How to add an Elasticsearch provider
What are Integrations?
What is a provider?
About Elasticsearch providers
An Elasticsearch provider is a dedicated provider that contains the connection details to your Elasticsearch instance. You need to create a Elasticsearch provider before you can use Elasticsearch tiles.
When you are creating an Elasticsearch provider, make sure that the SquaredUp server has access to your Elasticsearch instance, since it is the server that connects to Elasticsearch, and not your users' browser.
Adding an Elasticsearch provider
In Dashboard Server, navigate to the right-hand menu ☰ > system > Integrations.
Under Integrations click Elasticsearch:
In the service name box type in a suitable name, e.g. Elasticsearch
Enter the URL for your Elasticsearch instance.
The URL depends on your Elasticsearch environment:
If you are using the Elastic cloud service, you need to enter the endpoint URL, which has the following format:
https://CLUSTER_ID.REGION.CLOUD_PLATFORM.DOMAIN:PORT
If you are running Elasticsearch in a different environment, ask your Elastic administrator for the instance URL and port number.
Enter the username and password for your Elasticsearch instance into the appropriate boxes:
Change ignore invalid ssl to on if you are using a self-signed certificate.
Click save.
