If you don't already have a SolarWinds provider, you need to create one before you can configure a SolarWinds tile (How to add a SolarWinds provider).
Add a new tile to a dashboard and click on Integrations > SolarWinds.
Select the visualization for your SolarWinds tile and click next.
A Scalar displays one value. A Scalar is useful to show a specific number like "total cost of my services" or "free disk space on this server". When multiple values are returned (meaning a table with multiple rows), you will still be able to pick the Scalar visualization, but the Scalar will only show the value of the first row.
Example:
Did you know? Users can search the grid, and temporarily change the column size and sorting of the grid (by clicking on the column headers) without having to access the settings. They can also expand a row by clicking on the three dots at the end of each row if cells are too small to show their entire content.
Shows time-series data over time, in a graph with an x-axis (time) and a y-axis. You can show several objects, such as servers, in one graph.
Example:
Visualizes time-series data as vertical columns.
Example:
Shows data over time (like line graphs), but each item gets its own graph instead of showing all lines in one graph.
Example:
Visualizes both a number and the resulting bar width based on the number value.
Example:
Click either a section of the donut or the donut legend to display a drilldown page for the corresponding objects.
Example:
Similar to a donut, but using less dashboard space, the Ribbon visualization shows the data as a portion of the full bar.
Shows the state of items as icons with different colors. You can display just the icons or together with a description, or drag the images into position on top of a map or other image.
Example:
Shows the state of items as blocks with different colors.
Example:
The Date Heatmap shows the number of events per hour of the day. It uses lighter colors to show higher values and darker for lower values.
Scope: Select the scope for your tile (optional).
List
List allows you to select one or more objects or groups.
Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Group
Group allows you to select members of a specific group. Only one group can be selected.
Advanced
Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
Group:
Class:
Criteria:
Objects you would like to see
Criteria
Objects with particular text in their name
DisplayName like '%Server1%'
Objects starting with a particular string
DisplayName like 'test%'
All objects in maintenance mode
InMaintenanceMode = 'TRUE'
Only healthy objects
HealthState = 1
Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark.
HealthState = 0
Objects that are not healthy
HealthState != 1
Objects in critical state
HealthState = 3
Objects in critical or warning state
HealthState = 2 or HealthState = 3
To show all gray uninitialised objects
HealthState = 0 OR HealthState IS NULL
All objects not in maintenance mode
InMaintenanceMode != 'TRUE'
Objects where the parent agent is offline
IsAvailable='false'
Objects that are offline, in maintenance or state unknown
IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0
Computers with a particular OS
OSVersion = '6.3.9600'
List objects by name and filter by HealthState
List objects by SCOM Id and filter by HealthState
Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3
Exclude object from the Group specified
DisplayName not like '%server3%'
Exclude objects from the Group specified
(DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')
the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
Suggestions
Double-check the scope when using suggestions: Using suggestions is an easy way to pick a scope, but you need to make sure that the generated suggestion is appropriate for all objects that use the perspective. For example, when you pick a suggestion for an EA, you will get suggestions that are specific to the map, dependencies, and availability tests for this one EA. On perspectives you want to use for all EAs, you have to change the scope suggestion in the custom section so that the tile work for all EAs.
A parent of an object is any object that hosts or contains that object. A child of an object is any object that this object hosts or contains. A sibling of an object is any object of the same class that is hosted by the same parent.
This object
This / *
Example: This / IIS Web Server / * selects all objects of any class in the level below This / IIS Web Server.
Example:
Parent class of object
Sibling class of object
For an EA you want to scope to the servers that are specified on the EA map by selecting something from the suggestions (SquaredUp DS 4.2 and above) that shows something similar to the following: This /<YourApplicationName> Map / ... / Windows Computer The above will scope the tile to all the objects of class Windows Computer on this EAs map. The screenshot below shows some scope suggestions for an application called FinanceXS. The bold text shows the currently selected scope is This object. The cursor shows the option This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
In the scope section click custom.
Click on the text <YourApplicationName> Map (children) which is your first scope step. This will expand the scope step so you can edit it.
Remove the auto-populated class <YourApplicationName> Map by clicking the cross x next to it.
Start typing Enterprise Application - Map and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
Custom
At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
Class: Here you pick the class of the objects you want to select. If you leave this field empty, the scope falls back to the "this object" scope. Note: You will only see groups and classes that the object you are currently looking at is a member of. Tip: If you want to pick objects of any class, enter the SCOM base class logical entity in the class field. Tip: If you want to find out what classes the object you are interested in belongs to, you can go to the Monitored Entity perspective of that object. You'll see all the classes the object belongs to listed there.
Criteria: You can narrow the selection of objects of a particular class down further by entering criteria for those objects. For more help see How to use criteria when scoping objects. Tip: If you want to find out what properties you can base your criteria on, you can go to the Monitored Entity perspective of the object you are interested in. You'll see all the properties for criteria listed there.
Other specific objects
Gives you the normal, non-dynamic scope options you are used to when scoping tiles on dashboards. This means the tile will dynamically adapt its content to the currently viewed object, it will always show data for the static object picked here. dynamically adapt it's content to the currently viewed object, it will always show data for the static object picked here.
Which status is displayed depends on what you choose as a scope:
If you want to see the status of individual objects (for example, two individual servers), select multiple objects in the list section.
If you want to see the status of a group itself rather than the individual objects within the group, select a group in the list section.
If you want to see the status of each individual group member of a group, select a group in the group section.
If you want to see the health state of all groups, select the class "group" in the advanced section.
Provider: Select your SolarWinds provider from the select provider drop-down and click next.
You can only use providers of the same type as the tile. Providers of other types won't be shown in the select provider drop-down.
Query: Enter your SolarWinds query using the SolarWinds Query Language (SWQL).
If you defined a scope you can use the mustache picker
to insert scope variables (values that refer only to the defined scope) into your query.
Values that refer to the defined scope carry the prefix scope. before the value. For example, you can use the value {{scope[0].displayName}} for the name of the first item in your scope. You can manipulate the values with javascript syntax. For example, if you want to insert a quoted comma separated list of displayNames from every item in the scope, you can use {{scope.map(item => '"'+item.displayName+'"').join(',')}}.
You can use the clock insert time value button
to insert page timeframe and date variables in your query.
Avoid using a page timeframe shorter than the time span in the query, as this may not show any results.
The Page Timeframe is the timeframe setting a dashboard or perspective is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have Use Page Timeframe set will adapt to the new timeframe. (Tiles that do not have Use Page Timeframe set (i.e. are set to Specific Timeframe or Custom Timeframe) are not affected and won't change.)
The Custom option can be used to set timeframes using ISO 8601 format
Note
If you don't use page timeframe variables, the tile will ignore the page timeframe setting by a user.
Available dynamic page timeframe variables
timeframe.isoDuration
Use this format when you want to insert the page timeframe according to the ISO 8601 format
Example: When the page timeframe is set to "last 12 hours" the string PT12H is inserted.
timeframe.isoStart
Use this format to insert a "from" time when you want the starting point to be "now minus page timeframe". The page timeframe will be inserted as a starting time according to the ISO 8601 format
timeframe.isoEnd
Use this format to insert a "to" time when you need to specify the end time. The end time is always "now". The current time will be inserted according to the ISO 8601 format
timeframe.unixStart
Use this format to insert a "from" time when you want the starting point to be "now minus page timeframe". The page timeframe will be inserted as a starting time in milliseconds according to the UNIX standard.
timeframe.unixEnd
Use this format to insert a "to" time when you need to specify the end time. The end time is always "now". The current time will be inserted in milliseconds according to the Unix standard.
Math.floor(timeframe.UnixStart / 1000)
Use this format when you want to use the unixStart time but need to convert it from milliseconds to seconds.
Math.floor(timeframe.UnixEnd / 1000)
Use this format when you want to use the unixEnd time but need to convert it from milliseconds to seconds.
Available fixed date variables
Date.now() - 86400 * 1000 *14
This is a template format to express the fixed timeframe "14 days ago" (now minus 14 days in milliseconds). You can use this template to create your own fixed timeframe.
Date.now() = the current date and time (now) in milliseconds 86400 = 24 hours in seconds 1000 = converts the seconds into milliseconds 14 = 14 days
If you want to use a fixed timeframe in seconds, you need to convert the Date.now() into seconds, for example "4 days ago in seconds": (Date.now() /1000) - 86400 * 4.
new Date().toISOString()
A text based representation of "now". Use this format if you want to insert the date as a string in ISO 8601 format
Configure the settings for the visualization you chose:
Scalar
Font size
Allows you to set the font size of the value in the tile.
Alignment
Select the scalar text alignment. Choose from left, center or right.
Unit
Allows you to add a unit to the value displayed in the Scalar tile. For example, if your value shows a time in milliseconds, you can enter "ms" or if your value shows pageviews, you can enter "pageviews".
Value Formatter
Value formatter:
Allows you to format the value, using the mustache picker, and the modified values will be shown on the axis and hover values. For example, you can round the value up or down or convert it.
Color
Conditional formatting:
You can display the data in different colors based on values you define here. For example, you can display the data in green when the value is below 100 and in red when it is above 100.
Enter your condition in the field next to the color. You can use the value property and manipulate it with JavaScript String and Regex APIs. When you click on the mustache picker, you'll get some examples:
Value is greater than something, less than something, etc. For example: {{value < 10}} (The color you pick will be used if the value is less than 10)
Value is present in the result (scalar tiles only) For example: value.IndexOf('error') != -1 (The color you pick will be used if the string value "error" is present in the results)
Value matches one of the regular expressions you defined (scalar tiles only) For example: value.match(/healthy|good|up/) (The color you picked will be used if the string values are healthy, good, or up)
Display:
Tile background
Highlight the tile in the color you defined.
Text foreground
Display the text in the color you defined.
Link options
Item Link:
Allows you to turn returned item(s) into links. You can either enter plain text to create a fixed link (URL always stays the same) or use dynamic properties to create a dynamic link.
There is also a tick option to open the link in a new tab.
For scalars, you can only use the dynamic property value in dynamic links, which means the link changes when the value of the scalar changes. As a scalar is just one item, it would also make sense to use a fixed link, for example the link to the website of which you are displaying the response time.
VMware VMs: https://<your-instance>/ui/app/vm;nav=v/urn:vmomi:{{type}}:{{id}}:<your-vm-GUID>/summary For step-by-step details and URLs for Virtual Machines, Hosts, Clusters, and Datacenters see Row links for VMware Grid tiles
Dynamic links make use of dynamic properties which are inserted as part of the URL. This creates a template URL that will be resolved to an actual URL based on the item's properties.
For example, to link to tickets in your ticketing system you can use the dynamic property that contains the ticket ID to create this template URL: https://www.my-system/ticket-{{ticketID}} Where the URL for tickets in your system is https://www.my-system/ticket-123 and 123 is the ticket ID.
Dashboard variables allow you to pass variables to another dashboard, so you can create your own drilldown dashboard to show further data detail. Dashboard variables are available for SolarWinds, Prometheus and VMware integrations (DS v7.1 and above).
Grid columns
If you have access to the data source and can change the name of the property, change the name of the property to a name without hyphens. For example, if your Elasticsearch query uses a property (an aggregation, a grouping or any other property you want to use) with a name that contains a hyphen, you can either access your Elasticsearch instance and change the name there or you can overwrite the name in the query dsl field.
If you can't change the name of the property, you need to enter the property name in the following format: Original property name: {{properties.name-with-hyphens.value}} New format: {{properties['name-with-hyphens'].value}}
Grid options
Row link
Item Link:
Show column headers
You can choose between showing or hiding the header for all columns.
Expand rows automatically
Activate this checkbox if you want the row height to expand automatically based on the row content, for example if your grid uses increased text size, images, emojis etc.
Limit number of results displayed
You can set a limit of the initial number of results displayed in the grid. If you have set a limit and there are more results to display, users will see a "show all" button below the grid.
Font size
Use the slider to adjust the font size.
Tip for column sizing: You can change the column width directly in the grid by clicking on the divider lines between columns and dragging them to the width you want. You need to show column headers (by activating the show column headers check box) to be able to change the column width. Resizing columns while in edit mode affects how the grid looks by default when users open the dashboard. Users can temporarily change the column sizes by dragging them, but those changes only last until they leave the page.
Data mapping
grouping
To enter your grouping, you have to find the property that contains it. You can use the mustache picker to see every property returned from the response data. Pick the property that contains the grouping you want your graph to show.
Note: If you type in the property, make sure you add the mustache {{}} to the property name. Otherwise, you'll either get an error message or the property will be interpreted as a static value and be the same for every result.
Note: If your grouping needs more than one property, you can combine multiple properties. For example, if you want to see the disk space on the c: drive of different computers, your grouping needs to be c: drive and computer. You can combine them in one mustache {{PropertyForComputer + PropertyForC:Drive}} or keep them in separate mustaches {{PropertyForComputer} {PropertyForC:Drive}}.
timestamp
Here you define the time series to be used for the visualization.
To enter your timestamp, you have to find the property that contains it. If there is a mustache picker you can use this to see every property from the response data. Pick the property that contains the timestamp you want the visualization to use.
Note: Timestamps that are supported are Unix timestamp in milliseconds or the ISO 8601 format
metrics
To enter your metric value, you have to find the property that contains that value. You can use the mustache picker to see every property returned from the response data. Pick the property that contains the value you want your graph to show
Note: The metric value must be a numeric object. If an API returns values as strings, you can convert them from a string to a numeric object with the parseFloat() function.
Info: You can manipulate the value by adding operators to add, substract, divide or multiply. You can pick additonal properties from the response data or insert plain text for those functions. For example, if you want to multiply two properties you can do that by entering {{PropertyForMetricValue*PropertyForOtherMetricValue2}} . If you want to change Kb in Gb you can divide the value by 1024: {{PropertyForMetricValue/1024}}. You can also use more elaborate functions according to JavaScript syntax.
Extract multiple metrics:
For some tiles, if you want to see more than one value, you can tick the "Extract multiple metrics". You can manipulate those metrics exactly like the first metric you chose. The metrics won't affect each other, they are all treated as separate metrics. Each value will get its own series (a line in a line graph, a bar in a bar graph etc.).
Threshold
You can choose to apply a threshold line at a specified value, and whether you wish to fill above or below this value, or just show the line. For example, for free disk space you might want to fill below the line to highlight when space goes below a particular threshold. For processor information you might want to fill above the line to highlight when processor percentage goes above that threshold. The threshold is also shown on the drilldown view.
Max, min, avg
When drilled-down to view a graph, you can select the min, max and avg options for each object (displayed to the right of the graph), which displays a line cutting horizontally across the graph at each of the selected value points.
Data range
percentage
Shows 0 to 100
fit to data
Shows the data minimum to data maximum
fit to data (from zero)
Shows from 0 to the data maximum
custom
Allows you to specify the min and max
custom fit
Allows you to specify the min and max limits, so that data outside your settings will not be shown. If all the data falls within your specified ranges then the y-axis range will fit to the data rather than your caps.
Display
Height:
Allows you to set the height of the tile with a slider.
Show hover details:
Shows the value for all lines at any point you hover. There may not be a value exactly where you hover so the value is interpolated from the values either side.
Show points:
Shows where the data points are on the line. Useful to identify missing points, or detail for changing data.
Show trend
Enable the Show Trend Linestoggle to display a trend line for the line graph data. Disable the toggle to hide the trend line.
Custom colors:
You can display the data in different colors based on labels. For example, you can display data in green for a specific user.
Enter your condition in the field next to the color. You can use the label property and manipulate it with JavaScript String and Regex APIs. When you click on the mustache picker, you'll get some examples:
Condition is true if the label contains something For example: {{label.indexOf('SQL') != -1}} (The color you pick will be used if the label contains 'SQL')
Condition is true if the label contains multiple things For example: {{label.match(/C:|D:|E:/) != null}} (The color you pick will be used if the label contains 'C:', 'D:' or 'E:')
Condition is true if the label contains multiple things with multiple variations For example: {{label.match(/^[Ss]erver[0-9]+$/) != null}} (The color you pick will be used if the label is 'Server' or 'server' with a number after it)
Label
Show legend
Sort legend
Allows you to sort the legend entries is ascending or descending order.
Label:
auto
Choose this option if you want to use the default label that has been created automatically.
custom
Value Formatter
Value formatter:
Link options
Item Link:
Data mapping
grouping
timestamp
metrics
Threshold
Data range
percentage
Shows 0 to 100
fit to data
custom
custom fit
Display
Height:
Show hover details:
Solid bars:
Show the bars as solid color or translucent.
Custom colors:
Label
Show legend
Sort legend
Label:
auto
custom
Value Formatter
Value formatter:
Link options
Item Link:
Data mapping
grouping
timestamp
metrics
Data Range
percentage
Shows 0 to 100
fit to data
custom
custom fit
Sort
Value
Value Formatter
Value formatter:
Label
auto
custom
Color
multiple colors
If you turn color matching on, one item (a specific resource, object, site, anything you are displaying in your graphs) is shown in the same color in different graphs on one dashboard or one perspective. You can use either color matching or custom colors (colors based on values), they cannot both be used at the same time.
custom colors
Setting colors based on values
Note
You are able to combine value matching with label matching.
Setting colors based on labels
Note
You are able to combine label matching with value matching.
Link options
Item Link:
Data mapping
grouping
timestamp
metrics
Data Range
percentage
Shows 0 to 100
fit to data
custom
custom fit
Sort
Value
Value formatter
Value formatter:
Label
auto
custom
Display
Vertical:
Tick this option to show vertical bars, otherwise horizontal bars are shown.
Bar width:
Allows you to set the width of the bars with a slider.
Color
multiple colors
custom colors
Note
Note
Link options
Item Link:
Data mapping
grouping
timestamp
metrics
Sort
Value formatter
Value formatter:
Display
Size mode:
Default
Displays the donut scaled to the height of the tile.
Fill
Enlarges the donut to use the whole width of the tile. If you chose the fill option and show the legend, you can define the size of the legend with a slider.
Legend:
Show legend
Table or Inline:
Show the legend as a separate table or as labels pointing to the segments. When using Inline you can also hide the segment values, and use the slider to change the size of the labels.
Show zero values in legend:
Will show legend items for values of zero which are otherwise missing from the donut.
Fixed height scrollable legend:
Sets the legend to a fixed height where you can scroll through the items. This means that the tile doesn't become too large if there are many items.
Display mode:
Color palette:
General
10 different colors without specific meaning
Priorities
5 different colors representing 5 different priority states
Health1
3 different colors representing 3 different health states (red=unhealthy, green=healthy, gray=unknown)
Health2
4 different colors representing 4 different health states (red=critical, orange=unhealthy, green=healthy, gray=unknown)
Pastel
10 different pastel colors without specific meaning
Blue
4 different shades of blue from dark to light
Orange
4 different shades of orange from dark to light
Green
4 different shades of green from dark to light
Pink
4 different shades of pink from dark to light
Custom
Note
Note
Link options
Item Link:
Separator:
Separator used when concatenating property values from multiple objects. Defaults to “,”.
Sort
Value
Value formatter:
Display
Height:
Move the slider to set the height of the ribbon.
Labels:
Select the tick box to show labels and values on the ribbon, or unselect to rely on hover text.
Display mode:
Color palette:
General
Priorities
Health1
Health2
Pastel
Blue
Orange
Green
Pink
Custom
Note
Note
Link options
Item Link:
Separator:
Label
name
custom
Sublabel
custom
none
By default, no sublabels are shown.
Sort
default
By default, the sorting of objects depends on the data source. This can be alphabetical sorting or the order in which data comes back from an API request.
sort by
Sort by label, health state, or health state + availability where objects are sorted by availability (offline or maintenance mode) as well as health state. Ascending or descending
group by
Group by label, health state, or health state + availability where objects are Grouped by availability (offline or maintenance mode) as well as health state, for example Error (Available) and Error (Unavailable). Ascending or descending
Limit:
Allows you to define a maximum number of objects that will be shown. When 'group by' is used the limit applies to each group individually, for example to show 10 objects in each health state.
Here you can choose one of the provided images or upload your own. Tip: If you want a different selection of maps, you can download more at https://freevectormaps.com/
Supported image formats: png, jpg, jpeg, gif, tif, tiff. svg, bmp Tip: SVG images resize best since they are vector images.
File size limit: 10MB
Icons
One long list
Column list
Icons only
Link options
Item Link:
Label
name
custom
Sublabel
custom
none
Sort
default
sort by
group by
Limit:
Blocks
Link options
Item Link:
Data mapping
Data aggregation
You can optionally choose the sum aggregation which uses the field you enter in the value box to sum up events for dates.
Timestamp
Display
Choose to use squares or circles, and optionally whether to hide weekends, week days and/or empty days.
Color
Here you can choose the color scheme for your heatmap. Higher values are shown in a lighter shade of the color, and lower values in darker shades.
Data Range
percentage
Shows 0 to 100
fit to data
custom
custom fit
Link options
Item Link:
Separator:
Click done to save the tile. The tile now shows data according to your search.
