Prometheus tile
An EAM-X edition license is required for this feature. To upgrade please contact [email protected]
About Prometheus tiles
Prometheus tiles offer you an easy way to display data from your Prometheus instance in a SquaredUp DS dashboard.
How to configure a Prometheus tile
If you don't already have a Prometheus provider, you need to create one before you can configure a Prometheus tile (How to add a Prometheus provider).
  1. Add a new tile to a dashboard and click on Integrations > Prometheus.
  2. Select the visualization for your Prometheus tile and click next.
    A Scalar displays one value. A Scalar is useful to show a specific number like "total cost of my services" or "free disk space on this server".
    When multiple values are returned (meaning a table with multiple rows), you will still be able to pick the Scalar visualization, but the Scalar will only show the value of the first row.
    Example:
    Did you know? Users can search the grid, and temporarily change the column size and sorting of the grid (by clicking on the column headers) without having to access the settings. They can also expand a row by clicking on the three dots at the end of each row if cells are too small to show their entire content.
    Shows time-series data over time, in a graph with an x-axis (time) and a y-axis. You can show several objects, such as servers, in one graph.
    Example:
    Visualizes time-series data as vertical columns.
    Example:
    Shows data over time (like line graphs), but each item gets its own graph instead of showing all lines in one graph.
    Example:
    Visualizes both a number and the resulting bar width based on the number value.
    Example:
    Click either a section of the donut or the donut legend to display a drilldown page for the corresponding objects.
    Example:
    Similar to a donut, but using less dashboard space, the Ribbon visualization shows the data as a portion of the full bar.
    The Date Heatmap shows the number of events per hour of the day. It uses lighter colors to show higher values and darker for lower values.
  3. Scope:
    Select the scope for your tile (optional).
    Tip: If you experience any problems with scoping tiles, you'll find FAQs and help in the article How to scope tiles.
    List
    List allows you to select one or more objects or groups.
    Tip: Start typing and after two characters you'll see suggestions that match the name appear.
    Group
    Group allows you to select members of a specific group. Only one group can be selected.
    Advanced
    Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
    Group:
    Class:
    Criteria:
    Objects you would like to see
    Criteria
    Objects with particular text in their name
    DisplayName like '%Server1%'
    Objects starting with a particular string
    DisplayName like 'test%'
    All objects in maintenance mode
    InMaintenanceMode = 'TRUE'
    Only healthy objects
    HealthState = 1
    Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark.
    HealthState = 0
    Objects that are not healthy
    HealthState != 1
    Objects in critical state
    HealthState = 3
    Objects in critical or warning state
    HealthState = 2 or HealthState = 3
    To show all gray uninitialised objects
    HealthState = 0 OR HealthState IS NULL
    All objects not in maintenance mode
    InMaintenanceMode != 'TRUE'
    Objects where the parent agent is offline
    IsAvailable='false'
    Objects that are offline, in maintenance or state unknown
    IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0
    Computers with a particular OS
    OSVersion = '6.3.9600'
    List objects by name and filter by HealthState
    List objects by SCOM Id and filter by HealthState
    Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3
    Exclude object from the Group specified
    DisplayName not like '%server3%'
    Exclude objects from the Group specified
    (DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')
    For more information see:
    • the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
    • the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
    Suggestions
    A sibling of an object is any object of the same class that is hosted by the same parent.
    This object
    This / *
    Example:
    This / IIS Web Server / * selects all objects of any class in the level below This / IIS Web Server.
    Example:
    Parent class of object
    Sibling class of object
    1. For an EA you want to scope to the servers that are specified on the EA map by selecting something from the suggestions (SquaredUp DS 4.2 and above) that shows something similar to the following:
      The screenshot below shows some scope suggestions for an application called FinanceXS. The bold text shows the currently selected scope is This object. The cursor shows the option This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
    2. In the scope section click custom.
    3. Click on the text <YourApplicationName> Map (children) which is your first scope step. This will expand the scope step so you can edit it.
    4. Remove the auto-populated class <YourApplicationName> Map by clicking the cross x next to it.
    5. Start typing Enterprise Application - Map and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
    6. The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
    Custom
    1. At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
    2. Class:
    3. Criteria:
    2. Class:
    3. Criteria:
    Other specific objects
    Gives you the normal, non-dynamic scope options you are used to when scoping tiles on dashboards. This means the tile will dynamically adapt its content to the currently viewed object, it will always show data for the static object picked here. dynamically adapt it's content to the currently viewed object, it will always show data for the static object picked here.
    Which status is displayed depends on what you choose as a scope:
    • If you want to see the status of individual objects (for example, two individual servers), select multiple objects in the list section.
    • If you want to see the status of a group itself rather than the individual objects within the group, select a group in the list section.
    • If you want to see the status of each individual group member of a group, select a group in the group section.
    • If you want to see the health state of all groups, select the class "group" in the advanced section.
  4. Provider:
    Select your Prometheus provider from the select provider drop-down and click next.
    You can only use providers of the same type as the tile. Providers of other types won't be shown in the select provider drop-down.
  5. Query:
    Enter your Prometheus query using the Prometheus Query Language (PromQL).
    Data step
    An appropriate data step size (similar to a data interval or resolution) is set automatically based on the time period. This is so Prometheus doesn't have to return huge numbers of data points. The data step can be increased or decreased as required, and Prometheus interpolates the likely value(s) for the steps between the actual data points.
    Insert dynamic value
    If you defined a scope you can use the mustache picker
    to insert scope variables (values that refer only to the defined scope) into your query.
    Values that refer to the defined scope carry the prefix scope. before the value. For example, you can use the value {{scope[0].displayName}} for the name of the first item in your scope. You can manipulate the values with javascript syntax. For example, if you want to insert a quoted comma separated list of displayNames from every item in the scope, you can use {{scope.map(item => '"'+item.displayName+'"').join(',')}}.
    Insert time value
    You can use the clock insert time value button
    to insert page timeframe and date variables in your query.
    Avoid using a page timeframe shorter than the time span in the query, as this may not show any results.
    The Page Timeframe is the timeframe setting a dashboard or perspective is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have Use Page Timeframe set will adapt to the new timeframe. (Tiles that do not have Use Page Timeframe set (i.e. are set to Specific Timeframe or Custom Timeframe) are not affected and won't change.)
    The Custom option can be used to set timeframes using ISO 8601 format
    Note
    If you don't use page timeframe variables, the tile will ignore the page timeframe setting by a user.
    Available dynamic page timeframe variables
    timeframe.isoDuration
    Use this format when you want to insert the page timeframe according to the ISO 8601 format
    Example: When the page timeframe is set to "last 12 hours" the string PT12H is inserted.
    timeframe.isoStart
    Use this format to insert a "from" time when you want the starting point to be "now minus page timeframe". The page timeframe will be inserted as a starting time according to the ISO 8601 format
    timeframe.isoEnd
    Use this format to insert a "to" time when you need to specify the end time. The end time is always "now". The current time will be inserted according to the ISO 8601 format
    timeframe.unixStart
    Use this format to insert a "from" time when you want the starting point to be "now minus page timeframe". The page timeframe will be inserted as a starting time in milliseconds according to the UNIX standard.
    timeframe.unixEnd
    Use this format to insert a "to" time when you need to specify the end time. The end time is always "now". The current time will be inserted in milliseconds according to the Unix standard.
    Math.floor(timeframe.UnixStart / 1000)
    Use this format when you want to use the unixStart time but need to convert it from milliseconds to seconds.
    Math.floor(timeframe.UnixEnd / 1000)
    Use this format when you want to use the unixEnd time but need to convert it from milliseconds to seconds.
    Available fixed date variables
    Date.now() - 86400 * 1000 *14
    This is a template format to express the fixed timeframe "14 days ago" (now minus 14 days in milliseconds). You can use this template to create your own fixed timeframe.
    Date.now() = the current date and time (now) in milliseconds
    86400 = 24 hours in seconds
    1000 = converts the seconds into milliseconds
    14 = 14 days
    If you want to use a fixed timeframe in seconds, you need to convert the Date.now() into seconds, for example "4 days ago in seconds": (Date.now() /1000) - 86400 * 4.
    new Date().toISOString()
    A text based representation of "now". Use this format if you want to insert the date as a string in ISO 8601 format
    Time (Scalar visualizations only)
    Default - the scalar value shown will be the last value.
    Specific time - the scalar value shown will be that for the time selected.
    Timeframe
    Note
    The insert time value button inserts time values into the query. Any settings selected from the timeframe section are also applied to further filter down the results of the query. So time settings from both the query and the timeframe affect the results shown, and should be used with care or you may not see all the data you were expecting.
    The Timeframe section allows you to determine the timeframe for the data. You can choose either to use:
    Use Page Timeframe
    Note
    Specific Timeframe
    Choosing a Specific Timeframe allow you to set a fixed timeframe such as Last 1 hour or Last 7 days. You can use the available timeframes button to list the timeframes you can pick.
    These timeframes are all relative to the current time, for example 7 days ago until now. Using this setting means that any change the user makes to the page timeframe is ignored.
    Note
    Custom Timeframe
    This allows you to set a fixed timeframe window from the time and calendar picker. This sets a completely customizable timeframe window, not relative to now.
  6. Visualization settings
    Configure the settings for the visualization you chose:
    Scalar
    Font size
    Allows you to set the font size of the value in the tile.
    Alignment
    Select the scalar text alignment. Choose from left, center or right.
    Unit
    Allows you to add a unit to the value displayed in the Scalar tile. For example, if your value shows a time in milliseconds, you can enter "ms" or if your value shows pageviews, you can enter "pageviews".
    Value Formatter
    Value formatter:
    Allows you to format the value, using the mustache picker, and the modified values will be shown on the axis and hover values. For example, you can round the value up or down or convert it.
    Color
    Conditional formatting:
    You can display the data in different colors based on values you define here. For example, you can display the data in green when the value is below 100 and in red when it is above 100.
    1. Click on add to configure a condition.
    2. Click on select color.... to open the color picker. Select the color for this condition.
    3. Enter your condition in the field next to the color. You can use the value property and manipulate it with JavaScript String and Regex APIs. When you click on the mustache picker, you'll get some examples:
      • Value is greater than something, less than something, etc.
        For example: {{value < 10}} (The color you pick will be used if the value is less than 10)
      • Value is present in the result (scalar tiles only)
        For example: value.IndexOf('error') != -1 (The color you pick will be used if the string value "error" is present in the results)
      • Value matches one of the regular expressions you defined (scalar tiles only)
        For example: value.match(/healthy|good|up/) (The color you picked will be used if the string values are healthy, good, or up)
    Display:
    Tile background
    Highlight the tile in the color you defined.
    Text foreground
    Display the text in the color you defined.
    Link options
    Item Link:
    Allows you to turn returned item(s) into links. You can either enter plain text to create a fixed link (URL always stays the same) or use dynamic properties to create a dynamic link.
    There is also a tick option to open the link in a new tab.
    For scalars, you can only use the dynamic property value in dynamic links, which means the link changes when the value of the scalar changes. As a scalar is just one item, it would also make sense to use a fixed link, for example the link to the website of which you are displaying the response time.
    VMware VMs:
    https://<your-instance>/ui/app/vm;nav=v/urn:vmomi:{{type}}:{{id}}:<your-vm-GUID>/summary
    For step-by-step details and URLs for Virtual Machines, Hosts, Clusters, and Datacenters see Row links for VMware Grid tiles
    ServiceNow incidents:https://<your-instance>.service-now.com/nav_to.do?uri=%2Fincident.do%3Fsys_id%3D{{sys_id}}
    PagerDuty incidents:{{incident.html_url}}
    Azure DevOps projects:https://dev.azure.com/<your-instance>/{{name}}
    Azure DevOps builds:https://dev.azure.com/<your-instance>/_build/results?buildId={{id}}
    Zendesk tickets:https://<your-instance>.zendesk.com/agent/tickets/{{id}}
    Azure Application Insightshttps://portal.azure.com/#@squaredup.net/resource/{{ResourceId}}
    Dynamic links make use of dynamic properties which are inserted as part of the URL. This creates a template URL that will be resolved to an actual URL based on the item's properties.
    For example, to link to tickets in your ticketing system you can use the dynamic property that contains the ticket ID to create this template URL: https://www.my-system/ticket-{{ticketID}}
    Where the URL for tickets in your system is https://www.my-system/ticket-123 and 123 is the ticket ID.
    Dynamic links are also used with Dashboard Variables.
    Dashboard variables allow you to pass variables to another dashboard, so you can create your own drilldown dashboard to show further data detail. Dashboard variables are available for SolarWinds, Prometheus and VMware integrations (DS v7.1 and above).
    Grid columns
    How to use the Grid Designer
    Property names that contain hyphens (for example properties.name-with-hyphens) can't be processed due to a JavaScript limitation. If you want to use a property that contains a hyphen, you have two options:
    1. If you have access to the data source and can change the name of the property, change the name of the property to a name without hyphens.
    2. If you can't change the name of the property, you need to enter the property name in the following format:
      Original property name:
      New format:
    Grid options
    Row link
    Item Link:
    VMware VMs:
      New format:
    Show column headers
    You can choose between showing or hiding the header for all columns.
    Expand rows automatically
    Activate this checkbox if you want the row height to expand automatically based on the row content, for example if your grid uses increased text size, images, emojis etc.
    Limit number of results displayed
    You can set a limit of the initial number of results displayed in the grid. If you have set a limit and there are more results to display, users will see a "show all" button below the grid.
    Font size
    Use the slider to adjust the font size.
    Resizing columns while in edit mode affects how the grid looks by default when users open the dashboard. Users can temporarily change the column sizes by dragging them, but those changes only last until they leave the page.
    Threshold
    You can choose to apply a threshold line at a specified value, and whether you wish to fill above or below this value, or just show the line. For example, for free disk space you might want to fill below the line to highlight when space goes below a particular threshold. For processor information you might want to fill above the line to highlight when processor percentage goes above that threshold. The threshold is also shown on the drilldown view.
    Max, min, avg
    When drilled-down to view a graph, you can select the min, max and avg options for each object (displayed to the right of the graph), which displays a line cutting horizontally across the graph at each of the selected value points.
    Data range
    percentage
    Shows 0 to 100
    fit to data
    Shows the data minimum to data maximum
    fit to data (from zero)
    Shows from 0 to the data maximum
    custom
    Allows you to specify the min and max
    custom fit
    Allows you to specify the min and max limits, so that data outside your settings will not be shown. If all the data falls within your specified ranges then the y-axis range will fit to the data rather than your caps.
    Display
    Height:
    Allows you to set the height of the tile with a slider.
    Show hover details:
    Shows the value for all lines at any point you hover. There may not be a value exactly where you hover so the value is interpolated from the values either side.
    Show points:
    Shows where the data points are on the line. Useful to identify missing points, or detail for changing data.
    Show trend
    Enable the Show Trend Linestoggle to display a trend line for the line graph data. Disable the toggle to hide the trend line.
    Custom colors:
    You can display the data in different colors based on labels. For example, you can display data in green for a specific user.
    1. Click on select color.... to open the color picker. Select the color for this condition.
    2. Enter your condition in the field next to the color. You can use the label property and manipulate it with JavaScript String and Regex APIs. When you click on the mustache picker, you'll get some examples:
      • Condition is true if the label contains something
        For example: {{label.indexOf('SQL') != -1}} (The color you pick will be used if the label contains 'SQL')
      • Condition is true if the label contains multiple things
        For example: {{label.match(/C:|D:|E:/) != null}} (The color you pick will be used if the label contains 'C:', 'D:' or 'E:')
      • Condition is true if the label contains multiple things with multiple variations
        For example: {{label.match(/^[Ss]erver[0-9]+$/) != null}} (The color you pick will be used if the label is 'Server' or 'server' with a number after it)
    Label
    Show legend
    Sort legend
    Allows you to sort the legend entries is ascending or descending order.
    Label:
    auto
    Choose this option if you want to use the default label that has been created automatically.
    custom
    Here you can change the label to a custom label. You can use static text and dynamic properties. Use the mustache picker
    See How to use Custom Labels
      New format:
    Value Formatter
    Value formatter:
    Link options
    Item Link:
    VMware VMs:
    Threshold
    Data range
    percentage
    Shows 0 to 100
    fit to data
    custom
    custom fit
    Display
    Height:
    Show hover details:
    Solid bars:
    Show the bars as solid color or translucent.
    Custom colors:
    Label
    Show legend
    Sort legend
    Label:
    auto
    custom
      New format:
    Value Formatter
    Value formatter:
    Link options
    Item Link:
    VMware VMs:
    Data Range
    percentage
    Shows 0 to 100
    fit to data
    custom
    custom fit
    Sort
    Value
    Value Formatter
    Value formatter:
    Label
    auto
    custom
      New format:
    Color
    multiple colors
    Note
    If you turn color matching on, one item (a specific resource, object, site, anything you are displaying in your graphs) is shown in the same color in different graphs on one dashboard or one perspective. You can use either color matching or custom colors (colors based on values), they cannot both be used at the same time.
    custom colors
    Setting colors based on values
    Note
    You are able to combine value matching with label matching.
    Setting colors based on labels
    Note
    You are able to combine label matching with value matching.
    Link options
    Item Link:
    VMware VMs:
    Data Range
    percentage
    Shows 0 to 100
    fit to data
    custom
    custom fit
    Sort
    Value
    Value formatter
    Value formatter:
    Label
    auto
    custom
      New format:
    Display
    Vertical:
    Tick this option to show vertical bars, otherwise horizontal bars are shown.
    Bar width:
    Allows you to set the width of the bars with a slider.
    Color
    multiple colors
    Note
    custom colors
    Note
    Note
    Link options
    Item Link:
    VMware VMs:
    Sort
    Value formatter
    Value formatter:
    Display
    Size mode:
    Default
    Displays the donut scaled to the height of the tile.
    Fill
    Enlarges the donut to use the whole width of the tile. If you chose the fill option and show the legend, you can define the size of the legend with a slider.
    Legend:
    Show legend
    Table or Inline:
    Show the legend as a separate table or as labels pointing to the segments. When using Inline you can also hide the segment values, and use the slider to change the size of the labels.
    Show zero values in legend:
    Will show legend items for values of zero which are otherwise missing from the donut.
    Fixed height scrollable legend:
    Sets the legend to a fixed height where you can scroll through the items. This means that the tile doesn't become too large if there are many items.
    Display mode:
    Color palette:
    General
    10 different colors without specific meaning
    Priorities
    5 different colors representing 5 different priority states
    Health1
    3 different colors representing 3 different health states
    (red=unhealthy, green=healthy, gray=unknown)
    Health2
    4 different colors representing 4 different health states
    (red=critical, orange=unhealthy, green=healthy, gray=unknown)
    Pastel
    10 different pastel colors without specific meaning
    Blue
    4 different shades of blue from dark to light
    Orange
    4 different shades of orange from dark to light
    Green
    4 different shades of green from dark to light
    Pink
    4 different shades of pink from dark to light
    Custom
    Note
    Note
    Link options
    Item Link:
    VMware VMs:
    Separator:
    Separator used when concatenating property values from multiple objects. Defaults to “,”.
    Sort
    Value
    Value formatter:
    Display
    Height:
    Move the slider to set the height of the ribbon.
    Labels:
    Select the tick box to show labels and values on the ribbon, or unselect to rely on hover text.
    Display mode:
    Color palette:
    General
    Priorities
    Health1
    Health2
    Pastel
    Blue
    Orange
    Green
    Pink
    Custom
    Note
    Note
    Link options
    Item Link:
    VMware VMs:
    Separator:
    Display
    Choose to use squares or circles, and optionally whether to hide weekends, week days and/or empty days.
    Color
    Here you can choose the color scheme for your heatmap. Higher values are shown in a lighter shade of the color, and lower values in darker shades.
    Data Range
    percentage
    Shows 0 to 100
    fit to data
    custom
    custom fit
    Link options
    Item Link:
    VMware VMs:
    Separator:
  7. Click done to save the tile.
    The tile now shows data according to your search.
