After installing SquaredUp DS you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key), which is then activated against a SquaredUp DS installation.
When you apply for a free trial you receive an unrestricted 30 day evaluation to try out all features in your own SCOM environment: Request a free trial activation key. If you've previously had a trial, or your trial has expired please contact SquaredUp Support
When you buy SquaredUp DS you will be emailed your license keys. If you do not have a license activation key please contact SquaredUp Support
Types of license keys
Trial license
This license allows for unlimited users and all features for a 30 day evaluation in your own environment and is available from here
Primary Production license
This license should be used if you only have one SquaredUp production server, or on your first SquaredUp production server if you are configuring a multi-server / high availability environment (see Enabling High Availability)
Secondary license
This license should only be used for any subsequent servers in a multi-server / high availability / load balanced environment (see Enabling High Availability)
Test & Development license
This license is for your test environment so that you can experiment with configuration changes and new versions without affecting production.
It is included free of charge with a purchase of the Teams, Connect and EAM editions.
If you are upgrading from v3 to v4 you should request a v4 evaluation license before starting your v4 installation. This will allow you to perform any upgrade testing and user acceptance testing, prior to going live and switching your production use to v4. Without this license you will be able to install v4 and perform an upgrade assessment, but unable to then activate the product and start testing.
Once you are ready to move to v4 in production, enter your Primary license key into the Switchover portal to convert all your existing v3 licenses to v4 licenses which can be used to activate v4. From that point you will have 3 months to run v3 and v4 side-by-side in production, before the v3 instance is no longer supported and you will be in violation of the SquaredUp EULA.
Browse to <SquaredUpURL>/activation to get to your server's activation screen.
By default, the URL to your SquaredUp DS instance is: http://SquaredUpServer/SquaredUpInstance
SquaredUpServer is the name of the server where SquaredUp DS is installed.
By default, SquaredUpInstance is SquaredUp. For v5 it is SquaredUpv5 and for v4 SquaredUpv4. If you gave your SquaredUp DS instance a different application name when you installed it, use the name you chose.
Drag the .bin file into the box that says Drop license file or click to install. To return to the screen above browse to <SquaredUpURL>/InstallLicense and log in as an administrator.
If you uninstall and reinstall on the same server you can reuse the same .bin file by browsing to /InstallLicense. The .bin file cannot be used on a different server.
