Grid Designer
The Grid designer is available in the Grid columns panel in Grid visualizations, and also the Columns panel for Alerts List. It allows you to easily add, hide, order, and customize columns of data that may come from any internal or external source.
Configuring columns
Hide / Show hidden columns
By default, when you configure a tile all columns will be displayed. To hide a column, simply click Hide for each column you wish to hide.
If you have previously hidden some columns that you now want restored, you can click Show hidden columns to show visible and hidden columns (the toggle will now read Hide hidden columns). Columns that are currently hidden will be grayed out and have the Show option instead of Hide.
Filtering columns in your query
These column modifications are performed client-side, so it's still most efficient to filter the columns directly in your query or script (for example, for SQL or Azure Log Analytics tiles), but if you're using an API that doesn't allow you to filter columns then this feature gets you the results you need.
☰ Drag and drop
Changing the column order couldn't be easier, simply click and drag the gray ☰ icon to the left of the column name.
Changing the name of a column
If you want to change a column name, simply click on the existing column name and enter the new name.
To restore the original name, simply delete your updated name and the column will revert to its original name.
Edit
Data type and Conditional formatting
Select the Data type that applies to the column. This will enable sorting to work effectively, i.e. in numerical order, and show the relevant conditional formatting options.
Text
Conditional formatting for text allows you to change the color when the cell value meets your criteria.
Click Add, then Select Color and choose a color, then click on the mustache picker to see some examples.
For example:
{{value.indexOf('Windows') != -1}} would change the color when the value contains the word Windows. in the case shown.
{{value.match(/system|System/) != null}} would change the color when the value contains the word system or System.
Example of the text data type. Click to view fullsize.
Number
Conditional formatting for numbers allows you to change the color when the cell value meets your numerical criteria.
For example:
{{value > 0.2}} would change the color when the cell value is over 0.2
{{value >= 10 && value <= 90}} would change the color when the value is between 10 and 90
Example of the number data type. Click to view fullsize.
Time
Selecting the Data type of time will automatically format the time data, and show you additional time related conditional formatting. To adjust the time/date format see Using Timeago to convert Unix timestamps
Mostly the time units are milliseconds, but if you know your time is in seconds you can change this here.
For the data type time you can match on any or all conditions
Example of the time data type. Click to view fullsize.
Conditional formatting example for expiring certificates. Click to view fullsize.
Boolean
For the Data type boolean you can choose the true, false and default colors.
Example of the boolean data type. Click to view fullsize.
Default Color
Optionally, set a color for values that don't match any conditional formatting.
Apply color to
By default conditional formatting is applied to the text in the column, click on Background to apply the color to the background.
Whole row
With this ticked the color chosen will apply to the whole row, rather than just the cell.
Default Sort Column
You can select which column is used to sort the data by clicking on the column header in the data view below the Done button. You can toggle between ascending and descending by clicking the header again. When a header is selected a Default Sort Column, is shown in the config, along with a Reset button.
Custom template
The custom template box allows you to format the way the data in a column is displayed. You can then type your standard SquaredUp 'mustache' syntax and click on Done when you have the column looking exactly how you want it. If you want to preview the results before you're done, click anywhere outside the text box while editing it.
A
icon will appear next to the column edit option to indicate that a custom template has been applied.
The mustache syntax is great for converting numbers, adding units, highlighting key values or performing any other customizations you may need. For more information on mustaches see How to use Custom Labels.
Property names that contain hyphens (for example properties.name-with-hyphens) can't be processed due to a JavaScript limitation. If you want to use a property that contains a hyphen, you have two options:
  1. If you have access to the data source and can change the name of the property, change the name of the property to a name without hyphens.
  2. If you can't change the name of the property, you need to enter the property name in the following format:
    Original property name:
    New format:
Show Absolute
true = show absolute time (date) rather than relative time
false = show relative time
Show Time
true = if showing absolute time, show the time as well as the date
false = do not show the time with the date
Without Suffix
true = if showing relative time, this removes the "ago"
false = "ago" at the end will be shown (e.g. 10 hours ago)
With Prefix
true = adds "since" ahead of the absolute time, or "for" ahead of the relative time
false = no prefix will be shown
Tip: The default setting for all parameters is false. If you only want to change the first parameters, you can just use timeago(value, true, true) and it will be interpreted as timeago(value, true, true, false, false).
Examples:
{{timeago(value)}}
To display the absolute time as the date without the time:
{{timeago(value, true)}}
To display the absolute time as the date with the time:
To display the time with the prefix "for" for relative time and "since" for absolute time (for example, "the status has been unhealthy for 10 hours")
Option A) Use the fourth parameter and set it to true. This will insert the appropriate prefix for the absolute or relative time:
timeago(value, false, false, true, true)
Option B) You can leave out the fourth parameter that controls if the prefix "for" or "since" is inserted automatically. Since you left it out, it defaults to false, causing no prefix to be shown. Instead you insert the word "for" or "since" manually before the timeago function.
for timeago(value, false, false, true)
To convert a time value from seconds to milliseconds:
{{timeago(value*1000)}}
Example with a Pingdom property:
Adding custom columns
You can dynamically construct new columns based on the data returned by your tile, which is invaluable when dealing with data sources that only support simple data retrieval, or where the API does not return data in a simple tabular form (such as many JSON based Web APIs).
To add a custom column:
  1. Click the add button near the bottom of the panel.
  2. Click the column name and change the name from customcolumn1 to the name you want to give the column.
  3. In the data key path box, enter the (original) name of the column or path to the desired property in the returned data (this will depend on the API you are returning data from). If you need to access the values of multiple columns (i.e. concatenating two columns together) simply leave the box empty.
  4. Optionally, if you want to customize the display of the column, you can enter a mustache in the custom template box
  5. Click done when you have finished.
Custom columns have a pencil icon in the grid options panel to indicate they have been added by a dashboard author.
Example: Customizing the output of a SCOM task
In this example, we are going to customize the output of a SCOM task from the Data On Demand management pack that displays CPU process information. This will include hiding columns which may not be interesting, reformating some data for legibility, and separating the path column into separate folder and executable columns, so that a long path doesn't make it hard to see what program is being run.
  1. Add a new tile to a dashboard or windows server perspective. If using a dashboard, on the scope panel specify a valid Windows computer.
  2. Click on SCOM Task and then On-Demand Task (Grid). Click next.
  3. In the task config panel select List Processes (Data On Demand) as the task to execute.
  4. Click hide next to sessionId, handles, parentPid and threads.
  5. Click add and select Format in the override parameters dropdown. Enter csv and click apply changes (execute). Click next twice.
  6. Rename cpuPercent to CPU Usage % by clicking on its name in the grid columns panel.
  7. Rename the privateBytes column to Private MB and click edit. In the template box enter {{Math.round(value/1048576)}}. Click done.
  8. Rename the path column to Folder. Click edit and enter {{value.substring(0,value.lastIndexOf('\\'))}}. Click done.
  9. Click add to add a new custom column. Rename the column from customcolumn1 to Executable. In the path box enter path and in the custom template box enter {{value.slice(1+ value.lastIndexOf('\\'))}}. Click done.
  10. Click and drag the ☰ icon to the left of the Executable column above the Folder column.
  11. Click the orange done button to finish editing the tile.
