LogoDark mode logo
LogoDark mode logo
    • Troubleshooting licensing and activation
    • Troubleshooting users being unable to logon
    • How to check which license key is being used
    • "No license available. There are either insufficient named user licenses available, or you have been blocked from logging on to this server"
    • "License already activated" or "Maximum activations reached"
    • I've received a license expiry notification
    • An error occurred: The key provided is invalid. Activation keys must consist of at least 5 groups of letters and digits
    • This key has expired
    • "Your current license does not include the use of the EA Designer"
    • The activation key you have entered is incompatible with this version of SquaredUp DS
    • SquaredUp cannot start due to an error
    • HTTP Error 500 - The file {filename} has not been pre-compiled, and cannot be requested
    • Unable to log in post SquaredUp DSv4.4: "SCOM connectivity error: unknown or non-specific error"
    • Duplicate SPN found - Troubleshooting Duplicate SPNs
    • "Login failed for user" when configuring the Data Warehouse
    • Troubleshooting Kerberos
    • Authentication with the System Center Operations Manager server was unsuccessful
    • Users unable to logon when Kerberos constrained delegation configured
    • Users are unexpectedly logged out of SquaredUp DS
    • There are no licenses available, or the license for this user is in use elsewhere
  • Collecting diagnostic information
  • Operations Manager 2012 Data Warehouse Health Check Script
  • Where to find log files
troubleshootinguser access licensinglicense already activated or maximum activations reached
Symptoms
When activating SquaredUp DS you see:
or
Procedure
If you are adding further SquaredUp servers to a multi-server / high availability environment you should use the Secondary license key for each subsequent server (see Enabling High Availability). The Primary license should only be used for the first server in the deployment.
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to http://SquaredUpServer/SquaredUp/InstallLicense (where SquaredUpServer is the name of the server where SquaredUp DS is installed). The .bin file cannot be used on a different server.
If you need any help please contact SquaredUp Support
Submit a ticket
On this page
  • Symptoms
  • Procedure
Footer
Sites
  • SQUAREDUP
  • SQUAREDUP DS
  • DOWNLOAD
  • COMMUNITY ANSWERS
Quick Links
  • SUBMIT A REQUEST
  • EVENTS
  • CAREERS
Small Print
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
Youtubex (Twitter)LinkedIn
© SquaredUp 2025
