How to create a dashboard
Dashboards and perspectives are both pages that show tiles of data and graphs that update every minute. The difference is that for dashboards each tile on the page is configured separately to show information about whichever objects you choose, whereas perspectives can be configured so that all the tiles on the page dynamically change to show information about the one object you have browsed to.
You should create a dashboard if the page will show information about a variety of objects.
You should create a perspective if the tiles will be showing various information related to one specific object. For example, memory, CPU, alerts, for one object. You can create one perspective and have it dynamically show you the data for the objectthe user has drilled down to view.
See Working with perspectives
This article covers:
For detailed information about dashboard layout, adding columns, rows, and split tiles see How to use the dashboard designer.
For a series of short videos taking you through building and designing your own dashboards see the SquaredUp DS video series.
For a series of short videos taking you through building and designing your own dashboards see the Fundamentals video series (Fundamentals).
Dashboard Gallery
For more information about how to configure each tile please browse the KB to Dashboarding > Tiles
The dashboard is saved as you go along so there's no need to save your changes. You can find your dashboard from System > Administration > Content > Unpublished. Draft dashboards are not visible to anyone other than you.
You can toggle between Edit mode and View mode by clicking the edit this dashboard button at the top right:
Creating a new dashboard
You can create a new dashboard by clicking the Add Dashboard button:
Or add a new folder:
Or you can browse to a subfolder, click the ellipsis button, and then create the new dashboard there:
You may also like to watch this 7 minute video about creating a NOC (network operations center) dashboard, which is part of our Fundamentals Quick Win video series:
Edit tile - Configure tile
The most important part of any dashboard is the data. The edit tile (cog) button and configure tile links both allow you to choose the kind of tile you want to add and then configure it.
Publishing your dashboard
Who can view the dashboard?
On the main menu your dashboard will be visible to everyone.
If it is within a Team Folder then it will only be visible to those with access to that Team Folder (see Team Folders).
If the dashboard has Open Access enabled, or is added to the Open Access navigation bar, then it will be visible to anyone, even unlicensed users (see Sharing Dashboards with anyone - Open Access).
All SCOM data in SquaredUp DS is subject to SCOM's role-based access control (RBAC), so users will only see SCOM data that they have permissions to view. For more information see User Management.
Dashboard buttons - Edit mode
Discard a draft
If a dashboard or perspective is not published yet (draft), the discard and discard changes buttons will delete it.
If the dashboard or perspective has been published, and then you make changes, discard will discard the changes and leave the previously published dashboard or perspective live.
If you unpublish a dashboard or perspective and then discard changes then the dashboard or perspective will be deleted.
Undo / Redo
Whenever you make a change in edit mode, the Undo button is enabled, clicking this button will undo the last change you made to the dashboard.
Whenever you perform an undo action, the Redo button is enabled, clicking this button will reverse the undo and re-implement the change you last undid.
The following keyboard shortcuts are also supported for this functionality:
  • CTRL-Z: Undo
  • CTRL +Y or CTRL-Shift-Z: Redo
Unpublish
Once your dashboard is published you will see an unpublish option if you click on the cog to edit the dashboard.
Unpublishing the dashboard removes it from the view. You are asked to confirm this, as the dashboard will return to only you being able to view it.
If you discard a dashboard after unpublishing then the dashboard will be deleted.
Move
This allows you to move the dashboard to a new location on the navigation bar (How to edit the Navigation Bar).
Delete a published dashboard
SquaredUp DS admins can view a list of all the published perspectives from System > Administration > Content > Perspectives.
The Delete button allows you to delete a perspective quickly.
You can navigate to a dashboard, perspective, or pinned perspective, click the edit button and then click the delete button.
More options to delete a dashboard or pinned perspective
Other options to delete a dashboard or pinned perspective are:
  1. You can delete the dashboard or pinned perspective from the navigation bar. Deleting it from the navigation bar will delete it completely, not just from the navigation bar.
    The global navigation editor is accessible only by SCOM administrators (Types of users in SquaredUp DS) from System > Edit navigation or System > Administration > Content > Dashboards.
    This allows SCOM administrators to reposition globally viewable folders and Team Folders on the navigation bar, as well as the ability to move any globally viewable dashboards.
    Globally viewable folders (normal folders that appear on the navigation bar for everyone) are shown by a folder icon:
    Managing the dashboards within Team Folders is done from the Folder Details.
    The edit team folder icon is shown next to Team Folders and clicking it will take you to the Folder Details page where you can view and sort the dashboards within the Team Folder.
    The delete button will delete items. This deletes the dashboard or folder and sub-contents completely, not just from the navigation bar. (Admin users can restore deleted dashboards and perspectives from the Recycle Bin
  2. If the dashboard or pinned perspective is in a folder, you can go to the Folder Details
    Click the edit button
    Then delete it from the folder. Deleting it from the folder will delete the dashboard, not just from the folder. Admin users can restore dashboards and perspectives, see Recycle Bin
Clone
This creates a copy of the dashboard in the same location, ready for you to edit.
Edit actions
This allows you to add a button at the top of a dashboard.
For more information see Action buttons for dashboards and perspectives.
Edit JSON
This allows you to see and edit the JSON behind the dashboard, which can be useful for troubleshooting with the help of SquaredUp Supportor for some editing such as when using the Matrix tile (see How to use the Matrix tile).
  1. Click on the
    edit dashboard button
  2. Click on the
    edit JSON button.
    You see the dashboard's JSON.
Convert a dashboard to perspective
You can easily convert an existing dashboard into a perspective. This is useful when you have multiple objects you want to get the same kind of information about. Instead of creating separate dashboards for each object, you can use one perspective that will dynamically show the information depending on which object is currently viewed.
Note: Converting a dashboard does not delete the original dashboard. It preserves the original dashboard and creates a new perspective based on that dashboard.
  1. Click the edit this dashboard button.
  2. Click the Convert To Perspective button.
  3. Choose the target for the new perspective under Create perspective for.
    The target of a perspective determines two things:
    • for which set of objects the perspective will be visible in the perspective ribbon
    • which set of objects will be used for the dynamic scope of the tiles Note about the relation between the perspective's target and the scope of the perspective's tiles:
      Usually, when you create tiles on a perspective you use a dynamic scope for them that adapts to the currently viewed object. When you define a perspective's target, you define for which objects the perspective will be available. Since the target determines the objects that can be viewed and the currently viewed object determines how the dynamic scope is resolved, the target directly affects the scope of those tiles.
    specific object
    Creates a perspective for a single object with the target setting "this object only"
    group
    Creates a perspective for a group object with the target setting "this object only"
    members of
    Creates a perspective with the target setting "members of" the group or class you picked
    this object only
    The perspective will only be visible for the one specific object you picked, for example one specific server. This means the perspective won't be visible for any other objects.
    Choose this option if you want to create a very specific perspective that is only relevant to one specific object.
    all objects
    The perspective will be visible for all objects, no matter their class.
    Choose this option if you want to create a very broad perspective that is relevant for every object.
    members of
    The perspective will be visible for any object that belongs to the group, class, or health state you choose. For example, if you choose the class Windows Server the perspective will be visible for all objects that belong to the Windows Server class.
    Note: You can only choose groups and classes that the object you are currently viewing is a member of.
    Choose a group if you want to create a perspective that is relevant to a specific group, for example an application or a team.
    Choose a class if you want to create a perspective that is relevant for all objects of this class.
    Choose a health state if you want to create a perspective for objects with a specific health state, for example alerts or monitors.
    Example: If you want the new perspective to appear for all Distributed Applications (DAs) choose Create perspective for members of and in the Class box type service and then select System.Service from the drop down list:
  4. Click convert.
    The dashboard will be converted to a perspective, and you will be navigated to the new perspective.
  5. After converting a dashboard to a perspective, the scope of each tile will be set to the non-dynamic scope option "other specific objects". To take advantage of the power of perspectives, you need to edit the tiles on the perspective to use a dynamic scope.
    Example: If you want a Status tile to show the health status of each of the DA components change the scope to custom, select the children and one level options, and set the Class to object.
    • the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
    • the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
    General advice for scoping tiles on perspectives
    Remember that a tile scope on a perspective usually needs to work for many different objects. You need to consider:
    • For which objects will this perspective be visible? (determined by the target of the perspective)
    • Is the scope I am configuring appropriate for all objects the perspective will be visible on?
    Example:
    You create a perspective with the target "class: Windows Server". The perspective will therefore be visible for all objects of the class Windows Server.
    Now you create a tile on the perspective and scope it to "this object's children of class: Windows Server 2016 Logical Disk". This means that when you view a 2016 Windows server, you'll see data about the server's logical disks in the tile. But when you view a 2012 Windows Server the tile will show no data because the tile's scope is limited to logical disks on 2016 servers. Instead of picking "Windows Server 2016 Logical Disk" you should pick "Windows Server Logical Disk" to make the tile adjust to any object that uses the perspective.
    There are two different sets of options when scoping tiles on perspectives. It depends on the tile you want to scope which set of options you'll see.
    Suggestions
    A sibling of an object is any object of the same class that is hosted by the same parent.
    This object
    This / *
    Example:
    This / IIS Web Server / * selects all objects of any class in the level below This / IIS Web Server.
    Example:
    Parent class of object
    Sibling class of object
    1. For an EA you want to scope to the servers that are specified on the EA map by selecting something from the suggestions (SquaredUp DS 4.2 and above) that shows something similar to the following:
      The screenshot below shows some scope suggestions for an application called FinanceXS. The bold text shows the currently selected scope is This object. The cursor shows the option This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
    2. In the scope section click custom.
    3. Click on the text <YourApplicationName> Map (children) which is your first scope step. This will expand the scope step so you can edit it.
    4. Remove the auto-populated class <YourApplicationName> Map by clicking the cross x next to it.
    5. Start typing Enterprise Application - Map and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
    6. The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
    Custom
    1. At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
    2. Class:
    3. Criteria:
    2. Class:
    3. Criteria:
    Other specific objects
    The Alerts and the SCOM task tile have slightly different options than other tiles because they require different settings.
    This object
    Relative objects
    2. Class:
    3. Criteria:
    Note for SCOM task tiles:
Dashboard Settings
Dashboard settings apply to the whole dashboard and override any global defaults.
Graph colors
Graph colors are set to match by label by default, meaning that the same color will apply to an object with the same label across several graphs. See How to enable graph color matching.
Dashboard timeframe
  • Within SquaredUp DS, it decides which timeframe a dashboard or perspective uses when a user goes to the dashboard or perspective. Tiles set to use the page timeframe (not a fixed, specific timeframe) will use the default page timeframe every time the dashboard or perspective is opened. Users can change the page timeframe temporarily while they are on the dashboard or perspective, but their setting will only last until they leave the page. Their setting will only affect their view of the dashboard or perspective, not other users' views.
  • On Open Access dashboards, tiles that use the page timeframe according to their settings always use the default page timeframe.
You can change the default page timeframe for individual dashboards, or globally:
  • Changing the default page timeframe of a dashboard will affect this individual dashboard and it's Open Access representation. The default page timeframe for perspectives can't be changed individually, they always use the global default page timeframe. Pinned perspectives are treated as dashboards, which means you can change their default page timeframe settings.
  • The global default page timeframe is "last 12 hours". Changing this default setting will affect all dashboards (including Open Access dashboards) that don't have an individual default page timeframe setting. Perspectives always use the global default page timeframe as their timeframe can't be changed individually.
Note: If you are sharing the dashboard or pinned perspective via Open Access, these changes will also affect the Open Access dashboard.
  1. Go to the dashboard or pinned perspective you want to change the individual default page timeframe for.
  2. On the dashboard, click the edit button
  3. Click the settings button.
  4. Choose the new default timeframe under Dashboard timeframe.
  5. Click on the publish button to make the changes go live.
    The dashboard will now by default use the page timeframe you chose. Users can still temporarily change the page timeframe while looking at the dashboard.
    Tip: If you want to undo the individual page timeframe setting to let the dashboard use the global default timeframe again, you need to switch to the JSON view of the dashboard and delete the parameter that defines the dashboard's page timeframe (for example "timeframe": "last7days").
See Timeframes for tiles
Dashboard refresh
By default dashboards (and their Open Access versions) refresh every 60 seconds.
This setting allows you to change the refresh interval on a per dashboard basis, both for the normal dashboard and its Open Access version.
This setting overrides the global dashboard refresh interval.
For example, you may need to reduce the load on your external data, or for an API that has an access cost.
You can increase the refresh interval in increments, up to 6 hours. You can also decrease the interval down to 30 seconds on any given dashboard if you need to see the data refreshed more often.
To change the default refresh interval for Open Access dashboards you should change the global setting, see Sharing Dashboards with anyone - Open Access - Refresh Interval Setting.
View mode buttons
When you are not in Edit mode you will see the following buttons at the top-right of the dashboard:
Page timeframe
If you're looking for general information about what kind of timeframes can affect a tile please read Timeframes for tiles.
The Page Timeframe is the timeframe setting a dashboard or perspective is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have Use Page Timeframe set will adapt to the new timeframe. (Tiles that do not have Use Page Timeframe set (i.e. are set to Specific Timeframe or Custom Timeframe) are not affected and won't change.)
The Custom option can be used to set timeframes using ISO 8601 format
Default page timeframe
Note: This setting affects all dashboards and perspectives (including Open Access dashboards and pinned perspectives on Open Access).
  1. On the SquaredUp server, run Notepad as administrator (StartRun, type notepad, and then right-click and select Run as administrator).
  2. In your SquaredUp DS folder, go to \User\Configuration and find the extensionpacks.json file.
    Name of the SquaredUp folder
  3. Open the extensionpacks.json file and add the property default-timeframe with the value for your new default page timeframe for all your dashboards and perspectives.
    Example for a default timeframe of 24 hours:
    Possible values for the default-timeframe property:
    last1hour, last12hours, last24hours, last7days, last30days, last3months,last6months, last12months, all
  4. Save the json file.
  5. Recycle the SquaredUp DS application pool.
Export dashboard to Excel
See Export to Excel
Set Home Dashboard
The Set Home Dashboard button at the top of each dashboard allows you to set that dashboard as your personal home dashboard.
A panel opens which allows you to Set Home, if no homepage is set, Clear Home if this dashboard is already set as the homepage, or Replace Home if another dashboard is already set as the homepage. The home dashboard will then be shown first when you log in or click the SquaredUp logo. This replaces the default home dashboard, which is the first dashboard on the navigation bar.
In System > Personalization you can see which dashboard is set as your personal home dashboard. Clicking Clear Home will revert you to using the default home dashboard.
Add Favorite
The Add Favorite button on a dashboard will add that dashboard to your Favorites menu on the nav bar.
Even when the nav bar is collapsed the star button still gives you access to your favorites.
In System > Personalization you can sort and remove favorites from the Favorites menu, (no folder structure is supported).
Even when the nav bar is collapsed the Favorites (star) button gives you easy access to your favorite dashboards.
Share this dashboard
