How to add links to an external ticketing system from Alerts
Using this setting, allows you to turn the ticket field on a Dashboard Server Alert drilldown into a link to a ticket in your external service desk or ticketing system. This is useful if you have a separate ticketing/service desk system that has a web interface.
Procedure
The ticket hyperlink is configured through a setting stored in scom.json.
On the Windows Server where Dashboard Server is installed:
Run notepad as administrator (File, Run, type
notepad
, and then right-click and select Run as administrator) and then open the following file:C:\inetpub\wwwroot\SquaredUpv[version number]\User\Configuration\scom.json
Add the following line and replace with the desired template. You may not need the id= depending on your particular service desk URLs.
{{ticketId}}
is automatically replaced with the value of the ticket ID field in the Alert."ticket-template": "http://my-ticketing-system/id={{ticketId}}"
- You may also need to add a comma at the end of the previous line, if there are multiple settings in the file.
Linking to an alert
Once the template URL is setup, any alerts with a ticket ID will display a link.
- Drilldown into any alert within Dashboard Server.
- Select the ticket button near the top right of the page.
- Enter the desired ticket ID
- Click update.
You'll now see the ticket ID displayed alongside the alert name. Clicking this tag will open a new window to your external ticketing system / service desk.
Variables
Using the curly brace syntax, e.g. {{variable}}
you can include different variables in the URL template. In the example above we used {{ticketId}}
- classId
- customField1
- customField2
- customField3
- customField4
- customField5
- customField6
- customField7
- customField8
- customField9
- customField10
- description
- id
- isMonitorAlert
- lastModified
- lastModifiedBy
- monitoringObjectDisplayName
- monitoringObjectId
- monitoringObjectPath
- name
- owner
- priority
- problemId
- repeatCount
- resolutionState
- resolutionStateName
- resolvedBy
- ruleId
- severity
- ticketId
- timeRaised
- timeResolved
- type
