Users are unexpectedly logged out of SquaredUp DS
Symptoms
- Users are logged off before the session time-out is reached (see How to configure the session time-out).
- Users are redirected to the SquaredUp DS log on page unexpectedly.
- Users may see the following message in SquaredUp DS:
Your session has expired. - You may see the following in the SquaredUp DS log files (see Where to find log files):
Stop requested: BinDirChangeOrDirectoryRename
or
Stop requested: ConfigurationChange - You may see the following in the Event Viewer Application Log:
Event message: Application is shutting down. Reason: A subdirectory in the Bin application directory was changed or renamed.
It is normal for a user to be logged out if the same user logs in elsewhere.
Cause
If you are load balancing SquaredUp DS you should check that the load balancer is configured to send all SquaredUp DS requests from a client session to the same SquaredUp server. You should ensure that the load balancer is configured to use 'source address affinity persistence', 'server affinity', 'session affinity' or 'persistence'. The setting name varies depending on the load balancer, for more information see Tips for using a load balancer.
When the SquaredUp DS application pool is recycled user sessions are lost, and so all users are logged off SquaredUp DS.
Some common reasons for the application pool recycling unexpectedly are:
- Anti-virus software 'touching' files
- Microsoft hotfix KB3052480 not being installed on Windows 2012 servers
Procedure
These steps will allow you to investigate unexpected recycling of the application pool further:
- Search the SquaredUp DS log files for
BinDirChangeOrDirectoryRename. The default log file location isC:\inetpub\wwwroot\SquaredUp\transient\Log\see Where to find log files - If you find several occurrences of
Stop requested: BinDirChangeOrDirectoryRenamethen the SquaredUp DS folder needs to be added to your antivirus exclusions or exceptions list.The default location for the SquaredUp folder is
C:\inetpub\wwwroot\SquaredUpv5and for v4C:\inetpub\wwwroot\SquaredUpv4.Name of the SquaredUp folderNoteA custom location may have been chosen during the installation.
SquaredUpv5, and for v4SquaredUpv4. - Search the SquaredUp DS log files for
ConfigurationChange. You can find the log files in the SquaredUp DS folder in the following path:...\transient\LogThe default location for the SquaredUp folder is
SquaredUpv5, and for v4SquaredUpv4. - If you find several occurrences of
Stop requested: ConfigurationChangeyou should install Microsoft hotfix KB3052480 - If you are load balancing SquaredUp DS ensure that the load balancer is configured with sticky sessions, source IP/address affinity or persistence enabled see Tips for using a load balancer.
Further diagnostics
If you have configured anti-virus exclusions and installed Microsoft hotfix KB3052480 and users are still being logged off unexpectedly follow these steps to find out more about why this is happening:
Find the web.config file located in the SquaredUp folder.
For v5 it is C:\inetpub\wwwroot\SquaredUpv5 and for v4 C:\inetpub\wwwroot\SquaredUpv4.
web.config file by copy and pasting the file to a different location.Open the web.config file in the SquaredUp folder as an administrator.
- Immediately after the
<system.web>line add the following text:<healthMonitoring enabled="true"> <rules> <add name="App Lifetime" eventName="Application Lifetime Events" provider="EventLogProvider" profile="Default" minInstances="1" minInterval="00:00:00" maxLimit="Infinite"/> </rules> </healthMonitoring> - Wait for the next unexpected logoff or application pool recycle.
- In Event Viewer > Windows logs > Application look for an event where the Source is "ASP.NET" and the Event ID is 1305.
- The description of the event should show the reason.
