The dashboard is saved as you go along so there's no need to save your changes. You can find your dashboard from System > Administration > Content > Unpublished. Draft dashboards are not visible to anyone other than you.
You can toggle between Edit mode and View mode by clicking the Edit this dashboard button at the top right.
Tiles added in a column are aligned by their left-hand edge. Adding a row will allow you to align the tops of the topmost tiles in the columns in that row (see below):
The configuration of a tile can be copied and pasted between different dashboards. Tiles can be copied between instances of the same edition, for example from one instance of DS for SCOM to another of DS for SCOM, but not across different editions.
The Copy tile to clipboard button is also available in view mode (when you're not editing a tile) which is useful if you don't have edit rights to the dashboard. Hover over the tile title bar and the Copy tile to clipboard button will appear at the top right of the tile.
When pasting the tile configuration, for the first time, the user will be prompted to grant the browser permission to view clipboard. Once clipboard permission has been granted for a site a clipboard icon appears in the browser address bar allowing the user to manage access via the browser settings.
Note
The tile copy and paste functionality only works if the site is secure (using HTTPS), as this is a requirement for browsers following the W3 spec: Clipboard API and events. Firefox does not support the paste operation. See Mozilla: Browser Compatibility.
Only admins can publish dashboards, unless you have been given author permissions to a Team Folder see Team Folders.
Publish will make the dashboard or changes visible to others. Note: A newly created dashboard will appear on the menu where you created it. To move the dashboard to a different place on the navigation bar see How to edit the Navigation Bar.
Discard will delete your draft dashboard if it has never been published or, if you made changes to an already published dashboard, discard the changes.
In this walkthrough we're going to create a more complex dashboard using the split functionality and dashboard designer tools. We recommend you configure the tiles before creating too complicated a layout, because tiles do change size when showing data.
In SquaredUp navigate to the folder where you'd like the dashboard to be created, click the ellipsis button and then Add Dashboard:
Or you can click Add Dashboard from the menu and move it to a folder later:
Click on the Two tiles template:
First we are going to configure the right-hand tile to show servers in a particular health state. Click configure tile on the right-hand tile:
Click on the Status tile button:
Click on the Icons tile button:
In the scope section click on advanced:
In the class box type group and select group from the drop down list.
In the criteria box type HealthState = 3 or whichever health state (see How to use criteria when scoping objects) you wish to display (1 = Healthy, 2 = Warning, 3 = Critical 0 = Uninitialized) to show a fairly long list for the purposes of this walkthrough. The case of the letters in the word HealthState is important:
Click done. You should now have a dashboard with one long column on the right:
Hover between the columns and drag the column resizing line to the right allowing it to snap into place towards the right of the screen making the right hand column narrower:
We are now going to add a split to the left-hand column. Click on the Split tile button on the left-hand tile:
The left-hand column will now show two tiles nested within it. Try resizing the whole of the left-hand column to see how the two 50% cells within retain their dimensions and resize with the wider column.
Click add new tile beneath each of the split tiles to create 4 tiles:
To look like this:
Now click add new tile below the wider left-hand column to add a tile that spans the width of the two split tiles:
You should now have a dashboard that looks like this:
You can stop here, or you can add to your dashboard if you wish.
We recommend you configure some tiles now, to see how they fill out the space available. The 4 tiles at the top left of the dashboard would work well as Status donut tiles or Alert donut tiles.
You may find you need to create a new split and move tiles into that if you want the tiles to align by their top edge:
You may wish to add a large title for a wall monitor display, using the Web Content tile:
Tile sizes will change slightly depending on the tiles you configure, and some tiles, such as Status and Matrix tiles, can dynamically show more or less objects. For example, the list of unhealthy servers may be longer one day than another. If you're aware that one tile may expand or contract you might not want to put another tile beneath this one, instead you could add tiles to other columns.
One long list
Column list
Icons only
Other tiles such as the Performance tile line graph, heatmap and Web Content tiles have a height slider:
