LogoDark mode logo
LogoDark mode logo
    • Alerts tile
    • Azure Application Insights tile
    • Azure Log Analytics tile
    • Elasticsearch tile
    • Image tile
    • Markdown tile
    • Monitors tile
    • Performance tile
    • PowerShell tile
    • Prometheus tile
    • SCOM Task tile
    • ServiceNow tile
    • SLA tile
    • SolarWinds tile
    • Splunk tile
    • SQL tile
    • SquaredUp Cloud tile
    • Status tile
    • Surface tile
    • Visio tile
    • Web API tile
    • Web API tile with Google APIs, such as Google Analytics
    • Web API tile with PagerDuty
    • Web API tile with Pingdom
    • Web API tile with ServiceNow
    • Web Content tile
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingtilesmonitors tile
Monitors tile
About the Monitors tile
The Monitors tile displays the health state of monitors that use the object in the scope as their target.
The Monitors tile can be used on a dashboard or a perspective
What are monitors?
Monitors are used in SCOM to determine health information and make sure items are working within predefined thresholds. When a threshold is hit the monitor can raise an alert, and the monitor can change the health state of an object. Rules can also raise alerts, but cannot change the health state of an object.
Users may not be aware of the differences between monitor and rule alerts, and that monitor alerts should not be closed. SquaredUp DS uses different alert icons for rule and monitor alerts to help users be more aware of these differences.
Monitor alerts
Monitor alerts are shown by a solid icon (like the health state icon, but round) to indicate that the alert is affecting the health state of the object, because the alert has been raised by a monitor.
A monitor alert is 'stateful' and therefore current. A monitor changes the state of the monitor, which then triggers an alert. This means that if the monitor alert is still visible, then it is still a current issue. Once action has been taken, a user can click the reset monitor button to force SCOM to reevaluate the health of the object, and if the issue is re-detected then the alert will be reopened. When the issue is resolved the alert will be closed automatically, so monitor alerts should not be closed manually.
When changing the resolution stateclosed is not the default option, and if a user tries to close a monitor alert a warning is shown and confirmation is required.
Monitor alerts are used to show Health state summaries for unhealthy objects in SquaredUp DS.
Rule alerts
A rule can trigger an alert, but not change the state of the object, or rollup to the parent. A rule alert shows that something has happened in the past, but it won't necessarily happen again. If the issue reoccurs, then the alert RepeatCount increases. Rule alerts should be closed manually when the issue has been resolved.
Rule alerts are shown by a hollow icon (that’s different from the health state icon) the alert is not affecting the health state of the object because it has been raised by a rule. Rule alerts should be closed manually by clicking the resolution state button.
Summary of the differences between rule and monitor alerts
Monitor alerts
Rule alerts
Stateful
Non-stateful
‘There is a problem’
‘There was a problem’
Affects health state of object
Does not affect health state of object
Rollup health to parent object
Does not rollup health to parent object
Changes health state of dashboard
Does not change health state of dashboard
Creates alert (normally)
Alert stays open while issue remains
RepeatCount incremented if issue reoccurs
Closes alert automatically (normally)
Does not close alert automatically
Can be manually reset back to healthy
Cannot be reset (no state)
Alerts should not be closed manually
Alerts should be closed manually
There are a three types of monitors in SCOM:
  • Unit monitors - measure something, such as how much free disk space there is on drive C:
  • Dependency rollup monitors - used for rolling up the health state of members to the group health state (see Groups show no health information).
  • Aggregate rollup monitors are not displayed by the Monitors tile.
Monitors states
Green
Healthy
Yellow
Warning
For example, a monitor might be configured so that when a disk goes below 10% free space the monitor goes yellow and an alert is raised.
Red
Critical
If the free space goes below 5% the monitor may be configured to go red, and a critical alert be raised.
Gray
Unknown/uninitialized
A gray circle shows that this monitor does not currently have a health state.
How to configure a Monitors tile
  1. Add a new tile to a dashboard or perspective and choose the Monitors tile.
  2. Choose the visualization for your Monitors tile:
    Shows monitor icons.
    The Blocks visualization is a simple way to build high impact dashboards, and is perfect for wall monitors or to grab attention.
  3. Scope:
    The Monitors tile will display monitors that target the class of object you use in the scope. You will need to specify the correct object in the scope in order to see the monitors you want. If the monitor you want is not shown, check the configuration of the monitor in SCOM, and look at the monitor target.
    The Monitors tile will only display Unit monitors and Dependency rollup monitors.
    If you want to display only one particular monitor, use the scope > list option and enter the name of one object, such as a server or database, then in monitors > filter type the name of the monitor to display.
    Tip: If you experience any problems with scoping tiles, you'll find FAQs and help in the article How to scope tiles.
    List
    List allows you to select one or more objects or groups.
    Tip: Start typing and after two characters you'll see suggestions that match the name appear.
    Group
    Group allows you to select members of a specific group. Only one group can be selected.
    Advanced
    Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
    Group:
    Class:
    Criteria:
    Objects you would like to see
    Criteria
    Objects with particular text in their name
    DisplayName like '%Server1%'
    Objects starting with a particular string
    DisplayName like 'test%'
    All objects in maintenance mode
    InMaintenanceMode = 'TRUE'
    Only healthy objects
    HealthState = 1
    Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark.
    HealthState = 0
    Objects that are not healthy
    HealthState != 1
    Objects in critical state
    HealthState = 3
    Objects in critical or warning state
    HealthState = 2 or HealthState = 3
    To show all gray uninitialised objects
    HealthState = 0 OR HealthState IS NULL
    All objects not in maintenance mode
    InMaintenanceMode != 'TRUE'
    Objects where the parent agent is offline
    IsAvailable='false'
    Objects that are offline, in maintenance or state unknown
    IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0
    Computers with a particular OS
    OSVersion = '6.3.9600'
    List objects by name and filter by HealthState
    List objects by SCOM Id and filter by HealthState
    Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3
    Exclude object from the Group specified
    DisplayName not like '%server3%'
    Exclude objects from the Group specified
    (DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')
    For more information see:
    • the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
    • the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
    Suggestions
    A sibling of an object is any object of the same class that is hosted by the same parent.
    This object
    This / *
    Example:
    This / IIS Web Server / * selects all objects of any class in the level below This / IIS Web Server.
    Example:
    Parent class of object
    Sibling class of object
    1. For an EA you want to scope to the servers that are specified on the EA map by selecting something from the suggestions (SquaredUp DS 4.2 and above) that shows something similar to the following:
      The screenshot below shows some scope suggestions for an application called FinanceXS. The bold text shows the currently selected scope is This object. The cursor shows the option This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
    2. In the scope section click custom.
    3. Click on the text <YourApplicationName> Map (children) which is your first scope step. This will expand the scope step so you can edit it.
    4. Remove the auto-populated class <YourApplicationName> Map by clicking the cross x next to it.
    5. Start typing Enterprise Application - Map and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
    6. The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
    Custom
    1. At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
    2. Class:
    3. Criteria:
    2. Class:
    3. Criteria:
    Other specific objects
    Which status is displayed depends on what you choose as a scope:
    • If you want to see the status of individual objects (for example, two individual servers), select multiple objects in the list section.
    • If you want to see the status of a group itself rather than the individual objects within the group, select a group in the list section.
    • If you want to see the status of each individual group member of a group, select a group in the group section.
    • If you want to see the health state of all groups, select the class "group" in the advanced section.
  4. Monitors:
    Here you can filter the monitors if you only want to display specific monitors. Start typing the name of the monitor you want to display in the choose monitors field to get suggestions for matching monitors.
  5. Filters:
    Here you can filter the monitors to specific health states. By default, all health states will be shown. Click on one of the health states to hide monitors with this state.
  6. Group
    Here you can change the default grouping, so instead of the monitors being grouped by object you may like to group them by monitor state. Or if grouping by object you may like to sort groups bymonitor state.
  7. Sort:
    Sort allows you to change the order of the results displayed. You can sort by label (ascending or descending) or health state (ascending from healthy to critical or descending from critical to healthy).
    Limit:
    Allows you to define a maximum number of objects that will be shown. When 'group by' is used the limit applies to each group individually, for example to show 10 objects in each health state.
  8. Only for Monitor Icons: You can change the way the icons are displayed by using the toggle zoom
    button at the top right of the tile. You can toggle between list, column and tile view.
  9. Only for Monitor Blocks: You can change the way blocks are displayed in the following panels:
    Blocks
    Here you can change how many columns are used to display the blocks, their height, and the font size of the labels on the blocks.
    Label
    none
    Use no label.
    name
    Use the monitor's name as the label.
    description
    Use the monitor's description as the label.
    custom
    Here you can change the label to a custom label. You can use static text and dynamic properties. Use the mustache picker
    Sublabel
    custom
    none
    By default, no sublabels are shown.
Walkthrough: Adding Monitors tiles to a dashboard
  1. In SquaredUp DS browse to an object whose monitor(s) you would like to add to a tile. For this walkthrough, search or browse for a database.
  2. Click on the Monitored Entity perspective to view the list of monitors available.
  3. In another tab (perhaps duplicate the tab) browse in SquaredUp DS to where you'd like the new dashboard to be created. Hover over the + button and click dashboard.
  4. Give the dashboard a title, by replacing the text that says New Dashboard.
    The dashboard is saved as you go along so there's no need to save your changes. You can find your dashboard by clicking on the right-hand menu ☰ > system > unpublished.
  5. A new tile has already been added to the dashboard. Edit the title by overwriting the placeholder value New tile with your own tile title, such as the name of the database.
  6. First, we will add a single Monitors tile, using the Icons visualization. The tile selector will already be open. Click Monitors.
  7. Click on the Icons button.
  8. Next, we need to scope the tile. In the scope section select list then type the name of the object for which you wish to see the monitors, and then click on object from the results. For this walkthrough add the database that you browsed to in step 1.
    Monitors will only be shown that use the object in the scope as their target. SquaredUp supports Unit and Dependency rollup monitor types only. Aggregate rollup monitors, such as the entity health monitor, will not display.
    Monitor icons should appear after a moment. You could stop here, but we'll continue to configure the tile.
  9. In the monitors section click on filter.
  10. In the choose monitors box type any word from the name of the monitor that you want to display. Click on the monitor in the list displayed. If you wish you can type a new search word and select more than one monitor to display.
  11. Click next and leave the filters section as it is.
  12. Click done and your Monitors Icons tile will look something like this:
    Next, we will add a Monitor Blocks tile to the dashboard to show several monitors.
  13. Click on the orange plus button to add another tile to the dashboard.
  14. Click on the Blocks button to create a Monitors Blocks tile.
  15. In the scope section type the database name into the list box.
    Blocks should appear after a moment. You could stop here, but we'll continue to configure the tile.
  16. In the monitors section leave it set to all.
  17. In the filters section click on uninitialized to remove gray uninitialized monitors.
  18. In the blocks section you can change the number of columns, the block height, as well as the font size. This can be useful when creating a dashboard for a wall monitor.
  19. The label and sublabel sections allow you to change the block labeling or even create a custom label (How to use Custom Labels). We're going to leave these as they are for this walkthrough.
  20. Click done and your Monitors Blocks tile will look something like this:
Submit a ticket
On this page
  • About the Monitors tile
  • How to configure a Monitors tile
  • Walkthrough: Adding Monitors tiles to a dashboard
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
