CVE-2021-40096 - Stored cross-site scripting (provider configuration)
CVE: CVE-2021-40096
Before SquaredUp DS version 5.3.1, stored XSS was possible when creating an Azure Active Directory, Azure App Insights, or Azure Log Analytics provider. This vulnerability allows remote attackers to inject arbitrary web script or HTML.
What should you do?
If you are using a SquaredUp DS version earlier than 5.3.1, update to version 5.3.1 or later.
Product
Affected versions
Resolved versions
SquaredUp DS for SCOM
Versions earlier than 5.3.1
5.3.1 and later versions
SquaredUp DS for Azure
SquaredUp DS Standalone
Acknowledgement
If you believe you've found a different security vulnerability in one of our products please report it by emailing our support team so we can work on fixing it: [email protected]
10.11.2021
Initial release
