Release Notes for SquaredUp DS for SCOM v6
Note
For the full list of new features in SquaredUp DS v6 see What's new in SquaredUp DS for SCOM
See the Release Notes for the most recent version: Release Notes for SquaredUp DS for SCOM
6.5.1
Issues Addressed
  • Tree skeleton can escape tile area (SQ-5523)
Known Issues
  • Chained custom scope on a perspective does not visually update correctly on undo / redo (SQ-5235)
  • Removing the contents property from the dashboard JSON editor does not register as an undo action (SQ-5207)
6.5.0 (Release Candidate)
Improvements
  • New customizable branding (EAM tier or above) – choose your own home logo, login image, and login background (SQ-3876)
  • Conditional coloring and improved sorting for Grid visualizations (SQ-4602 and SQ-5434)
  • Value formatter allowing configuration of number of decimal points for Line graph and Column graph visualizations (SQ-5385)
Issues Addressed
  • HTML content in the Web Content tile doesn't display correctly on Open Access dashboards (SQ-5479)
  • SquaredUp Cloud tile does not support subdomain tenants (SQ-5446)
  • Include Contained Objects is not selected when reviewing active maintenance windows (SQ-5445)
  • VADA discovery fails for Windows 2025 servers (SQ-5443)
  • Single-object scope panel does not clear its configured scope when scope tag is deleted (SQ-5234)
Known Issues
6.4.1
Issues Addressed
  • The color for a hyperlink, when included in the Broadcast message, conflicts too much with the coral background color and makes it difficult to read (SQ-5436)
  • Improvements to grid performance when editing and moving columns (SQ-5435)
  • SquaredUp Cloud Integration now available for EAM tier, as well as EAM-X tier (SQ-5438)
Known Issues
6.4.0 (Release Candidate)
Improvements
  • A new SquaredUp Cloud tile and provider has been added, allowing you to embed your SquaredUp Cloud tiles into your DS dashboards (SQ-5282)
  • A new Matrix tile editor allows you to edit the columns section of Matrix tiles on the fly using a new interface, so you no longer need to edit the JSON. The new Matrix Rows tab on the System page uses the same editor to also allow you to easily edit your saved row perspectives (SQ-5307)
  • A message broadcasting system has been implemented which allows you to enter markdown content to show on all dashboards (SQ-5138)
  • You can now run Tasks against multiple objects on Status Donut, Alert Donut, Alert Heatmap and Alert Scalar drilldowns (SQ-4035)
  • You can manually define an interval for how often a task on a SCOM Task tile runs. To support this feature caching has been added to all task tile results (SQ-3203)
  • You can now add a tile above another tile when editing a dashboard (SQ-4108)
  • DS has been upgraded to use PowerShell 7.4.6, so if you use .NET Core in your PowerShell tiles you'll need to upgrade to .NET 8.0 (SQ-5323)
Issues Addressed
  • Maintenance mode no longer defaults to the Selected object and all contained objects option (SQ-5371)
  • Export to Excel uses UTC time for Local Time (SQ-5360)
  • Bar Graph sort ignores bars with '0' value (SQ-5354)
Known Issues
6.3.1
Issues Addressed
  • Maintenance Mode duplicates objects from Alert Date Heatmap drilldown (SQ-5367)
  • Unable to add objects to maintenance window when drilldown was scoped to a group (SQ-5368)
Known Issues
6.3.0 (Release Candidate)
Improvements
  • A new Markdown tile has been added that allows you to add richer content to your dashboards such as links, lists, images and more! (SQ-5242)
  • A new scalar visualization has been added to the Alerts tile (SQ-5237)
  • Scheduled maintenance mode (SQ-2435)
  • Tear-off tiles (SQ-5306)
  • Maintenance mode dashboard pack (SQ-5250)
  • Management pack descriptions for Enterprise Applications (SQ-4791)
Issues Addressed
  • Text contrast improvements while in Light mode (SQ-5270)
  • Setup hangs at Dashboard Packs stage when no internet (SQ-5301)
  • WebAPI 'Date HeatMap' tile displays timestamps in UTC (SQ-5304)
Known Issues
6.2.1
Issues Addressed
  • SQUP Cloud MP broken for synced data (SQ-5292)
  • Update DOMPurify to new Release Versions 2.5.2 & 3.1.2 (SQ-5310)
Known Issues
6.2.0 (Release Candidate)
Improvements
  • Matrix tile improvements:
    • Matrix tile column sorting is now persisted so that the sort configuration is remembered whenever you load or refresh the page. (SQ-4887)
    • A new custom celltile type of scalar has been added to matrix tiles. (SQ-3357)
  • Alerts donut tile improvements:
    • Setting a task for an alert object in has been streamlined with the inclusion of two new Task buttons, added to the alerts tile and alerts perspective. (SQ-4764, SQ-3198)
    • Now, the full list of alert grouping properties are available for Alert donut tiles, including the custom alert fields that are provided by System Center Operations Manager. (SQ-1830)
    • Now, it is possible to update update ticket IDs for multiple alerts at a time directly from the alerts tile. Additionally, when an external ticket hyperlink is configuredthe corresponding alert's ticket ID is now automatically hyperlinked for the Alert. (SQ-4788)
    • A new diagnostics row visualization has been added to the alerts tile donut and heatmap (SQ-2427)
    • A Sort option has been added to the donut settings for the Alerts tile, bringing it inline with donut tiles in other areas of the application. (SQ-1830)
  • Clicking the center (total) value on SCOM Alert, SCOM Status and ServiceNow Donut tiles now takes you to a drilldown page of all objects or alerts (for SCOM Status and Alerts donut tiles), or to a list of all incidents / change requests in the ServiceNow portal for ServiceNow donut tiles. (SQ-5229)
  • A tile fullscreen mode has been added. (SQ-5281)
  • You can now rename a provider by simply selecting it on the Integrations page and editing the name field. (SQ-4653)
  • Dashboard Server Security Improvements (SQ-5312)
Issues Addressed
  • When a user changes any field that is stored in the "Alert.vAlertDetail" table, the Most Recent and Currently Open SQL (Grid) tiles on the Alert Analytics perspective show the wrong number of records. (SQ-3536)
  • When attempting to update report availability for EA status, an error occurs. (SQ-5080)
  • Resolved Cloud connectivity issue for the EAM-X MP (SQ-5292)
Known Issues
6.1.1
Issues Addressed
  • Add undo functionality when editing a dashboard (SQ-5123)
Known Issues
6.1.0 (Release Candidate)
Improvements
  • 24 hour time option (SQ-5120)
  • Trend lines for time-series graphs (SQ-3601)
  • EAM-X: Alert description / field improvements (SQ-5118)
  • Undo / Redo buttons for dashboard draft editing (SQ-5123)
  • Performance drill-down page improvements:
    • Trend lines (SQ-3601)
    • Min, max, avg options (SQ-4816)
    • Data range options (SQ-5197)
    • Custom timeframe placement redesign (SQ-5197)
  • Auditing improvements (SQ-5301):
    • Folder filter ability
    • Last 24 hrs audit events loaded by default
    • Filter on multiple types of event at the same time (e.g. Dashboard moved + Team Folders modified)
  • Scalar Tile: Text can be left-aligned, centered or right-aligned (SQ-4953)
  • Number format improvement (SQ-3098): Decimal number format support has been added for small units and separator format support has been added for large units.
  • VADA: performance improvements in Analyze mode (SQ-4868)
  • Initial page size / speed load improvements (SQ-5195)
Issues Addressed
  • The scope panel does not reflect changes made by the undo / redo functionality, even though the underlying tile JSON has been updated as expected. This may be confusing to users (SQ-5209)
  • When the browser is set to use Arabic as the display language, the Date Heatmap does not show any data and an error is logged in the browser (SQ-5215)
Known Issues
6.0.2
Issues Addressed
  • Users are redirected to the Audit Explorer page on logon if Dashboard Server is installed to the website root (SQ-5165)
  • Encrypted content is lost when applying a new license key in a High Availability environment (SQ-5160)
  • Some text input fields, such as the auditing connection string field and the provider default headers / url parameters fields are difficult to see in the Light Mode (SQ-5150)
6.0.1
Improvements
  • Removed the redundant haupgrade command, as these types of upgrade are not supported for v5 upwards (SQ-5131)
Known Issues
  • Alerts Analytics perspective shows incorrect number of records in certain situations (SQ-3536)
6.0.0 (Release Candidate)
Improvements
  • Auditing user actions (SQ-3100)
  • SolarWinds Orion integration (SQ-5057)
  • Prometheus integration (SQ-5034)
  • Date Heatmap: add aggregation options for Web API, SQL, PowerShell and SolarWinds tiles (SQ-5082)
  • SquaredUp Cloud aligned color pallet and styling (SQ-4941)
  • Time series data as bar graphs (SQ-4690)
Issues Addressed
  • Azure Log Analytics integration for .US endpoint failing (SQ-5089)
  • Top n Bar formatting not converting values to days (SQ-5055)
  • Mustache picker buttons disappear if timeframe mustache Is used in query (SQ-5081)
  • Second Splunk tile on a dashboard automatically uses the first Splunk tile's search query (SQ-4840)
  • Sorting of date fields from custom template in grid sorts by string value rather than date (SQ-4866)
  • IIS App Pools are not discovered by VADA in Windows 2022 (SQ-5125)
Known Issues
Older versions
Release Notes for SquaredUp DS for SCOM v5
