LogoDark mode logo
LogoDark mode logo
    • Azure Application Insights provider
    • Azure Log Analytics provider
    • Elasticsearch provider
    • Google API provider
    • Microsoft Entra ID provider
    • PagerDuty provider
    • Pingdom provider
    • Prometheus provider
    • ServiceNow provider
    • SolarWinds provider
    • Splunk provider
    • SquaredUp Cloud Provider
    • Uptime Robot provider
    • Web API provider
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingintegrations pingdom provider
Pingdom provider
Before you configure the Web API tile for use with Pingdom you need to create a Pingdom provider in SquaredUp DS.
You may like to refer to the Pingdom API documentation or speak to your Pingdom expert.
For Pingdom the provider must be created as a simple provider:
  1. In SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
  2. Under Integrations click Web API.
  3. Click the authentication type Simple
  4. In the service name box type in a suitable name, e.g. Pingdom
  5. The base URL should be the current Pingdom API URL, for example:
    We recommend you include the API version here in the base URL, so if the API version changes you only need to update it here, rather than in every tile.
  6. Under default headers click add
  7. Add the following:
    value: Bearer<API token from Pingdom>
    Paste the API token into the authorization value box in SquaredUp DS, prepended by the word Bearer and a space
  8. Click Save.
Submit a ticket
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
