How to use the Monitors tile
About the Monitors tile
The Monitors tile displays the health state of monitors that use the object in the scope as their target.
The Monitors tile can be used on a dashboard or a perspective
What are monitors?
Monitors are used in SCOM to determine health information and make sure items are working within predefined thresholds. When a threshold is hit the monitor can raise an alert, and the monitor can change the health state of an object. Rules can also raise alerts, but cannot change the health state of an object.
Users may not be aware of the differences between monitor and rule alerts, and that monitor alerts should not be closed. Dashboard Server uses different alert icons for rule and monitor alerts to help users be more aware of these differences.
Monitor alerts
Monitor alerts are shown by a solid icon (like the health state icon, but round) to indicate that the alert is affecting the health state of the object, because the alert has been raised by a monitor.
A monitor alert is 'stateful' and therefore current. A monitor changes the state of the monitor, which then triggers an alert. This means that if the monitor alert is still visible, then it is still a current issue. Once action has been taken, a user can click the reset monitor button to force SCOM to reevaluate the health of the object, and if the issue is re-detected then the alert will be reopened. When the issue is resolved the alert will be closed automatically, so monitor alerts should not be closed manually.
When changing the resolution stateclosed is not the default option, and if a user tries to close a monitor alert a warning is shown and confirmation is required.
Monitor alerts are used to show How to use the Monitors tile for unhealthy objects in Dashboard Server.
Rule alerts
A rule can trigger an alert, but not change the state of the object, or rollup to the parent. A rule alert shows that something has happened in the past, but it won't necessarily happen again. If the issue reoccurs, then the alert RepeatCount increases. Rule alerts should be closed manually when the issue has been resolved.
Rule alerts are shown by a hollow icon (that’s different from the health state icon) the alert is not affecting the health state of the object because it has been raised by a rule. Rule alerts should be closed manually by clicking the resolution state button.
Summary of the differences between rule and monitor alerts
Monitor alerts | Rule alerts |
Stateful | Non-stateful |
‘There is a problem’ | ‘There was a problem’ |
Affects health state of object | Does not affect health state of object |
Rollup health to parent object | Does not rollup health to parent object |
Changes health state of dashboard | Does not change health state of dashboard |
Creates alert (normally) | Creates alert (normally) |
Alert stays open while issue remains | RepeatCount incremented if issue reoccurs |
Closes alert automatically (normally) | Does not close alert automatically |
Can be manually reset back to healthy | Cannot be reset (no state) |
Alerts should not be closed manually | Alerts should be closed manually |
There are a three types of monitors in SCOM:
- Unit monitors - measure something, such as how much free disk space there is on drive C:
- Dependency rollup monitors - used for rolling up the health state of members to the group health state (see Groups show no health information).
- Aggregate rollup monitors are not displayed by the Monitors tile.
Monitors states
![]() Green | Healthy |
![]() Yellow | Warning For example, a monitor might be configured so that when a disk goes below 10% free space the monitor goes yellow and an alert is raised. |
![]() Red | Critical If the free space goes below 5% the monitor may be configured to go red, and a critical alert be raised. |
![]() Gray | Unknown/uninitialized A gray circle shows that this monitor does not currently have a health state. |
How to configure a Monitors tile
Add a new tile to a dashboard or perspective and choose the Monitors tile.
Choose the visualization for your Monitors tile:
Monitors Icons
Shows monitor icons.
Monitors Blocks
The Blocks visualization is a simple way to build high impact dashboards, and is perfect for wall monitors or to grab attention.
Scope:
The Monitors tile will display monitors that target the class of object you use in the scope. You will need to specify the correct object in the scope in order to see the monitors you want. If the monitor you want is not shown, check the configuration of the monitor in SCOM, and look at the monitor target.
The Monitors tile will only display Unit monitors and Dependency rollup monitors.
If you want to display only one particular monitor, use the scope > list option and enter the name of one object, such as a server or database, then in monitors > filter type the name of the monitor to display.
Scope options on dashboards
List List allows you to select one or more objects or groups.
Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Tips for using wildcards when searching for objects or groups
Group Group allows you to select members of a specific group. Only one group can be selected.
Advanced Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
Group:
Class:
Criteria:
Examples for commonly used criteria
Objects you would like to see Criteria Objects with particular text in their name DisplayName like '%Server1%'
Objects starting with a particular string DisplayName like 'test%'
All objects in maintenance mode InMaintenanceMode = 'TRUE'
Only healthy objects HealthState = 1
Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark. HealthState = 0
Objects that are not healthy HealthState != 1
Objects in critical state HealthState = 3
Objects in critical or warning state HealthState = 2 or HealthState = 3
To show all gray uninitialised objects HealthState = 0 OR HealthState IS NULL
All objects not in maintenance mode InMaintenanceMode != 'TRUE'
Objects where the parent agent is offline IsAvailable='false'
Objects that are offline, in maintenance or state unknown IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0
Computers with a particular OS OSVersion = '6.3.9600'
List objects by name and filter by HealthState (Name like '%Server3%' OR Name like '%Server4%' OR Name like '%Server2%') AND HealthState=3
List objects by SCOM Id and filter by HealthState Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3
Exclude object from the Group specified DisplayName not like '%server3%'
Exclude objects from the Group specified (DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')
For more information see:
Scope options on perspectives
the actual resolved scope that depends on which object you are currently viewing ("this object has 5 child objects of type logical disk")
Suggestions
For example, when you pick a suggestion for an EA, you will get suggestions that are specific to the map, dependencies, and availability tests for this one EA. On perspectives you want to use for all EAs, you have to change the scope suggestion in the custom section so that the tile work for all EAs.Walkthrough: Editing a scope suggestion to make it work for all EAs
This / FinanceXS / ... / Windows Computer
. Once chosen this scope will show all the Windows computers shown on the applications map.Next, we need to adjust the specified scope to allow it to work for all EAs, rather than just this one.
Click on the text
<YourApplicationName> Map (children)
which is your first scope step. This will expand the scope step so you can edit it.Remove the auto-populated class
by clicking the cross x next to it.Start typing
Enterprise Application - Map
and select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.- The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
How to read the suggestions
This / child
/child
/class of object
Example:
This / IIS Web Server / *
selects all objects of any class in the level belowThis / IIS Web Server
.This / child
/ ... /class of object
Example:
This / Sales App Map / ... / Windows Computer
selects all objects of the class Windows Computer in theThis / Sales App Map
path.Parent class of object
The dynamic scope will be resolved to parents of the object currently viewed. Sibling class of object
The dynamic scope will be resolved to siblings of the object currently viewed. Show more triangle next to a suggestion
You can click the show more triangle to expand the list of suggestions and see more specific paths.Example for navigating suggestions in an EA
If you are looking at an EA, the path to find all windows computers in that EA may read
. It returns all objects of the Windows Computer class contained within all of the paths underMap
.To narrow the scope down, you can click on the triangle to expand the suggestion and select one of the more specific paths. If you select
Map / Web / Windows Computer
you will find all objects of the Windows Computer class in the pathMap / Web
.If you choose the option
Map / *
you'll find all objects contained in the map. If you extend this suggestion by clicking on the triangle, you'll see suggestions to select all objects in a more specific path, for exampleMap / Web / *
.Custom
How to pick a simple relation (one step through the SCOM model)
At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
Class:
Criteria:
Example for picking a simple relation
For example, for a perspective created for the group IIS8 Computer Group adding a Status tile scoped to show children with a class of
object
will show the group members, i.e. the members of the IIS8 Computer Group.How to pick advanced relations (multiple steps through the SCOM model)
Class:
Criteria:
Other specific objects
Notes for selecting the scope for Status Icons or Blocks
Which status is displayed depends on what you choose as a scope:
If you want to see the status of individual objects (for example, two individual servers), select multiple objects in the list section.
If you want to see the status of a group itself rather than the individual objects within the group, select a group in the list section.
If you want to see the status of each individual group member of a group, select a group in the group section.
If you want to see the health state of all groups, select the class "group" in the advanced section.
Monitors:
Here you can filter the monitors if you only want to display specific monitors. Start typing the name of the monitor you want to display in the choose monitors field to get suggestions for matching monitors.
Filters:
Here you can filter the monitors to specific health states. By default, all health states will be shown. Click on one of the health states to hide monitors with this state.
Sort:
Sort allows you to change the order of the results displayed. You can sort by label (ascending or descending) or health state (ascending from healthy to critical or descending from critical to healthy).
Limit:
Allows you to define a maximum number of objects that will be shown. When 'group by' is used the limit applies to each group individually, for example to show 10 objects in each health state.
Only for Monitor Icons: You can change the way the icons are displayed by using the toggle zoom
button at the top right of the tile. You can toggle between list, column and tile view.
Only for Monitor Blocks: You can change the way blocks are displayed in the following panels:
Blocks
Here you can change how many columns are used to display the blocks, their height, and the font size of the labels on the blocks.
Label
none Use no label.
name Use the monitor's name as the label.
description Use the monitor's description as the label.
custom
Important note if you are using external API properties with hyphens for custom labels (Web API tile, Elasticsearch tile, Splunk tile)
Property names that contain hyphens (for example
properties.name-with-hyphens
) can't be processed due to a JavaScript limitation. If you want to use a property that contains a hyphen, you have two options:If you have access to the data source and can change the name of the property, change the name of the property to a name without hyphens.
Original property name:
New format:
Sublabel
New format:
none By default, no sublabels are shown.
Walkthrough: Adding Monitors tiles to a dashboard
- In Dashboard Server browse to an object whose monitor(s) you would like to add to a tile. For this walkthrough, search or browse for a database.
Click on the Monitored Entity perspective to view the list of monitors available.
- In another tab (perhaps duplicate the tab) browse in Dashboard Server to where you'd like the new dashboard to be created. Hover over the + button and click dashboard.
The dashboard is saved as you go along so there's no need to save your changes. You can find your dashboard by clicking on the right-hand menu ☰ > system > unpublished.
- A new tile has already been added to the dashboard. Edit the title by overwriting the placeholder value New tile with your own tile title, such as the name of the database.
- First, we will add a single Monitors tile, using the Icons visualization. The tile selector will already be open. Click Monitors.
Click on the Icons button.
Next, we need to scope the tile. In the scope section select list then type the name of the object for which you wish to see the monitors, and then click on object from the results. For this walkthrough add the database that you browsed to in step 1.
Monitors will only be shown that use the object in the scope as their target. SquaredUp supports Unit and Dependency rollup monitor types only. Aggregate rollup monitors, such as the entity health monitor, will not display.
Monitor icons should appear after a moment. You could stop here, but we'll continue to configure the tile.
- In the monitors section click on filter.
In the choose monitors box type any word from the name of the monitor that you want to display. Click on the monitor in the list displayed. If you wish you can type a new search word and select more than one monitor to display.
- Click next and leave the filters section as it is.
Click done and your Monitors Icons tile will look something like this:
Next, we will add a Monitor Blocks tile to the dashboard to show several monitors.
- Click on the orange plus button to add another tile to the dashboard.
Click on the Blocks button to create a Monitors Blocks tile.
In the scope section type the database name into the list box.
Blocks should appear after a moment. You could stop here, but we'll continue to configure the tile.
- In the monitors section leave it set to all.
- In the filters section click on uninitialized to remove gray uninitialized monitors.
In the blocks section you can change the number of columns, the block height, as well as the font size. This can be useful when creating a dashboard for a wall monitor.
- The label and sublabel sections allow you to change the block labeling or even create a custom label (How to use Custom Labels). We're going to leave these as they are for this walkthrough.
Click done and your Monitors Blocks tile will look something like this:
