LogoDark mode logo
LogoDark mode logo
  • Licensing Overview
  • System Requirements, Server Spec and Sizing
    • Branding
    • Broadcast
    • Dashboard Packs
    • Export to Excel
    • In-product Notifications
    • Logs and Maintenance Page
    • Page Analytics (Telemetry)
    • Pinned Perspectives
    • Team Folders
    • Theme Personalization
    • Time and formats page
    • Visual Application Discovery & Analysis (VADA)
  • EAM-X
  • Training
  • Support for older versions of SquaredUp DS
  • Understanding the figures on Performance graphs
  • SquaredUp DS and the SDK user limit
  • Useful PowerShell Commands
  • Square Up (the credit card company) payments and problems
referenceproduct featuresin product notifications
Notifications are only visible to SCOM administrators.
SquaredUp DS will periodically check for new notifications, which are visible from the top right-hand menu ☰ either via notifications or under system -> notifications. Notifications have different severity levels from informational (such as a new product release) to critical (e.g. license expiry).
Dismissing Notifications
Submit a ticket
On this page
  • Dismissing Notifications
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
