LogoDark mode logo
LogoDark mode logo
    • Azure Application Insights provider
    • Azure Log Analytics provider
    • Elasticsearch provider
    • Google API provider
    • Microsoft Entra ID provider
    • PagerDuty provider
    • Pingdom provider
    • Prometheus provider
    • ServiceNow provider
    • SolarWinds provider
    • Splunk provider
    • SquaredUp Cloud Provider
    • Uptime Robot provider
    • Web API provider
  • How to create a dashboard
  • Recycle Bin
  • Working with perspectives
  • VADA perspective
  • How to scope tiles
  • Timeframes for tiles
  • Grid Designer
  • Performance Metric Labels
  • How to use Custom Labels
  • How to run SCOM tasks
dashboardingintegrations pagerduty provider
PagerDuty provider
Before you configure the Web AP tile for use with PagerDuty you need to create a PagerDuty provider in SquaredUp DS.
For PagerDuty the provider must be created as a simple provider:
  1. In SquaredUp DS navigate to the right-hand menu ☰ > system > Integrations
  2. Under Integrations click Web API.
  3. Click the authentication type Simple
  4. In the service name box type in a suitable name, e.g. PagerDuty
  5. The base URL should be the current PagerDuty API URL, for example:
    https://api.PagerDuty.com/
  6. Under default headers click add
  7. Add the following information to the boxes as shown below:
    First box (name): authorization Second box (value): Token token=API token from PagerDuty
    Paste into the authorization value box in SquaredUp DS, prepended by Token token= as shown above.
  8. Click Save.
Submit a ticket
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
