How to scope tiles
The scope of a tile defines for which objects data will be shown.
How to scope tiles on dashboards
For some tiles on dashboards, defining a scope is mandatory. For other tiles, defining a scope is optional. For example, the API tile doesn't need a scope, but you can use the scope to filter the results further.
Options for scoping tiles on dashboards
List
List allows you to select one or more objects or groups.
Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Group
Group allows you to select members of a specific group. Only one group can be selected.
Advanced
Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
Group:
Class:
Criteria:
Objects you would like to see
Criteria
Objects with particular text in their name
DisplayName like '%Server1%'
Objects starting with a particular string
DisplayName like 'test%'
All objects in maintenance mode
InMaintenanceMode = 'TRUE'
Only healthy objects
HealthState = 1
Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark.
HealthState = 0
Objects that are not healthy
HealthState != 1
Objects in critical state
HealthState = 3
Objects in critical or warning state
HealthState = 2 or HealthState = 3
To show all gray uninitialised objects
HealthState = 0 OR HealthState IS NULL
All objects not in maintenance mode
InMaintenanceMode != 'TRUE'
Objects where the parent agent is offline
IsAvailable='false'
Objects that are offline, in maintenance or state unknown
IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0
Computers with a particular OS
OSVersion = '6.3.9600'
List objects by name and filter by HealthState
List objects by SCOM Id and filter by HealthState
Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3
Exclude object from the Group specified
DisplayName not like '%server3%'
Exclude objects from the Group specified
(DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')
For more information see:
Tips and scope examples
What you want to select
What to use as a scope
All your Distributed Applications (DAs)
In the advanced section, use a class of either service (system.service) or user created distributed application
Only your Enterprise Applications (EAs)
In the advanced section, use a class of Enterprise Application (Base)
FAQs
I'm missing certain objects or groups. Why can't I find them?
SquaredUp DS adheres to SCOM Role Based Access Control (RBAC). This means users will only see in SquaredUp DS what they are allowed to see in the SCOM. Any SCOM user can log on to SquaredUp DS and RBAC will be applied. See How do SCOM roles affect what users can do in SquaredUp DS?.
Only for Performance and Matrix tiles: Why do I get the error "No values found for the given metric for the last <time period> at the resolution '<raw/hourly/daily>'"?
You may get this message returned if you change the scope after setting the metric.
Symptoms
A Performance tile or Matrix tile shows no graph (graph tile is blank) or an error similar to the following:
The server encountered a problem whilst processing the request.
No values found for the given metric for the last <time period> at the resolution 'raw/hourly/daily'.
Cause
This error indicates that there is no data to show. There are several reasons why there may not be any data:
  • No data is being collected.
  • The SCOM collection rule is saving data to the Operations Manager database, but not to the Data Warehouse database.
  • For the chosen timeframe and resolution there is no data.
  • For the chosen scope and metric there is no data.
  • The group specified contains only subgroups and you have not specified, or have removed, the class.
Procedure
  1. Install the latest version of SquaredUp DS
  2. Check the Data Warehouse connection
    If this message is shown for all performance graphs in SquaredUp DS then you should check that Data Warehouse specified is correct.
    See Troubleshooting the Data Warehouse connection.
  3. Check data is being collected
    SquaredUp DS uses data from the Data Warehouse database. If the data is available in SCOM this means the data is being collected and stored in the Operations Manager database. SCOM Reporting uses the Data Warehouse database, so if the data appears in a report then it is in the Data Warehouse.
    Flush the health service state and cache to trigger the workflows to collect the data, either using SCOM or SquaredUp DS.
    To do this in SquaredUp DS, browse to the object in SquaredUp DS, then:
    1. Click on the Monitored Entity perspective.
    2. Click on Health Service in the Children section.
    3. Click the task button at the top of the page.
    4. Select the task Flush Health Service State and Cache.
    5. Click execute.
  4. Change the timeframe
    Change the page timeframe, or tile timeframe if applicable, to see if there is data over a different period of time. See Timeframes for tiles
    Why is no data shown?
    There may be no data points available if you are using hourly data and looking at the last 1 hour (metric > resolution is set to hourly and the tile or page timeframe is set to last 1 hour), or using daily data and looking at the last 24 hours (metric > resolution is set to daily and the tile or page timeframe is set to last 24 hours). Try changing the resolution to auto and the tile or page timeframe to a longer time period.
    The timeframe section allows you to determine the timeframe for the data. You can choose either to use:
    Use page timeframe
    The page timeframe is the timeframe setting a dashboard or perspective is currently using. These timeframes are all relative to the current time, for example 7 days ago until now. When a user changes the page timeframe, all tiles that have use page timeframe set will adapt to the new timeframe. (Tiles that do not have use page timeframe set (i.e. are set to specific timeframe or custom timeframe) are not affected and won't change.)
    Specific timeframe
    These timeframes allow you to set a fixed timeframe such as last 1 hour or last 7 days. You can use the
    sample relative timeframes button to get some examples for different timeframes. These timeframes are all relative to the current time, for example 7 days ago until now. Using this setting means that any change the user makes to the page timeframe is ignored.
    The custom option can be used to set timeframes using
    Custom timeframe
    This allows you to set a fixed timeframe window from the time and calendar picker. This sets a completely customizable timeframe window, not relative to now.
  5. Check the resolutionData resolution in the Data Warehouse
    Resolution refers to the raw, hourly or daily data stored in the Data Warehouse.
    The data available in the Data Warehouse is determined by the retention period set in SCOM.
    Whether raw or hourly data is available for the whole timeframe will depend on your Data Warehouse data retention settings. Using the default SCOM data retention settings means that SquaredUp DS timeframes of 1 week or less will probably be using raw data, for timeframes between 30 days and 12 months SquaredUp DS will be probably be using hourly data. The SCOM data retention settings may well have been changed from the default.
    Understanding how SquaredUp DS uses the different resolution data from the Data Warehouse
    For Performance tiles the resolution is set in the Metric panel. Try changing metric > resolution to auto.
    SquaredUp DS, when using the auto resolution setting, uses the highest resolution data available (raw, hourly or daily), based on what data is available in the Data Warehouse for the whole graph timeframe. So SquaredUp DS will use raw data as long as it is available for the whole reporting timeframe, then it will use hourly, and when that is not available for the whole timeframe it will use daily data.
    For Performance tiles the resolution is set in metric > resolution
    Using the autoresolution setting on a Performance tile automatically changes to a more suitable resolution when the page timeframe is changed by a user, in order to optimize the time to return the graphs.
    The auto setting applies to visualizations that use time periods, such as line graphs, sparklines and reports. Visualizations that do not show a time period, such as Bar Top N, Heatmap and Scalar, use the latest data point. These visualizations do not change when a user changes the page timeframe. For these visualizations the auto resolution setting defaults to daily.
    Why is daily, rather than hourly, data shown for a 6 month graph?
    When the retention period for hourly data is set to 180 days and a SquaredUp DS graph is set to display 6 months of data, this can actually be 182 or 183 days. SquaredUp DS will switch to daily data because hourly data is not available for the full 6 month period, i.e. the retention period is less than the date range. The solution is to modify the retention period to reflect 6 months i.e. an extra 5 days and set the retention period to 185 days, this should not affect your storage levels too greatly. After a few days this will resolve the problem because 6 months of hourly data will then be available, when SquaredUp DS checks the retention period against the requested time frame, the retention period would be higher and SquaredUp DS would show hourly data.
    For more information see How to optimise the Data Warehouse - 5 Point Plan - 4. Data Retention
  6. Check the metric
    The quickest way to check the metric is correct, is to clear the existing metric and use the down arrow button on the keyboard to view all the metrics available for the scope you have chosen.
    You may get the No values found for the given metric message returned if you change the scope after setting the metric.
How to scope tiles on perspectives
  • the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
  • the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
General advice for scoping tiles on perspectives
Remember that a tile scope on a perspective usually needs to work for many different objects. You need to consider:
  • For which objects will this perspective be visible? (determined by the target of the perspective)
  • Is the scope I am configuring appropriate for all objects the perspective will be visible on?
Example:
You create a perspective with the target "class: Windows Server". The perspective will therefore be visible for all objects of the class Windows Server.
Now you create a tile on the perspective and scope it to "this object's children of class: Windows Server 2016 Logical Disk". This means that when you view a 2016 Windows server, you'll see data about the server's logical disks in the tile. But when you view a 2012 Windows Server the tile will show no data because the tile's scope is limited to logical disks on 2016 servers. Instead of picking "Windows Server 2016 Logical Disk" you should pick "Windows Server Logical Disk" to make the tile adjust to any object that uses the perspective.
There are two different sets of options when scoping tiles on perspectives. It depends on the tile you want to scope which set of options you'll see.
Suggestions
A sibling of an object is any object of the same class that is hosted by the same parent.
This object
This / *
Example:
This / IIS Web Server / * selects all objects of any class in the level below This / IIS Web Server.
Example:
Parent class of object
Sibling class of object
  1. For an EA you want to scope to the servers that are specified on the EA map by selecting something from the suggestions (SquaredUp DS 4.2 and above) that shows something similar to the following:
    The screenshot below shows some scope suggestions for an application called FinanceXS. The bold text shows the currently selected scope is This object. The cursor shows the option This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
  2. In the scope section click custom.
  3. Click on the text <YourApplicationName> Map (children) which is your first scope step. This will expand the scope step so you can edit it.
  4. Remove the auto-populated class <YourApplicationName> Map by clicking the cross x next to it.
  5. Start typing Enterprise Application - Map and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
  6. The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
Custom
  1. At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
  2. Class:
  3. Criteria:
  2. Class:
  3. Criteria:
Other specific objects
The Alerts and the SCOM task tile have slightly different options than other tiles because they require different settings.
This object
Relative objects
  2. Class:
  3. Criteria:
Note for SCOM task tiles:
