Web API provider
An EAM-X edition license is required for this feature. To upgrade please contact [email protected].
About Web API providers
The Web API integration allows you to create Web API providers. A Web API provider is a generic provider that contains the connection details to any REST API that returns JSON.
What are Integrations?
SquaredUp DS Integrations allow you to create your own providers. Each Integration has its own form to help you input the information required for different providers. You may use one integration to create more than one provider, for example using the SQL Integration to create providers to connect to different databases.
What is a provider?
- dedicated providers that connect to a specific external platform or database (SQL, ServiceNow, Azure Application Insights, Elasticsearch, etc.)
Which Integrations can I use for Web API tiles?
You can use generic and dedicated integrations to create your own providers. Of course, a dedicated provider like ServiceNow will only work with the ServiceNow API.
You need to have at least one provider before you can use Web API tiles (see How to use the Web API tile).
The Simple Web API provider has been created for you, and can be used by entering a URL and parameters on the fly in the Web API tile on a tile by tile basis. If you are going to create several tiles using a particular API we recommend you create your own API provider so you only need to configure it once.
Generic Web API providers
Walkthroughs for creating generic Web API providers for popular APIs
Google API provider (such as Google Analytics)
Dedicated providers
Adding a Web API provider
In SquaredUp browse to System > Administration > Integrations.
- Under Integrations click on Web API and choose either Simple, Basic Auth or OAuth depending on the API you are using. Note: When adding an OAuth provider you may get a message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc.), or if you use a proxy it could be that the proxy is not configured. See How to configure SquaredUp DS to use a proxy.
- Complete the provider fields, using your API provider's online documentation as a guide.
- You are now ready to use this provider in a Web API tile (see How to use the Web API tile).
Further help for adding Web API providers
- Blog: Integrating SquaredUp DS with external APIs: UptimeRobot
- Webinar that includes New Relic
For other APIs, take a look at our Community Answers site, where there's a wealth of knowledge about APIs.
