LogoDark mode logo
LogoDark mode logo
  • Licensing Overview
  • System Requirements, Server Spec and Sizing
    • Branding
    • Broadcast
    • Dashboard Packs
    • Export to Excel
    • In-product Notifications
    • Logs and Maintenance Page
    • Page Analytics (Telemetry)
    • Pinned Perspectives
    • Team Folders
    • Theme Personalization
    • Time and formats page
    • Visual Application Discovery & Analysis (VADA)
  • EAM-X
  • Training
  • Support for older versions of SquaredUp DS
  • Understanding the figures on Performance graphs
  • SquaredUp DS and the SDK user limit
  • Useful PowerShell Commands
  • Square Up (the credit card company) payments and problems
referenceproduct featuresmaintenance page
The Logs and Maintenance page is only visible to SquaredUp DS for SCOM administrators (see Who can log on to SquaredUp DS?). It is accessible from the top right-hand menu ☰ System > Logs and maintenance. It is designed to help you maintain and troubleshoot SquaredUp.
Updates
SquaredUp DS for SCOM periodically checks for updates, and if an update is available then this section will show a link to the Release Notes for SquaredUp DS for SCOM and to download the installer.
Remote Administration
If SquaredUp DS for SCOM detects that it is running on an Azure virtual machine (VM) then a link Open in Azure Portal will be shown. The link takes you to the VM resource page in the Azure portal, if you have access to the VM resource.
The Connect with RDP link allows you to download a Remote Desktop Protocol (RDP) link file which can be used to remotely connect to the SquaredUp server. This is particularly useful for installing updates and troubleshooting.
High Availability (HA)
This section will only be shown if SquaredUp DS for SCOM detects that it is running in High Availability (HA) mode (see Enabling High Availability).
It shows the location of the squaredup.index file, the HA health status, and details of the Primary and Secondary servers from the index.
The HA health status can be healthy, warning or error. A warning or error state will occur if a Secondary server is out of contact with the Primary server (see Enabling High Availability).
You can use the table to check that all servers are running the same version of SquaredUp DS for SCOM and that they each have the correct role.
Logs
Log Level
SquaredUp DS for SCOM can record five different levels of logging data: debug, information, warning, error, fatal.
The log level chosen determines which of the five levels of logging data are recorded, as shown below.
Log level
Logging data shown
Log file size
Debug
All 5 levels of log entries are recorded: debug, information, warning, error, and fatal.
Larger log files
Information
Information, warning, error, and fatal log entries.
Default logging level
Warning
Only the highest levels of warning, error, and fatal are shown.
Smaller log files
SquaredUp Support may ask you to increase the logging level to Debug if they need more information to be recorded for troubleshooting. Alternatively, you may choose to decrease the logging level to warning if you wish to record less information, and reduce the file size of the logs.
Log Files
The Log Files section shows the most recent log files, up to 10 days old, which can be downloaded individually. The download logs button automatically downloads the last 7 days worth of logs.
When you are in contact with SquaredUp Support they may ask you to run the SquaredUp DS diagnostics script (see Collecting diagnostic information), as this collects more useful configuration information along with the logs.
Log Viewer
The log viewer shows the last 100 log entries on-screen. You can refresh the view, or set it to auto refresh, as well as copy the details.
Submit a ticket
On this page
  • Updates
  • Remote Administration
  • High Availability (HA)
  • Logs
  • Log Level
  • Log Files
  • Log Viewer
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
