LogoDark mode logo
LogoDark mode logo
    • Troubleshooting licensing and activation
    • Troubleshooting users being unable to logon
    • How to check which license key is being used
    • "No license available. There are either insufficient named user licenses available, or you have been blocked from logging on to this server"
    • "License already activated" or "Maximum activations reached"
    • I've received a license expiry notification
    • An error occurred: The key provided is invalid. Activation keys must consist of at least 5 groups of letters and digits
    • This key has expired
    • "Your current license does not include the use of the EA Designer"
    • The activation key you have entered is incompatible with this version of SquaredUp DS
    • SquaredUp cannot start due to an error
    • HTTP Error 500 - The file {filename} has not been pre-compiled, and cannot be requested
    • Unable to log in post SquaredUp DSv4.4: "SCOM connectivity error: unknown or non-specific error"
    • Duplicate SPN found - Troubleshooting Duplicate SPNs
    • "Login failed for user" when configuring the Data Warehouse
    • Troubleshooting Kerberos
    • Authentication with the System Center Operations Manager server was unsuccessful
    • Users unable to logon when Kerberos constrained delegation configured
    • Users are unexpectedly logged out of SquaredUp DS
    • There are no licenses available, or the license for this user is in use elsewhere
  • Collecting diagnostic information
  • Operations Manager 2012 Data Warehouse Health Check Script
  • Where to find log files
troubleshootinguser access licensingtroubleshooting users being unable to logon
No license available. There are either insufficient named user licenses available, or you have been blocked from logging on to this server.
This message means that either:
  • The user trying to log on has been blocked from accessing SquaredUp DS.
or
  • The maximum number of named users has been reached and therefore this user has been declined a license.
In SquaredUp DSclick on the right-hand menu ☰ > system > named users. Check if this user has been blocked, or if they are listed as a licensed user, and how many named users are available.
If you do not see the number of named users you expected see the FAQ and Troubleshooting section of How to manage Named Users.
If you see a message similar to the above, but in a tile on the page when using SquaredUp DS see There are no licenses available, or the license for this user is in use elsewhere.
  • The username entered does not exist in Active Directory.
or
  • If the username is correct, they have entered the wrong password.
Check Active Directory Users and Computers for this user.
Users are unexpectedly logged out or see "Your session has expired"
Your session has expired. Please refresh the page and try again
HTTP Error 500
Symptoms
Users see a black screen and one of various HTTP Error 500 when trying to access SquaredUp DS, and when checking the SquaredUp DS log files you see:
HTTP Error 500 (Dynamic)
Authentication/index : System.Web.HttpException
"The file {filename} has not been pre-compiled, and cannot be requested"
See: Where to find log files
Possible HTTP Error 500 black screen messages:
"The file {filename} has not been pre-compiled and cannot be requested"
HTTP Error 500 (Static)
"This error is triggered by ASP.NET and likely indicated a configuration problem rather than a runtime error in SquaredUp itself"
OpenAccess/Index : System.Web.HttpException
"The file '/SquaredUp/Views/OpenAccess/Index.cshtml' has not been pre-compiled, and cannot be requested"
Procedure
The issue can be resolved using the following steps.
  1. In IIS stop the SquaredUp DS application pool.
  2. On the SquaredUp Server open the following folder:
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\SquaredUp[version number]
  3. Delete the folder within it which is named with a randomly generated GUID.
  4. ​​Start the SquaredUp DS application pool. If you check you should see a new randomly named folder has been created as the SquaredUp DS assemblies are re-copied into the new folder.
  5. Browse to SquaredUp DS. The web page should open successfully and you should be able to log in.
Unable to log in post SquaredUp DS v4.4
Error Message on logon screen
Unable to log in after an upgrade or a new install of SquaredUp DS v4.4 and above, you may get one of the following messages:
"An unknown error occurred when logging in"
or
"Datasource authorization unsuccessful"
Error Message in the log files
The SquaredUp DS rolling.log file includes the following (for help see Where to find log files):
YYYY-MM-DD HH:MM:SS.xxx >> XXX >> [ERR] SCOM connectivity error: unknown or non-specific errorMicrosoft.EnterpriseManagement.ConfigurationReaderException: The service type 'Microsoft.EnterpriseManagement.Runtime.ITaskRuntimeService, Microsoft.EnterpriseManagement.Runtime, Culture="", PublicKeyToken="31bf3856ad364e35", Version="7.0.5000.0"' for the component named 'TaskService' cannot be found.at SquaredUp.Connector.Scom.Authorization.ScomConnectivityTest.GetGroupName(IImpersonation identity)at SquaredUp.Connector.Scom.Authorization.ScomConnectivityTest.Authorize(IImpersonation identity)
Cause
The problem appears to be with loading the SCOM SDK binaries from the Global Assembly Cache if the server has ever had any SCOM components installed on it (e.g. Reporting, Web Console)
Workarounds
  • Remove the SCOM Reporting Server component
  • Re-install the SCOM Web Console component if previously installed but has been removed
  • Install SquaredUp DS on a server without the SCOM components
Symptoms
A user sees the following message when trying to logon:
"Authentication with the System Center Operations Manager server was unsuccessful"
Overview
  • The user trying to log on is not a SCOM user and is therefore unable to authenticate against the SCOM SDK.
or
  • The SCOM server specified is incorrect or inaccessible and therefore SquaredUp DS cannot communicate with the SCOM SDK.
Procedure
If others users can log in:
Check that this user is a SCOM user. Check in Active Directory Users and Computers that this user is a member of a group that has permissions to access SCOM. Commonly used roles include Administrator and Read-Only Operator, but users with other roles - such as Read-Only Operator, Operator, Advanced Operator and Author - may also log on, see Who can log on to SquaredUp DS?.
If no one can log in:
Check that the SCOM server specified is correct and that the System Center Data Access Service is running on that server:
  1. On the SCOM server open Server Manager > Tools > Services and right-click on the System Center Data Access Service and click start or restart. Then test again.
  2. Run notepad as administrator (File, Run, type notepad, and then right-click and select Run as administrator) and then open the scom.json file that is in your SquaredUp DS folder in the following path:
    ...\User\Configuration\scom.json
    Name of the SquaredUp folder
    If you are using high availability (HA) check the scom.json on any SquaredUp server.
  3. Update the value next to server-address to the correct SCOM server name, for example:
    "server-address": "SCOMServer01"
    Where SCOMServer01 should be replaced by your SCOM server name.
  4. Save the file.
  5. Recycle the SquaredUp DS application pool in IIS in your SquaredUp server(s).
  6. Check that you can log in to SquaredUp DS.
Users are unexpectedly presented with the SquaredUp DS logon screen
Symptoms
  • Users are logged off before the session time-out is reached (see How to configure the session time-out).
  • Users are redirected to the SquaredUp DS log on page unexpectedly.
  • Users may see the following message in SquaredUp DS:
  • You may see the following in the SquaredUp DS log files (see Where to find log files):
    Stop requested: BinDirChangeOrDirectoryRename
    or
    Stop requested: ConfigurationChange
  • You may see the following in the Event Viewer Application Log:
    Event message: Application is shutting down. Reason: A subdirectory in the Bin application directory was changed or renamed.
It is normal for a user to be logged out if the same user logs in elsewhere.
Cause
If you are load balancing SquaredUp DS you should check that the load balancer is configured to send all SquaredUp DS requests from a client session to the same SquaredUp server. You should ensure that the load balancer is configured to use 'source address affinity persistence', 'server affinity', 'session affinity' or 'persistence'. The setting name varies depending on the load balancer, for more information see Tips for using a load balancer.
When the SquaredUp DS application pool is recycled user sessions are lost, and so all users are logged off SquaredUp DS.
Some common reasons for the application pool recycling unexpectedly are:
  • Anti-virus software 'touching' files
  • Microsoft hotfix KB3052480 not being installed on Windows 2012 servers
Procedure
These steps will allow you to investigate unexpected recycling of the application pool further:
  1. Search the SquaredUp DS log files for BinDirChangeOrDirectoryRename. The default log file location is C:\inetpub\wwwroot\SquaredUp\transient\Log\ see Where to find log files
  2. If you find several occurrences of Stop requested: BinDirChangeOrDirectoryRename then the SquaredUp DS folder needs to be added to your antivirus exclusions or exceptions list.
    If you are using McAfee and you are experiencing several refreshes when logging into SquaredUp DS, then you may need to implement version 8.8.07 in order to resolve this issue. Notes on this can be found here.
  3. Search the SquaredUp DS log files for ConfigurationChange. You can find the log files in the SquaredUp DS folder in the following path:
    ...\transient\Log
  4. If you find several occurrences of Stop requested: ConfigurationChange you should install Microsoft hotfix KB3052480
  5. If you are load balancing SquaredUp DS ensure that the load balancer is configured with sticky sessions, source IP/address affinity or persistence enabled see Tips for using a load balancer.
Further diagnostics
If you have configured anti-virus exclusions and installed Microsoft hotfix KB3052480 and users are still being logged off unexpectedly follow these steps to find out more about why this is happening:
Find the web.config file located in the SquaredUp folder.
Create a backup of the web.config file by copy and pasting the file to a different location.
Open the web.config file in the SquaredUp folder as an administrator.
  1. Immediately after the <system.web> line add the following text:
    <healthMonitoring enabled="true">
      <rules>
        <add name="App Lifetime" eventName="Application Lifetime Events" provider="EventLogProvider" profile="Default" minInstances="1" minInterval="00:00:00" maxLimit="Infinite"/>
      </rules>
    </healthMonitoring>
  2. Wait for the next unexpected logoff or application pool recycle.
  3. In Event Viewer > Windows logs > Application look for an event where the Source is "ASP.NET" and the Event ID is 1305.
  4. The description of the event should show the reason.
Users are presented with the browser sign in screen
Symptoms
When users attempt to log on to SquaredUp DS they receive a browser-based login prompt.
The following error is logged in the SquaredUp DS log file (see Where to find log files):
[ERR] SCOM connectivity error: unauthorized System.UnauthorizedAccessException: The user does not have sufficient permission to perform the operation.
Cause
SquaredUp DS accesses SCOM using the end user's credentials. When Windows authentication is being used and SquaredUp DS is deployed on a dedicated server (not a SCOM server), the end user first authenticates with the SquaredUp server, and then the SquaredUp server impersonates the end user and authenticates with the SCOM Management Server. This requirement to authenticate a second time is known as a 'double-hop' and requires Kerberos delegation to be configured correctly.
Kerberos delegation involves complex configuration. It requires Kerberos authentication to be correctly functioning between client, web server and management server, and for configuration such as Service Principal Names (SPNs) to be configured correctly.
You may find that users logging on to SquaredUp DS on a client, who have also logged on to the browser on the SquaredUp server itself, will authenticate successfully. This is because their session can still be live on the SquaredUp server, which means it is in effect now only a one hop authentication between the client and SCOM. This can cause confusion when diagnosing the issue.
Resolution
Please follow the guide here User authentication methods for SquaredUp DS for SCOM.
And run through the Troubleshooting Kerberos article.
Support
You may also like to look at How to manage Named Users
Submit a ticket
On this page
  • No license available. There are either insufficient named user licenses available, or you have been blocked from logging on to this server
  • Username or password incorrect
  • Users are unexpectedly logged out or see "Your session has expired"
  • HTTP Error 500
  • Unable to log in post SquaredUp DS v4.4
  • Users are unexpectedly presented with the SquaredUp DS logon screen
  • Users are presented with the browser sign in screen
  • Support
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
