How to activate your license
After installing SquaredUp DS you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key or activation key), which is then activated against a SquaredUp DS installation.
If you have been asked to reactivate your existing license key, because it has been modified or extended, then you will need to reactivate your existing license (see How to reactivate your license).
If your web server cannot connect to the internet to activate then you can do an offline activation (see How to activate your license offline (manual activation)).
Use this article if you have been sent a new license activation key.
Free trial
When you apply for a free trial you receive an unrestricted 30 day evaluation to try out all features in your own SCOM environment: Request a free trial activation key. If you've previously had a trial, or your trial has expired please contact SquaredUp Support
Purchased SquaredUp DS
When you buy SquaredUp DS you will be emailed your license keys. If you do not have a license activation key please contact SquaredUp Support
Types of license keys
Trial license
This license allows for unlimited users and all features for a 30 day evaluation in your own environment and is available from here
Primary Production license
This license should be used if you only have one SquaredUp production server, or on your first SquaredUp production server if you are configuring a multi-server / high availability environment (see Enabling High Availability)
Secondary license
This license should only be used for any subsequent servers in a multi-server / high availability / load balanced environment (see Enabling High Availability)
Test & Development license
This license is for your test environment so that you can experiment with configuration changes and new versions without affecting production.
It is included free of charge with a purchase of the Teams, Connect and EAM editions.
How to Activate SquaredUp DS
  1. After installing, the set up wizard prompts you to log in as a user who is a SCOM Admin (see Types of users in SquaredUp DS), and ideally SQL sysadmin user (see How to make a user a SQL sysadmin), then runs you through first-time use: Login, Activation, Data Warehouse, Open Access, EAM, and Dashboard Packs. See How to install SquaredUp DS for SCOM.
    Or you may need to browse to http://SquaredUpServer/SquaredUp/Activate
    By default, the URL to your SquaredUp DS instance is: http://SquaredUpServer/SquaredUpInstance
    SquaredUpServer is the name of the server where SquaredUp DS is installed.
    By default, SquaredUpInstance is SquaredUp. For v5 it is SquaredUpv5 and for v4 SquaredUpv4. If you gave your SquaredUp DS instance a different application name when you installed it, use the name you chose.
  2. Paste your license key into the Activation screen.
    Take care to use the correct license key, as many licenses only allow one activation.
    For example, the Primary key for the first server, or the Secondary key for subsequent servers in a multi-server / high availability environment (see Enabling High Availability). The Primary key can be activated only once, while the Secondary key can be activated on up to 3 servers.
  3. Click the Activate button.
  4. Complete the SquaredUp DS setup wizard.
For more information on the setup wizard stages see How to install - Logon to SquaredUp DS for the first time.
Each SquaredUp DS instance should have only one SquaredUp DS license key installed. This is usually either a trial license, or - after purchasing SquaredUp DS - the Primary or Secondary license. You may have both a Primary and a trial license installed, for example, if you are trialing new features while considering a license upgrade.
To check which license is being used by an instance of SquaredUp DS, open SquaredUp DS on a particular server by using the localhost address on the server itself or using the server name in the URL, for example https://SquaredUpServer/SquaredUp/
  1. In SquaredUp DS click on the right-hand menu ☰ and then on system.
  2. Click on licensing .
Here you can remove a license, but if you accidentally remove the active license you may not be able to access SquaredUp DS again without contacting SquaredUp Support
Types of licenses
Trial license
Secondary license
If you are having problems activating
If you are adding further SquaredUp servers to a multi-server / high availability environment you should use the Secondary license key for each subsequent server (see Enabling High Availability). The Primary license should only be used for the first server in the deployment.
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to http://SquaredUpServer/SquaredUp/InstallLicense (where SquaredUpServer is the name of the server where SquaredUp DS is installed). The .bin file cannot be used on a different server.
If you need any help please contact SquaredUp Support
You need a license activation key to install SquaredUp DS for SCOM. You will have received this by email following your purchase or free trial. If you do not have an activation key please contact SquaredUp Support
There are two kinds of license key format. The old and the new license key format.
New format:
SquaredUp DS license keys have a text prefix followed by 5 groups of letters and numbers:
For example:
Old format:
SquaredUp DS license keys contain of 5 groups of 5 letters/numbers:
SquaredUp DS v4.1 and above accepts both the new prefixed license key and the old style without the prefix.
SquaredUp DS v4.0 and below only accepts the old style license key. Remove the prefix from the license key to leave just 5 groups.
For example, remove SQUP-PRIMARY- to leave just aaaaa-bbbbb-ccccc-ddddd-eeeee.
That's fine, you can perform a manual or offline activation on another computer that has got internet access and then copy the .bin activation file onto the server. See How to activate your license offline (manual activation).
The activation key being used is not valid for the version of SquaredUp DS. For example, this error occurs when using a DS Standalone or Community Edition (CE) activation key on SquaredUp DS for SCOM.
Some license activation keys (such as for technical preview releases and evaluation licenses) are only valid for a limited time period. Contact SquaredUp Support
For other renewable licenses you will normally be able to renew your license before it expires. As part of this renewal process, SquaredUp DS will update your existing license with the new subscription term, so you can simply reactivate your license for the changes to take effect.
If your license expires before you are able to renew then you may be sent a new license activation key, which you should paste into the activation screen to activate the new key, when prompted when you open SquaredUp DS.
Anything else we can help with
Following activation
Browse to your SquaredUp DS instance.
