How to add an SQL provider
What are Integrations?
Dashboard Server Integrations allow you to create your own providers. Each Integration has its own form to help you input the information required for different providers.
What is a provider?
About SQL providers
Since Dashboard Server version 5.4 you need an SQL provider to use the SQL tile. Your Data Warehouse is available as a provider by default but if you want to use any other connection you'll need to create a provider.
Adding an SQL provider
Make sure you have access to the database you want to use.
Configuring access to a database for an SQL provider
Access to the SCOM Data Warehouse
Access to the SCOM Data Warehouse is configured during the Dashboard Server setup process. If you are able to see graphs in Dashboard Server, SQL queries have access to the SCOM Data Warehouse (see How to check and reconfigure the Data Warehouse connection).
Access to other databases
To be able to query other databases, such as the Operations Manager database, the Dashboard Server application pool identity needs to be given the db_datareader role in SQL Server Management Studio for the database you wish to query. See How to configure access to a database for use with the SQL tile.
Provider name:
Driver and Connection String:
Connection strings when you are using Microsoft SQL Server Driver
If you want to connect to the SCOM Data Warehouse:
Tip: Dashboard Server already comes with a default SQL provider that connects to your Data Warehouse, so you don't need to create a provider for this connection. In case you deleted this provider, you can always recreate it with the following connection string:
Copyglobal:dw
If you want to connect to the Operations Manager database:
CopyServer=<SQLservername>;Database=<OperationsManagerDatabaseName>;Integrated Security=True;
Tip: If the Operations Manager database is on the same server as the Data Warehouse you can use the Data Warehouse provider in your tiles, but you need to remember in the Query panel that you have to put the following in front of the query:
USE <OperationsManagerDatabaseName>;
If you want to connect to any other data base:
With integrated security:
CopyServer=<SQLservername>;Database=<DatabaseName>;Integrated Security=True;
With username and password:
CopyServer=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
CopyServer=<SQLservername>\\<InstanceName>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1\\Main;Database=CRMDB;Integrated Security=True;
If you want to specify a port
CopyServer=<SQLservername>,<PortNumber>;Database=<DatabaseName>;Integrated Security=True;
Example:
CopyServer=SQLServer1,51433;Database=CRMDB;Integrated Security=True;
Connection strings when you are using ODBC
Note: You need to use 64-bit ODBC drivers.
Example:
CopyDriver=<ODBCdriverName>;Server=<SQLservername>;Database=<DatabaseName>;User Id=<username>;Password=<password>;
If you are using a System DSN
CopyDSN=<DSNname>
Click save to save your new provider.
