SQL provider
About SQL providers
An SQL provider contains the connection string to the SQL database you want to connect to. You can use Microsoft SQL Server or ODBC drivers for your connection.
What are Integrations and Providers
You need an SQL provider to use the SQL tile. Your Data Warehouse is available as a provider by default, but if you want to use any other connection you'll need to create a provider.
Note
If you created SQL tiles before SquaredUp DS version 5.4, they were created with a connection string in the tile instead of a provider.
Adding an SQL provider
  1. Make sure you have access to the database you want to use.
    Access to the SCOM Data Warehouse
    Access to the SCOM Data Warehouse is configured during the SquaredUp DS setup process. If you are able to see graphs in SquaredUp DS, SQL queries have access to the SCOM Data Warehouse (see How to check and reconfigure the Data Warehouse connection).
    Access to other databases
    To be able to query other databases, such as the Operations Manager database, the SquaredUp DS application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
  2. Provider name:
  3. Driver and Connection String:
    If you want to connect to the SCOM Data Warehouse:
    Tip: SquaredUp DS already comes with a default SQL provider that connects to your Data Warehouse, so you don't need to create a provider for this connection. In case you deleted this provider, you can always recreate it with the following connection string:
    global:dw
    If you want to connect to the Operations Manager database:
    Server=<SQLservername>;Database=<OperationsManagerDatabaseName>;Integrated Security=True;
    Tip: If the Operations Manager database is on the same server as the Data Warehouse you can use the Data Warehouse provider in your tiles, but you need to remember in the Query panel that you have to put the following in front of the query:
    USE <OperationsManagerDatabaseName>;
    If you want to connect to any other data base:
    With integrated security:
    Server=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;
    With username and password:
    Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
    Server=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;
    Example:
    Server=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;
    If you want to specify a port
    Server=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;
    Example:
    Server=SQLServer1,51433;Database=CRMDB;Integrated Security=True;
    Note: You need to use 64-bit ODBC drivers.
    If you are using an ODBC driver
    After you've set up your ODBC driver in Windows on the SquaredUp server, add the following at to your connection string:
    Driver=<Name of your ODBC driver>;
    Example:
    Driver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
    If you are using a System DSN
    DSN=<DSNname>
  4. Click save to save your new provider.
To use the SQL provider in a tile see How to use the SQL tile
