Theme Personalization
Theme Personalization allows users to view SquaredUp DS in either dark theme or light theme.
Theme Personalization is available in SquaredUp DS v4.5 and above
New installations default to dark theme.
v5 and below default to light theme and retain this default on upgrading.
A Teams edition license (or above) is required for this feature. To upgrade please contact [email protected]
Setting your individual theme
You can decide if you want to view SquaredUp DS for SCOM in dark theme or light theme. The individual theme setting only affects the way SquaredUp DS looks to you, not how it looks to other users.
- Go to System > Personalization.
 - Toggle the dark theme button to on or off.
When the dark theme button is set to off, you'll see SquaredUp DS in light theme. When it is set to on, you'll see SquaredUp DS in dark theme.
Setting the theme for all Open Access Dashboards
Open Access dashboards for new installations default to dark theme.
Open Access dashboards on v5 and below default to light theme and retain this default on upgrading.
By default Open Access dashboards use the same theme, for example light theme, as normal dashboards, and all users who navigate to any of the Open Access URLs will be affected by this setting. If required, Open Access dashboards can be given a different theme by changing the global setting for all Open Access dashboards, or changing it on a per dashboard level:
Global Open Access settings can be set and changed in the openaccess.json file. Global settings affect all Open Access dashboards, but some settings can be overridden on a per dashboard level in Dashboard Settings.
notepad, and then right-click and select Run as administrator).With Notepad in administrator mode, open the
openaccess.jsonfile from the following path in the SquaredUp DS folder:...\User\Configuration\openaccess.jsonThe default location for the SquaredUp folder is
C:\inetpub\wwwroot\SquaredUpv5and for v4C:\inetpub\wwwroot\SquaredUpv4.Name of the SquaredUp folderA custom location may have been chosen during the installation.
SquaredUpv5, and for v4SquaredUpv4.- If openaccess.json is blank or only contains {} then enter the setting and the value you require, for example:
{ "oa-refresh-interval": 120 } - If openaccess.json already contains settings, then you will need to add a comma at the end of the previous line, and then enter your setting and value, to look something like this:
{ "oa-theme": "darktheme", "oa-refresh-interval": 120 } - Save the file.
 - In IIS recycle the SquaredUp application pool for the setting to take effect.
If you are unable to access SquaredUp DS ("Server Error in '/SquaredUpvx' Application", "SquaredUp DS cannot start due to an error" or "Startup failed for 'Configuration'") after editingopenaccess.jsonthen there is an error in the file. Correctopenaccess.jsonand recycle the SquaredUp DS application pool again.
System > Administration > Content > Open Access
This setting allows you to change the theme on a per Open Access dashboard basis.
This setting overrides the global Open Access theme.
