Action buttons for dashboards and perspectives
About action buttons
Action buttons are customized buttons that you can add at the top of a dashboard or perspective.
  • Open an internal link
    An internal link within your SquaredUp DS instance. For example, when you want to link from an object's perspective to a dashboard that is relevant for that object.Internal links use only the part of the URL that comes after .../SquaredUpv[version number]/. For example, if the full URL to a dashboard is https://mysquaredup.com/SquaredUp/page/dashboard-enterprise-applications, you need to use /page/dashboard-enterprise-applications.
  • Open a web link
  • Execute a SCOM task
    You can run a SCOM task on an object.
    Which tasks are available depends on the object and the management packs that are installed. Only users with the correct SCOM access will be able to run the task (see How do SCOM roles affect what users can do in SquaredUp DS?).
How to create an action button for a specific task
  1. For dashboards: Go to the dashboard where you want to add the action button.
    For perspectives: If you want to add the action button to a specific perspective, go to an object that contains the perspective and choose this perspective. If you want to add the action button to all perspectives of a specific class of objects, go to an object that is a member of this class.
  2. Click on the edit button to go into edit mode.
  3. Click on the Edit actions button.
  4. Under Actions, click on the add button.
  5. Enter a name for your new action button.
  6. Select the type of action you want to create:
  • Open a web link
  1. If you selected the action type "task":
    For dashboards: Enter the object you want to run the task on. While you are typing, you'll get suggestions for matching objects. Then select the task you want to run from the dropdown.
    Some tasks let you override parameters, for example the time until the task runs into a timeout. Which parameters are available depends on the task.
    For perspectives: Select the task you want to run for the object you are currently viewing.
    Take care to add task buttons to a relevant perspective so the button doesn't appear for objects where it will not run. For example, if you add the Display Server Statistics task to a button on the Monitored Entity perspective then it will show for all objects, but when if you try to run it when you are viewing an application you will get a task failed error message because server statistics cannot be shown for an application.
  2. Only for perspectives: Decide when the action button will be shown. "only show when this perspective is selected":
    If you leave the checkbox activated, the action button will be visible only on this one perspective.
    If you deactivate the checkbox, the action button will be visible on all perspectives for all objects of the same class as the object you are currently viewing.
  3. Click done to save the action button.
  4. You can add more buttons or click done to finish adding buttons.
  5. Click publish to make the changes live.
    For task action buttons: All users with the correct SCOM access will be able to run the task with the action button. Clicking the button will display the results of the task at the top of the page. The results stay there until you close them or go to another page.
5 minute Video
This 5 minute video 'Dashboard actions' describes how to create and edit actions on a dashboard or perspective:
