the roles of the ServiceNow account you use for the ServiceNow provider what functions are available in the ServiceNow tile.
The permissions of the ServiceNow account you are using for your ServiceNow provider affect what you can see and do in the ServiceNow tile.
We recommend using a service account, which means you create an account specifically to use with the ServiceNow provider. You have different options for setting up this service account:
  • ServiceNow permissions assignment with roles
    Give the ServiceNow account the ITIL and rest_api_explorer roles.
  • ServiceNow permissions assignment with ACLs, in place of roles
    If you don't want to use the ITIL role (for licensing or security reasons) give the ServiceNow account only the rest_api_explorer role and use ACLs to give the account more rights. This will limit the functionality of the ServiceNow tile. Using accounts without the ITIL role may cause data streams to error.
    When you are using an account without the roles specified in this article, then the functionality of the ServiceNow tile is limited:
    • You'll see an error if you used a scope for your tile
    • In the View dropdown, only the non-admin default view is available (contains a default set of columns)
    • Under Filter, default filters are not available, only user-created ones are visible
    You can grant the specific permissions required more granularly by creating a custom role and assigning the specific ACLs or assigning the ACLs themselves directly to a user account:
    • Adding them directly to a user account, meaning you are adding the ACLs to the service account you are using for the ServiceNow provider.
    • Adding them to a role. We recommend that you create a new role specifically just for adding the ACLs to it. Then you need to assign the role to the service account you are using for the ServiceNow provider.
      A benefit of adding the ACLs to a role is that it makes them easier to manage and you can assign the role to different users (in this case, service accounts) if you want to use different service accounts for different instances of the ServiceNow providers.
    sys_filter
    sys_dictionary.*
    sys_dictionary
    sys_db_object
    sys_ui_list
    sys_db_object.*
    sys_ui_list.*
    • The tile can be scoped
    • Under Filter, all default filters are visible
    • The ACLs don't affect the views. The View dropdown still shows only the non-admin default view. You need to use an admin Service account to see all the views.
Where can I use ServiceNow providers?
The ServiceNow provider can be used with either the dedicated ServiceNow tile or the Web API tile (when you are using the Web API tile for ServiceNow). See How to use the ServiceNow tile and How to use the Web API tile
The ServiceNow tile is available in SquaredUp DS v4.4 and above, and offers easier configuration than the Web API tile. You can display incidents and change requests with the ServiceNow tile. If you want to use any other data from ServiceNow, you need to use the Web API tile.
Adding a ServiceNow provider
  1. In SquaredUp browse to System > Administration > Integrations.
  2. Under Integrations click on ServiceNow and type in a suitable name, e.g. ServiceNow.
  3. instance url:
    The instance URL should look something like
    https://instancename.service-now.com/api/now/ where instancename is your instance. If /api/now/ is not included as part of the instance URL then it will be automatically appended to this URL when the provider is created. If ServiceNow is installed on-premises, this may be something different.
    Note: This URL is prepended to every request URL.
  4. client id and secret:
    To get a client ID and secret from ServiceNow, you need to create an OAuth API endpoint for external clients in your ServiceNow account.
    Note: If you already are using ServiceNow in SquaredUp DS, you can re-use the client ID and secret you previously created. In this case, you can skip this step.
    1. In your ServiceNow account in the Application Navigator (left-hand menu) go to System OAuth and click Application Registry.
    2. Click Create an OAuth API endpoint for external clients.
    3. Give it an easy to remember name like SquaredUp DS and leave the other default settings as they are.
    4. Once you've created the endpoint, open the entry to view the client ID and client secret. Click the padlock next to the client secret to see it.
    5. Copy client ID and client secret into a notepad for use later.
  5. username and password of the ServiceNow account you want to use.
      sys_filter
      sys_dictionary.*
      sys_dictionary
      sys_db_object
      sys_ui_list
      sys_db_object.*
      sys_ui_list.*
  6. Click Save.
If the provider is not authorized it could be that some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
Download the ServiceNow Dashboard Pack
The ServiceNow Dashboard Pack will give you key dashboards to get started.
