CVE-2021-40091 - SSRF issue
CVE: CVE-2021-40091
An SSRF issue was discovered in SquaredUp DS for SCOM 5.2.1.6654.
What should you do?
If you are using a SquaredUp DS version earlier than 5.3.1, update to version 5.3.1 or later.
Product
Affected versions
Resolved versions
Versions earlier than 5.3.1
5.3.1 and later versions
SquaredUp DS for Azure
SquaredUp DS Standalone
Acknowledgement
If you believe you've found a different security vulnerability in one of our products please report it by emailing our support team so we can work on fixing it: [email protected]
10.11.2021
Initial release
