How to upgrade SquaredUp DS for SCOM (in-place)
Upgrading to v7, or from one minor release to another (e.g. v6.4 to v6.5), defaults to an In-place upgrade.
You can upgrade to v7 from any release of v5 or v6. When upgrading from v4.x we recommend you have the latest version of SquaredUp DS v4 installed. Download the latest v4 version here.
Upgrades from v4 or v5 default to a side-by-side install and there are further considerations described in the specific upgrade article:
Carrying out an In-place upgrade
The steps below describe how to carry out an In-place upgrade by simply downloading and running the latest installer on the server where SquaredUp DS is installed.
- Before upgrading we recommend you backup SquaredUp DS for SCOM (see How to backup and restore SquaredUp DS for SCOM).
Any changes made to the
web.configsuch as adding Proxy configuration, will be lost during the upgrade. We recommend taking a backup of this file, so that it can be restored afterwards.Find the
web.configfile located in the SquaredUp folder.Create a backup of theThe default location for the SquaredUp folder is
C:\inetpub\wwwroot\SquaredUpv5and for v4C:\inetpub\wwwroot\SquaredUpv4.Name of the SquaredUp folderA custom location may have been chosen during the installation.
SquaredUpv5, and for v4SquaredUpv4.web.configfile by copy and pasting the file to a different location.Open the
web.configfile in the SquaredUp folder as an administrator. - Download the latest version of SquaredUp DS.
- Run the installer that you have downloaded.
- Leave the default install type as In-Place. Check the correct SquaredUp DS instance is going to be upgraded. You can click edit to see more details. For important information about migrating from older versions see
- Side-by-side - This migrates your dashboards to a new instance of the new version, but leaves your old instance as it is.
- In-place - This upgrades your old instance to the version you are installing. It is not possible to revert or rollback to your old version.
- New installation - This will install a separate instance of the new version which does not use any dashboards from your old instance. See How to install SquaredUp DS for SCOM
- Complete the installer, and open SquaredUp DS.
- Login to SquaredUp DS.
- Any Open Access dashboards you have will be refreshed, after any upgrade.
- When you upgrade to SquaredUp DS v4.6 and above any upgraded dashboard packs will be imported.
If changes have been made to the dashboards or perspectives in the upgraded packs then you will be shown a Conflicts Detected page when logging in to SquaredUp DS.
For more information see Dashboard Packs
If you have configured high availability (HA)
If you are using multiple SquaredUp servers using high availability (HA) with a load balancer there are some important considerations to be aware of.
