How to configure SquaredUp DS to use a proxy
If you use a proxy server you may get an error when activating SquaredUp DS or configuring an OAuth Web API provider.
This provider has not been authorized (or there is an error with its configuration)
You need to configure SquaredUp DS to use the proxy, as described below. This will configure SquaredUp DS to use the proxy settings from Internet Explorer. For more information see the defaultProxy element article from Microsoft.
Adding a proxy to the web.config
Find the
web.configfile located in the SquaredUp folder.Create a backup of theThe default location for the SquaredUp folder is
C:\inetpub\wwwroot\SquaredUpv5and for v4C:\inetpub\wwwroot\SquaredUpv4.Name of the SquaredUp folderA custom location may have been chosen during the installation.
SquaredUpv5, and for v4SquaredUpv4.web.configfile by copy and pasting the file to a different location.Open the
web.configfile in the SquaredUp folder as an administrator.- Add the following XML snippet under the
<configuration>section of theweb.configfile:<system.net> <defaultProxy enabled="true" useDefaultCredentials="true"> <proxy usesystemdefault="true" /> </defaultProxy> </system.net> - If your proxy uses Active Directory for authentication, the responsible team will need to give your SquaredUp DS application pool user(s) access. For more information about identifying the SquaredUp DS application pool identity for each of your SquaredUp servers see How to check and modify the application pool identity.
